My plane is going into annual soon. Currently I have a Cessna 300 transponder, one of these clunkers: http://www.bennettavionics.com/rt359a.html (not entirely sure this is the exact model but it looks the same). At last calibration test, I was told it was pretty iffy. The last time I flew in controlled ATC was reading me 200ft higher than actual. So Im willing to bet theres a good chance it needs to be repaired or replaced. So a few questions:
A) how much, if any, money is it worth putting into repairing this thing?
B) Im assuming the answer to 'A' above might be nil, I was looking at a replacement: http://www.aircraftspruce.com/catalog/a ... gtx327.php Suggestions?
C) Im assuming its also possible the transponder is fine, but wiring or encoder could be the issue. When you buy a new transponder such as the 327 linked above, "with harness", that does not including the antenna, cabling, or encoder correct?
D) If replacing the transponder, is it better to go all out and replace the wiring, antenna, and encoder also or if they seem to be working, its best to leave 'em.
Thanks for any insight
