call sign "PARROT"
Switchfoot
call sign "PARROT"
Post by Switchfoot »
I recently had an opportunity to tour a mobile ATC set-up at a military airfield. The controller was showing us his radar screen and I was glancing at the flights in the area and came across "PARROT" at FL 600. Any military types here who can answer as to what type of aircraft that might be? U 2?
Switchfoot.
oldncold
Re: call sign "PARROT"
Post by oldncold »
likely a f22 raptor in super cruise enroute to "undisclosed location"
Post by █████ »
Beefitarian
Post by Beefitarian »
█████ wrote:███ █████ ████ ███ ███ ██ ████ ██ ████ ████████.
You shouldn't be posting that in the public forum, should you?
kevenv
Post by kevenv »
Switchfoot wrote:I recently had an opportunity to tour a mobile ATC set-up at a military airfield. The controller was showing us his radar screen and I was glancing at the flights in the area and came across "PARROT" at FL 600. Any military types here who can answer as to what type of aircraft that might be? U 2?
Switchfoot.
Was it moving slowly in a tight circle? A Parrot is a computer generated target used to verify the alignment of the radar display. IE: if the "Parrot" is in the correct position -radial & DME (it was always at FL600), I can consider the radar correctly aligned. It stands for Position Adjustable Range Reference Orientation Transponder. We displayed it when I was in the military but it is hidden on my civil screen.
justwork
Post by justwork »
Why is it that most of your posts are blacked out? As is your username and location... I didn't even know that was possible.
daedalusx
Post by daedalusx »
He could tell you. But then he would have to ████ you ....
W0XOF
Post by W0XOF »
Switchfoot.
+1 I can see them on NARDS when I zoom the display out. All at FL600 and share the same code (can't remember off hand). I was on a trip with a tech to one of the radar sites where he explained how they use the Parrot in maintaining the integrity of the Secondary Surveillance Radar. We then went to the Parrot site, looks like a small transmitter tower in line of sight with the radar.
Read you 2 by 2. Too loud and too often!
Darkwing Duck
Post by Darkwing Duck »
Not the coolest military call sign if it was.
ATC - "Parrot234, sqwak ident"
Parrot - "Sqwwwwaaaakkinng."
Changes in Latitudes
I still want to know what this business is about.
I don't have a ████████ clue...
Beefitarian
Appearently I could get into trouble just for quoting it so I'm going to just pretend I never saw it and try to forget the whole thing.
fleet16b
Post by fleet16b »
He He He
you guys are a bunch of █████ freakshows :smt040
Doc
Post by Doc »
It was Jimmy Buffett's Albatross riding a Hell of a thermal!
flyinggreasemonkey
Post by flyinggreasemonkey »
I once took an ATC chick back to my place...she had this ███████ and she █████ with a █████ while ██████████ █████ pineapple██████████ couple of sheep.
Beefitarian
Pineapple? Epic!
Darkwing Duck
flyinggreasemonkey wrote:I once took an ATC chick back to my place...she had this ███████ and she █████ with a █████ while ██████████ █████ pineapple██████████ couple of sheep.
Boy that story changes all the time. Last I heard it was a watermelon and 3 or 4 Tibetan yaks.
Panama Jack
Post by Panama Jack »
You guys are a bunch of Image
-President Ronald Reagan
Panama Jack wrote:You guys are a bunch of Image
Guilty as charged. 8)
