Seair Passenger Sues
http://www.globaltvbc.com/world/Float+p ... story.html
A Beaver has a stall warning system, I have over 4000 hours on them and have never seen one?
Re: Seair Passenger Sues
It's part of the STOL kit and the 5600lb upgross, both of which this plane had.
Great link about the life vests. It's great to see operators implementing TSB recommendations before TC pushes them to.
Here is the link regarding the Seair passenger, as the original article doesn't mention the topic.
http://www.vancouversun.com/news/Surviv ... story.html
[quote="enbt"]It's part of the STOL kit and the 5600lb upgross, both of which this plane had.[/quote]
Thanks, I didn't know that, then its been at least a decade since I flew one.
TMC did not have the STOL kit -- certainly not the Baron kit. I'm guessing the upgross it had was the 5370lb version. For a while in the early and mid 2000s it had the large flow generators on the wing but they had been removed prior to the accident.It's part of the STOL kit and the 5600lb upgross, both of which this plane had.
5500 gross weight kit. Flow generators are turbo beaver 6000 lb
