Northern Flyer:Northern Flyer wrote:One of the main reasons to turn it to standby is so that aircraft on short final don't have to put up with TCAS traffic alerts and resolutions when they are concentrating on landing... I realize you said that TCAS I and II systems don't do this but I disagree with you. I spend 90% of my career below 400 feet working fires, and the TCAS audio has to be inhibited or you will go nuts with the the advisories. I have also many times had the aural warnings while on the ground or on short final, in many different aircraft.
I'm a bit perplexed by your comments. The TSO standard for TCAS (C119c) mandates compliance with RTCA/DO-185B, the document that defines the performance standards for TCAS systems. Version 7 of the TCAS performance standards - which has been in effect since at least the year 2000 - provides that the sensitivity level of the TCAS must be attenuated to SL 2 when the aircraft is within 1,000 feet of the ground. At SL 2, no RAs are ever issued. Further, the ground estimation logic within the TCAS system looks at the height of other aircraft above ground (by correlating own ship pressure and radar altitude to the altitude differential of the threat aircraft) whenever your own aircraft is below 1,750 feet, and automatically suppress all alerts (both TA and RA) for other aircraft that are determined to be on the ground.
A full explanation of how this works can be found in a FAA publication (a PDF) that can be downloaded here. See page 21 of that PDF for the sensitivity specification, and pages 29 (last paragraph) and 30 for the ground estimation logic specification.
You made reference to flying around at 400 feet doing forest fire work, and the need to inhibit nuisance alerts at that altitude - is it possible that you might have inadvertently confused the TAWS ("don't hit the ground") system with the TCAS ("don't hit the other plane") system?
I fly aircraft fitted with both TCAS I and TCAS II systems on a regular basis - in fact, part of my job duties includes production test flight of new aircraft to ensure that these TCAS systems work properly. I have never, ever experienced (while in flight) a TA generated in response to an aircraft that is on the ground. I suppose it is possible that certain manufacturers (e.g. Honeywell) might go above and beyond the TSO specifications by flat-out suppressing all alerts when the own ship is below 400 feet AGL (as stated in the Honeywell pilot guide), but for sure, all manufacturers must comply with the specifications set out in the TSO, which are explained in the FAA publication I referenced earlier.
Michael
