Blunders in aircraft controls
System Message
The early days of aviation involved rapid advances in aircraft control. The original Wright Flyer used a cradle actuated by slideing ones hips from side to side to control the roll of the aircraft. While good enough to prove the machine could fly, the invention of fat pilots necessitated the need of a more elegant method of control.
The control stick rising vertically in front of the pilot's seat provided an intuitive and simple mechanism for controling the pitch and roll of aircraft. No further changes are known to have been requested by a pilot.
Not to let a good thing be unscrewed with, aircraft designers began designing control wheels that required separate motions for controlling pitch and roll, or sticks that have wheels at the top like boeing jetliners, or the spitfire that had a different motion for each axis of movement. Others use controllers from computer games like the F16 and Airbus mounted to the side so that they do not interfere with the pilot's lunch tray.
Cessna used a proper stick in the center of the floor in the L19, the C188, and maybe others. The new 162 Skycatcher gave Cessna a chance to correct the mistake of the control wheel in previous aircraft. What they did was use a regular yoke control, and saw half of it off so they could call it a control stick.
Messing with the control stick was was one of the great blunders in aircraft design history.
If we can put oil in the engine while we're flying then we have absolutely no problem at all.
- slowstream
Re: Blunders in aircraft controls
Just to point out the obvious ................ this is according to youSystem Message wrote:
Keep in mind that there are many people who have adapted and like the side-stick including me.
If you ever flew a large Consolidated-Vultee product, you would appreciate who came up with the yoke..... and the co-pilot....
Another blunder would be piper installing them in such a matter that they are prone to coming apart mid-flight and not paying for the repair.
- Panama Jack
Well, System Message, I took to learning to fly Weight-Shift Control Aircraft a half-year ago and felt that weight shift provides more than adequate control. Bring it back on!
-President Ronald Reagan
The Chrislea Super Ace had an unusual 'steering wheel' control arrangement which eliminated the conventional rudder bar. The wheel was mounted on a universal joint; turning it applied aileron, moving it vertically applied elevator and sideways the rudder.
http://www.abpic.co.uk/images/images/1004451F.jpg
I can picture this on Boeing's next product. "V1, Rotate. ATTENTION PASSENGERS, EVERYONE RUN TO THE BACK OF THE PLANE!"Panama Jack wrote:Well, System Message, I took to learning to fly Weight-Shift Control Aircraft a half-year ago and felt that weight shift provides more than adequate control. Bring it back on!![]()
I think that would be the German contribution to the next Airbus project.grimey wrote: I can picture this on Boeing's next product. "V1, Rotate. ATTENTION PASSENGERS, EVERYONE RUN TO THE BACK OF THE PLANE!"
http://www.youtube.com/watch?v=eVBPGZEVRH0#t=0m20s
- Siddley Hawker
Yes indeed.If you ever flew a large Consolidated-Vultee product, you would appreciate who came up with the yoke..... and the co-pilot....
