RAIC Wait times
RAIC Wait times
Hey all.
I was chosen for a job on the condition that I get my RAIC card and applied for that today at pass control here in ottawa.
I was just curious if any one knew roughly how long this takes to process. I know it "varies" but an idea is better then none
Thanks in advance.
Thanks in advance.
wrenchturner
Re: RAIC Wait times
I did it about 2 months ago in Ottawa, it only took about 3 weeks or so. Not sure if it makes any difference for new or renewal though, mine was renewal.
Re: RAIC Wait times
I just received mine after waiting nearly 8 months. I hope you have better luck than I.
- fingersmac
Re: RAIC Wait times
My original pass was for Thunder Bay and it took six months. God only knows why it took six months to process.
Re: RAIC Wait times
1 month YWG, and ive heard upwards of 8 months to depends on the person.
Valkyrie_XB70
Re: RAIC Wait times
Your temporary one should be issued within 2 weeks or so, however it will be an escort required pass. Your permanent should be within 4-6 weeks. At least thats how long mine took. When I upgraded from a YWG only to Canada wide it took a week.
Re: RAIC Wait times
Escort Required passes were all changed to be Search Required last year, or so I was told. When I got my Yellow pass, I was one of the first at my airport to not require an escort, only the search. Is that not something done nationwide?
Re: RAIC Wait times
Thanks for all your quick responses. It looks like the start date for the job is some time in Nov so about 6 weeks away. I feel like I have a simple form to do for example never lived outside of Canada nor have I been married ever
Could someone explain to me why someone would get an "escort" pass. My assumption is that they have been approved but they are making the persons permaninte card.
Thanks again
Thanks again
Re: RAIC Wait times
You'll be given an escort-required yellow pass in the interim to use while your info is being verified. It allows you to go on with your job while you're awaiting the clearance. In YWG, the yellow escort-required pass is still being used, not sure what it'll be in Ottawa. A permanent card takes all of 10 minutes to make, but only after the security clearance has been granted.
XcessEnergy
Re: RAIC Wait times
My pass took exactly 1 month, but someone else I worked with said his pass took 8 months. Apparently, it depends if you have ever been outside the country in the last two years, and obviously if you have ever had a brush with the law. But if your history is clean I suspect a month is standard.
Re: RAIC Wait times
I thought all RAIC cards were Canada wide? How do you tell which card you have?Valkyrie_XB70 wrote:Your temporary one should be issued within 2 weeks or so, however it will be an escort required pass. Your permanent should be within 4-6 weeks. At least thats how long mine took. When I upgraded from a YWG only to Canada wide it took a week.
- Snagmaster E
Re: RAIC Wait times
RAIC aircrew, I believe, are Canada wide, but only as a flight crew on a ramp and in a terminal. I don't believe it allows you to access these areas through security checkpoints (like a baggage room door) only if you're escorted (so where a ramp attendant can access through checkpoints, you would have to be with one, just like how gate agents aren't allowed through there by themselves).
A RAIC allows you at the airport you work at. Canada wide red pass (non-aircrew) allow you access to all areas at ALL airports. You have to have a valid reason to obtain this I believe (my company security manager has one to allow her to check out all of our operational airports).
I think. I used to have a Red but now it's aircrew, so I haven't tried to access doors other than crew entrances, so it may work there too.
Edit:
Guess I didn't really answer the question. A RAIC Aircrew states Aircrew and has a red outline of a maple leaf on a white background. A RAIC Non aircrew looks the same, without the aircrew. A red pass is ... well red.
Edit:
Money, wish I had it...
Re: RAIC Wait times
http://laws.justice.gc.ca/eng/regulatio ... ge-13.htmlYYZatcboy wrote:Escort Required passes were all changed to be Search Required last year, or so I was told. When I got my Yellow pass, I was one of the first at my airport to not require an escort, only the search. Is that not something done nationwide?
46.1 A person must not enter or remain in a restricted area unless the person is
(a) a person to whom a restricted area identity card has been issued; or
(b) in possession of a document that is issued or approved by the aerodrome operator in accordance with a security measure as authorization for the person to enter or remain in the restricted area.
46.4 An aerodrome operator must ensure that a person is not allowed to enter or remain in a restricted area unless the person is in possession of
(a) an active restricted area identity card that has been issued to him or her; or
(b) a document that is issued or approved by the aerodrome operator in accordance with a security measure as authorization for the person to enter or remain in the restricted area.
Going to vary airport to airport, no absolute standard. Some places don't have the resources others do.
Re: RAIC Wait times
It gives you access to areas relevant to your work, there are always further restricted places. You're not going to get into the Airport Ops centre, an IPU room or maintenance shop.Snagmaster E wrote:RAIC aircrew, I believe, are Canada wide, but only as a flight crew on a ramp and in a terminal. I don't believe it allows you to access these areas through security checkpoints (like a baggage room door) only if you're escorted (so where a ramp attendant can access through checkpoints, you would have to be with one, just like how gate agents aren't allowed through there by themselves).
Non-Aircrew RAIC's are different at every base. Ours are changing to white.Snagmaster E wrote: Guess I didn't really answer the question. A RAIC Aircrew states Aircrew and has a red outline of a maple leaf on a white background. A RAIC Non aircrew looks the same, without the aircrew. A red pass is ... well red.
Valkyrie_XB70
Re: RAIC Wait times
RAIC is the generic term:
Restricted
Area
Identification
Card
It used to be known as the "red pass", however each airport has their own variety. Winnipeg has changed to a blue pass, Kitchener uses a purple one, Toronto has 3 different colours, whereas the Canada wide is standardized with the maple leaf, and white front.. As stated above, an aircrew pass will state AIRCREW on it, mine states AME. When I go to a different airport I have to check in with their security and they will grant me access to the areas I need to work in. The biggest difference I was told is the RAIC uses more biometric data encoded into the card than the older red pass.
Restricted
Area
Identification
Card
- CL-Skadoo!
Re: RAIC Wait times
Question to tag on to this post...how difficult is it to transfer a raic when you switch flying jobs and remain based at the same airport? Any idea what the process is like? (cyyz)
TopperHarley
Re: RAIC Wait times
CL-Skadoo! wrote:Question to tag on to this post...how difficult is it to transfer a raic when you switch flying jobs and remain based at the same airport? Any idea what the process is like? (cyyz)
If youre staying at the same airport, it's very simple. Make an appointment at the GTAA office and bring a signed copy of the short form from your employer (its valid for 7 days from when they sign it). You should be able to walk out with a new RAIC in hand. I just transfered my YUL RAIC to a YYZ one. I first had to go to YUL to hand in the pass and make sure they deactivated it, then I went to the GTAA office the same day and walked out with a YYZ RAIC.CL-Skadoo! wrote:Question to tag on to this post...how difficult is it to transfer a raic when you switch flying jobs and remain based at the same airport? Any idea what the process is like? (cyyz)
"Never travel faster than your guardian angel can fly." - Mother Theresa
BeechjetYKZ
Re: RAIC Wait times
I called the GTAA pass office today (30 minutes on hold) and they need you to make an appointment for the application (despite having a RAIC on file) AND another one to pick it up. TC needs to reactivate it since I had surrendered it a few months ago. Why I need an appointment I have no idea. I'll spend more time waiting than I will to get the action form processed. I can understand if I am applying for a new clearance with the 5-year history form because they need to do fingerprinting but for a simple handing in of a form why should I need an appointment?
BTW: You get a yellow pass right away and you'll get the full pass once your clearance is reactivated (in my case) or approved (new pass holder). As usual, the GTAA is backlogged for pass appointments (probably because the 4 clerks work for 10 minutes, take a 40 minute break, work for 5 more minutes, go for lunch, work for 5 more minutes, take a break, etc). Can you tell I hate the pass-office. There is no reason I should wait for an hour just to see a clerk for 5 minutes...
Nothing cleans a dirty plane like 100LL!
Re: RAIC Wait times
I luckily got mine in a week or 2 because it was rushed for the Olympics, but I know a guy who is going on 10 months in Vancouver and still hasn't received his.
Tom
PPL
PPL
Re: RAIC Wait times
My introduction to working at the airport is this pass control office at YOW and all I can say is... Are you kidding me.
I've never had a pass before.
I did my applications, fingerprints, pictures ect on Friday and was told have a nice day.
No yellow pass
No time frame
No explanation of the process.
My job starts nov 1, so I think and I'm beyond confused and concerned something Has gone wrong.
Does this seem normal or do I have merit to worry?
Yes I have called them and no one has an answer. I have resorted to calling other airports and am waiting to hear back from them.
No yellow pass
No time frame
Re: RAIC Wait times
Last time i renewed my RAIC in YYZ ( 5 years new security check ) it took about a month. Because the pass i had was going to expire before i got my new one i was given a yellow search/escort required pass. So even though i have had a pass for 14 years and am capt. of the aircraft i had to go through screening every time ( no bypass ) and was not allowed on the ramp or aboard the aircraft by myself, had to be escorted by the f/o or f/a at all times when beyond the passenger boarding area.
Re: RAIC Wait times
yowtsx, you should be notified to pick up your temp pass about a week after your application. I'd definitely keep fishing for info from them. Amazing how no one there has any clue about whats going on.
Re: RAIC Wait times
Curious about an e-mail I have with regards to RAIC pass pick-up. It mentions that it is ready for pick up and to come by the pass office to do so. Currently with a yellow "search required" pass, can I walk in an have it done or do I have to wait in the hour or so long line to do so?
Re: RAIC Wait times
I think you're residential history has a lot to do with it. If you've been out of country, providing supporting documents can sometimes be a bit of a hurdle.
