Float Plane Rentals?
Is there an outfit in Southern BC that would rent a small Cessna equipped with floats to a low time pilot commercail float rated pilot? Somewhere in the lower mainland or as far north as Kamloops?
Re: Float Plane Rentals?
Fort Langley Air has special rates for March, check it out:
http://www.fortlangleyair.com/
Not sure about the Solo requirements.
Air Hart in Kelowna has a 172XP and 180 on floats. I think they will even rent it out solo. At least they did about 5 years ago.
Ft. Langley Air does solo rentals of it's C180.. FCDQ. The rates are reasonable, they're always friendly and I believe they have good availability.
They do http://www.lakecountryairways.ca/MapleFlag wrote:Is there anyone doing the same in Southern Ontario?
