Tap test hammer
Tap test hammer
Does anyone know where to find a composite tap hammer? We've got some heavy inspections coming up and I tend to spend my loonies as fast as I get them.
http://www.heatcon.com/wind-energy/tool ... tap-hammer
I asked for a quote from this place about a month ago, and they ignored me.
I also checked Mac, Snap-On, Brown, USATCO, and MATCO. No luck.
Re: Tap test hammer
I know where you can get one for a nickel...
Re: Tap test hammer
One manufacturer of helicopters suggests using an 8mm diameter steel rod 10cm long for tap testing composite blades. If you are going to be tapping that much that you need a hammer, have fun, after 2 hrs, all you hear is tap, tap, tap, tap......
Re: Tap test hammer
A representative of a certain helicopter manufacturer handed out lots of composite tap tool rods to our crews at one time.
Take a steel rod 1/4 diameter, about 2 inches long, round off the ends on a lathe. That's all it is.
Or take a small brass drift from Snap-On and use the rounded end.
I use both methods.
I use both methods.
Re: Tap test hammer
Just weld a steel ball on a stel rod,works well lasts a long time
Re: Tap test hammer
Why would you want to tap test a hammer?
Re: Tap test hammer
More importantly, when did they start being called hammers?niss wrote:Why would you want to tap test a hammer?
This is aviation. Tapometers people, tapometers...
Re: Tap test hammer
For christ's sakes, if you want to be called an engineer start sounding like one! It doesn't measure tapo's! It smashes stuff!iflyforpie wrote:More importantly, when did they start being called hammers?niss wrote:Why would you want to tap test a hammer?
It is a solid state force transfer through leverage application device.
Re: Tap test hammer
the tap hammer is a really small piece of alum, turned to a Boeing drawing,I have made about 500 of these things for the inspectors in my shop over the years.it's not meant for "smashing" things. lol
Re: Tap test hammer
Do you have the drawing you built from that you could share with the rest of us?blastingcoffee wrote:the tap hammer is a really small piece of alum, turned to a Boeing drawing,I have made about 500 of these things for the inspectors in my shop over the years.it's not meant for "smashing" things. lol
Perhaps a wee scan?
- GA MX Trainer Dude
Re: Tap test hammer
Hey - Plane Jane hammers are so last century
http://hotbonders.wichitechindustries.c ... ssment.pdf
http://www.google.com/patents/US6748791 ... &q&f=false - Us Patent
You need one of these to be up to date!! LOL
Source to buy;
http://hotbonders.wichitechindustries.c ... &forward=1
Most often there is a drawing of the tap test method and equipment in the manufacturers manual - try Standard Practices section.
I have had very good results with the big ball bearing welded to a 1/4 inch rod (6.35mm for you metric gearheads) - have also used big washers with the edges filed round - just make 100% sure that you do not damage the surface with whatever tool you are using. Don't forget to calibrate your ear - I find it interesting that many don't actually know what a defect sounds like.
If I can find a drawing I will try and post it.
EDIT: - Link to Tap Test Hammer Drawing http://1pointperspecti.ucoz.com/load
This drawing is from MIL HandBook - 337 Section 10.
Hope that helps for a generic hammer - your aircraft manufacturer might have a different one that they want you to use.
Mutatis mutandis - (A caution to a reader when using one example to illustrate a related but slightly different situation. The caution is that the reader must adapt the example to change what is needed for it to apply to the new situation.)
Regards
Mx
Source to buy;
Regards
Mx
- twistedoldwrench
Re: Tap test hammer
and dont forget to get the certificate saying its calibrated to a national standard
Re: Tap test hammer
For those that have the ability and resources to produce a manual tap hammer, please let me know if you would want to make a couple for me with a price included? Or if there is a manufacturer website that is valid where I could go and buy one. The Yard store and Brown aviation tools do not carry these. Thank you very much and please no weird remarks.
Re: Tap test hammer
try this one
- try this one
- 6_Tap_Hammer.jpg (609.73 KiB) Viewed 4060 times
