Cargojet crew scheduling
CYWG Mike
Post by CYWG Mike »
Hello,
I am hoping some of the Cargojet people on this board can help with a couple questions I have about Cargojet.
When the 757/767 were brought in were any of the pilot positions filled by the 727 crews?
The other question I have is how does it work in regards to how the crews are assigned? Is it done a bidding process? It seems to me that the domestic 767 operations are quite straight forward; one aircraft is in Hamilton while the second one is in Vancouver and then they end up in the opposite city during the week on flights CJT 571 and 572 and then flights 550/551 on the weekend service. With the 757 and CJT 620/621does the same crew start with the flight from Hamilton and then come back to Hamilton or is there a crew change along the way? In regards to the 727 flights I would like to know how they work from a crew standpoint? I won’t type different scenarios that I think they could be I will hope that someone will be able to tell me how it works.
I hope I am making sense. :)
Thanks in advance and I look forward to hearing from you.
Cheers.
CYWG Mike
CYWG Mike
Re: Cargojet crew scheduling
Post by CYWG Mike »
Anyone?
Thanks in advance
Mike
1201checkin
Post by 1201checkin »
why do you want to know ??
Its all done based on bidiing usually some times on how long you can hold your breath for too with out gasping for air if you know what i mean
CYWG Mike
Post by CYWG Mike »
Well the first part about the 767/757 crews I wanted to see if they actually took pilots who were already in the company and upgraded them to the FO on these aircraft.
In regards to the flight bidding I am interested in the way that the works. I am probably not explaining myself very well, I basically wanted to know if you bid on the actually pairing of cities that a particular flight goes to or can you say fly CYHM - CYWG and then chage planes and fly back to CYHM or is it just a straight CYHM-CYWG-CYVR and then the next night fly CYVR-CYWG-CYMX.
Anyways thanks for replying and I hear what you are saying and again thanks for the response.
Mike
