The other problem is trying to understand the controllers when going from English to ,Danish, Norwegian, Dutch, German, Italian, Greek, Portuguese, Aribic, zulu, etc....Oh, I forgot in California ..Ebonics..
Cat
So there you have it. No legal requirments require actual 'IMC' time. You can have an ATPL, and never have seen a cloud while in an aircraft.421.34(4)(d)
75 hours instrument flight time of which a maximum of 25 hours may have been acquired in approved instrument ground trainers and a maximum of 35 hours may have been acquired in helicopters. Instrument ground time shall not be applied toward the total 1500 hour flight time requirement.
"instrument time" means
(amended 2001/03/01; no previous version)
(a) instrument ground time,
(b) actual instrument flight time, or
(c) simulated instrument flight time; (temps aux instruments)
Never heard of VFR-over-the-top?endless wrote:If you're up at FL270 and ontop of a layer basking in the sun and blue sky for your entire enroute portion I still log this as actual. You don't have reference to the ground and therefore can't be legally VFR.
I sympathize, and consider occasionally sufficient self-discipline as "equivalent" for logging purposes. However, these devices are hardly unorthodox (having been used for probably five decades), and their use is mandated for non-IMC IFR flight tests.Cat Driver wrote:Any check pilot who demands that I wear such an unorthodox device will not be flying with me on any check ride.
I don't think you can go VFR OTT above FL180...It must be IFR. Why? Insufficient visual references and traffic separation requirement.fche wrote:Never heard of VFR-over-the-top?endless wrote:If you're up at FL270 and ontop of a layer basking in the sun and blue sky for your entire enroute portion I still log this as actual. You don't have reference to the ground and therefore can't be legally VFR.
I'm not sure if this is true. If you mean this line in the flight test standards:fche wrote: I sympathize, and consider occasionally sufficient self-discipline as "equivalent" for logging purposes. However, these devices are hardly unorthodox (having been used for probably five decades), and their use is mandated for non-IMC IFR flight tests.
It doesn't specifically requiest a hood. By remaining on the instruments can be considered sufficient by some examiners. Although it does differ from examiner to examiner. It'd be quite hard to fly an accurate hold while looking outside, as well stay on any glideslope.The candiate will provide...
(d) an effective means of excluding outside visual reference to simulate instrument flight conditions, while maintaining a safe level of visibility for the examiner or safety pilot.
