Prospect wrote:I got a "yes" call 8 business days after my interview. Apparently I was an outlier considering the long wait time. Not sure why it was so quick.
Ladies and Gentlemen talk to this person and people like him or her. I bet you will find that in most cases they just went in and did it sort of speak. They were just themselves and didn't try to out think anything. Close Prospect?
This is how the system works.
-You go through the process and get scored.
-If you score below the last person in the pool? You get the immediate please try again later.
-If you score within the pool? You take your spot according to your score. That could be at the top, middle or bottom.
-Ground schools are made up of the top scoring applicants in the pool. They are not made up from how long an applicant is in the pool.
-If the pool gets over a specific size the bottom person gets kicked out. This is the late please try again later letter.
-So if you get a quick Ground school? You scored high and went to the front of the pack.
WHEN YOU RUN INTO THESE INDIVIDUALS------TALK TO THEM
If you get PFO'd? Try again. During the last hiring the failure rate on the first attempt was well in excess of 50%. Second attempts were much higher.
