* AvCanada's Home Page * Photo Gallery * Directory * Topsites *Weather *Enter Chat * Media Kit
It is currently Tue Jun 18, 2013 10:44 pm
Who is chatting
Who is chatting
Enter Chat
Post new topic Reply to topic  [ 13 posts ]
Author Message
 Post subject: Compressor washer
PostPosted: Fri Mar 02, 2012 2:53 pm
Offline
Has anyone here built one themselves, or know of plans for one?
Top
 Profile
 Post subject: Re: Compressor washer
PostPosted: Fri Mar 02, 2012 3:57 pm
Offline
Seen some guys use those canisters( the pump type that builds pressure) and adapt the end to get the right flow. Those canisters are usually used for weed killer etc.
Top
 Profile
PostPosted: Fri Mar 02, 2012 4:31 pm
Offline
Tronair makes a great unit for compressor washes.
Top
 Profile
PostPosted: Fri Mar 02, 2012 5:26 pm
Offline
yes, I know about their unit, but for a number of reasons we have to build our own.
We can access the stainless pressure tanks, air cylander and trolly, but the valves, guages etc. for flow control are what we really need to have the plans for.
Top
 Profile
PostPosted: Sun Mar 04, 2012 8:07 pm
Offline
So a power recovery wash cart. I can post a pic of a homemade one to help.Two regulators and two pop cans. Pratt spells out pressures and mix.
Top
 Profile
PostPosted: Tue Mar 06, 2012 10:15 pm
Offline
I just used a bucket of water, a sponge, and some detergent. Look how clean she is! YMMV
Top
 Profile
PostPosted: Fri Mar 09, 2012 5:48 pm
Offline
I'll have a go at this.
You'll need two pressure tanks, one for wash, one for rinse. An air pressure regulator with gauge to pressurize said tanks, and 3 valves, ball valves work best. As well as whatever plumbing you'll need
The regulator is plumbed to both tanks, you can use valves to isolate each tank if you want, but not required.
The oulets of the tanks to the wash nozzle will basically come to a tee. The center of the tee will be the outlet to the wash nozzle and will have one ball valve on it to turn the fluid on/off. The other sides of the tee will come from their respective tanks, each one having their own valve.
Assuming you've only used the 3 valves, ensure they are closed and your tanks sealed. Attach your shop air/nitrogen and adjust the regulator to whatever your manual states. Open the valve from the tank you wish to use (it helps to label them), and when you're ready to wash/rinse, open the center valve to the nozzle.
Best I can do off the top of my head without a picture or cart to look at. I'm sure others here can add to this.
Hope it helps.
Top
 Profile
 Post subject:
PostPosted: Sat Mar 10, 2012 12:32 am
Online
I don't think it's right for you to lie here Niss.
You should have moved the "cleaning rake" before you took the picture.
Top
 Profile
PostPosted: Mon Mar 12, 2012 8:07 am
Offline
groncher..
It helps.. Unfortuantely, we have the same problem...nothing to look at, so the issue is with the pressure guages and hoses, fittings etc. Which is why I was hoping someone might have plans.
We have two very nice stainless tanks, pressure bottle. Just need to make the cart and hook it all up so it works smoothly and at the right volumes and pressures...`
cheers
Top
 Profile
PostPosted: Wed Mar 14, 2012 9:47 pm
Offline
here is a pic of our cart. It might help
Top
 Profile
PostPosted: Wed Mar 14, 2012 10:02 pm
Offline
It looks like the file is too large. I will try and pm it
Top
 Profile
PostPosted: Thu Mar 15, 2012 5:53 pm
Offline
Not sure what engines you're working on. I'm mostly PT6. For what it's worth, the PT6 maintenance manual has a description and schematic for a wash rig and compressor wash ring.
Top
 Profile
PostPosted: Fri Mar 16, 2012 5:33 am
Offline
Yep,PT6 with wash rings.i had to make the example in the manual for one aircraft until a ring was fitted.used copper and ball valve. The cart has two simple air regulators and pop 19 liter canisters.ardrox is the solution.
Top
 Profile
Who is online
Users browsing this forum: Shiny Side Up and 18 guests
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
webmaster@avcanada.ca
AvCanada Topsites List
While the administrators and moderators of this  forum will attempt to remove or edit any generally objectionable material as  quickly as possible, it is impossible to review every message. If you feel a  topic or post is inappropriate email us at support@avcanada.ca .  By reading these forums you acknowledge that  all posts made to these forums express the views and opinions of the author and  not the administrators, moderators or webmaster (except for posts by these  people) and hence will not be held liable. This website is not responsible or liable in any way for any false or misleading messages or job ads placed at our site.
  When you post a message, your IP is logged and may be provided to concerned parties where unethical or illegal  behavior is apparent. All rights reserved.
