* AvCanada's Home Page * Photo Gallery * Directory * Topsites *Weather *Enter Chat * Media Kit
It is currently Tue May 21, 2013 4:05 am
Who is chatting
Who is chatting
Enter Chat
Post new topic Reply to topic  [ 69 posts ]  Go to page 1, 2, 3  Next
Author Message
 Post subject: Short Fields
PostPosted: Sat May 05, 2012 2:40 am
Online
So how short is "short" for the purposes of the short field landing and takeoff exercises ?
I have not been able to find any definitive guidance on this issue and so to give new students a starting place quite awhile ago I arbitrarily decided it is 200% of the POH distance. So if the field is less then twice the distance that the POH says you need to take off or land, I tell students to use the short field technique.
What do you guys/gals do ?
Top
 Profile
 Post subject: Re: Short Fields
PostPosted: Sat May 05, 2012 3:12 am
Offline
I am a bit confused by your question.
For the purposes of training, the length of runway should be sufficeint to allow the student to learn and practice the specific techniques to a satisfactory level, without the danger of overrun if things dont go quite as planned.
If you are asking what the definiition of a short runway requiring special technique is, that is much more difficult to answer specifically, as , for example a change in temperature could result in an increase in density altitude that would require a short field take off technique to be used on a runway that normally would not require it if the temperature was lower...If you are trying to add in a fudge factor to compensate for all this, then you are missing the pont of teaching short field take offs. It is much better than trying to teach a number, to teach awareness of things like slope of runway,, density altitude, and judging the runway length from the air for small aircraft. The numbers only game is played in bigger aircraft which dont usually subscribe to attempting short field take off techniques...go or no go decision, and where the numbers can be better relyed upon.
It is also important to have the student understand that they can get into some places that they cannot get out of, and again, sometimes they can get into a place in the cool morning, but if they fill the tanks and try it in the hot afternoon it will work.
What I am trying to say, in my rambling way...is in a small plane, dont teach a student to go to the book. Teach them to recognize the effects of weight , density altitude, and to estimate the runway length from a flyover.. Teach them the technique and let them practice, and then, if possible find a narrow relatively short strip to work from. The last thing you want is a pilot ending up in the trees and saying that the runway was......x times the lenght in the POH, and his instructor said that meant no special take off technique was needed. Teach them the danger of getting behind the power curve after take off...or more correctly reinforce that previous lesson about slow flying.
And while I am rambling, please do not combine short field and obstacle clearance in the same first lessons....It used to drive me to distraction when I did check rides and asked for a short field demonstration, and after take off the student climbed at the best angle of attack speed....there is no need to do that unless there is an obstacle clearance issue, and quite frankly, for a new ppl, they should be taught to avoid situations where they are required to do both...Drain some fuel from the plane...Leave the cooler of beer and fish. Wait until early morning to depart..Dont rely on some basic learned skills to try and eke out maximum performance from a small plane. Teach them to pick a fixed point like a tree, runway marker, dead moose as a no go, and if they are not off the ground or at a certain air speed, get er'stopped.
I say airspeed here, because on very real short field take offs, there is no real go/no go..Once you release the brakes you are going to end up in the air, or off the end of the runway, so your point must be picked to see something like the ASI moving...but again, no private pilot should be attempting those type of take offs until they have some experience.
Top
 Profile
PostPosted: Sat May 05, 2012 3:54 am
Online
TK
One of the problems when you are a very experienced pilot is issues that are blindingly obvious to you are not necessarily understood in a practical way by very low time pilots. Where we can look at a field and do the unconscious WAT calculation based on experience, where does that leave a pilot with no body of experience to draw on ?
My point with the 200 % factor is two fold. First it forces them into the POH to get a best case scenario of what the airplane ought to do and second it gives them a starting point to work from. Going to the book also again starts to give them an appreciation of what temperature, slope and surface does to takeoff and landing distances and becomes the context for the actual practice including visiting some actual short fields.
Anybody who can't do a normal landing into a 200 percent field doesn't have a problem with short fields he/she has a big problem with making safe landings under any conditions.
Finally if you genuinely think I am incapable of understanding and teaching the difference between short field and obstacle clearance techniques then I guess we don't have much to discuss so I will not waste your time responding specifically to your posts.
Top
 Profile
PostPosted: Sat May 05, 2012 4:01 am
Offline
I would say under 3000' for the purpose of light aircraft but it does depend on conditions. 3000' is usually plenty on most surfaces, temperature and runway conditions in a single-engine trainer. But it also can be dicey if you're taking off uphill when it's hot, and of particular concern that isn't mentioned in flight training is the surface condition. Taking off of pavement will probably take about 50% of the length you'll require with a muddy runway, if you even make it off.
Anyway, I enjoyed reading your post as always trey kule, I'm pretty sure some of yours have more information that a couple AFM's I've read, but I'm interested in your thoughts on this part,
What do you use? I've heard a lot of views on it but I'm pretty sure a lot of people have no view on it and just hope for the best. I don't have any formula personally I just look and feel the place out usually and do my thing. But I think I've heard 70% of Vr in 50% of runway a few times before, which sounds appropriate but totally neglects things like obstacles or third stage climb, or airborne first two thirds of runway, etc.
Anyway have specific thoughts on when exactly to reject when not limited by 704 regulations for ASDA or enroute climb numbers?
Top
 Profile
PostPosted: Sat May 05, 2012 11:05 am
Offline
First of all BPf.....my comments with regard to flying at Vx after a short field comment were not directed at you, and, I assume from your response, do not apply. I enjoy your posts, and learn quite a bit from them, as I am hoping to instruct again, when, or maybe if, I ever retire and can still pass a medical and crawl into a plane...There is always the danger, I fear, of thinking my way is the only right way, and your posts sometimes offer a completely different perspective, which gets one to thinking..
Edited: comment removed as an AvCanada member's felt it was an insult and I hurt their feelings. :smt008
Where does that leave a pilot with no body of experience to draw on ? My philosophy of instructing, is to teach them the tools so they can hopefully safely get the experience afterwards. Which is why I focus on things like judging runway length from the air , and remembering to consider field elevation and temperature...The truth is, once people get a license they very very soon quit calculating runway take off distances, or thinking about density altitude formally so it is important that somewhere in the back of their brain they remember they are important. How many PPLs, or even CPS bother doing a weight and balance, fuel plan, use checklists etc, after flying a small plane for a few hours unless someone is forcing them to... For example, I dont ever recall a checklist in any beaver I ever flew, though I suspect if you dug through the old cardboard box in the back that has the grease rags and oil cans, maybe there was one there to make TC happy. That is the reality.
I was fortunate that when I was an instructor there were all sorts of little fields to work out of, and we had the blessing of the FTU , and no fear of the wrath of TC for doing so..It is one of the few things about the good old days that really was good..more oopsies, but the acceptance of some risk at that level, I thought made safer pilots in the long run...I have always wanted to do a comparision between the reduction in FTU accidents and accidents of pilots under a 1000 hours to see if there was a reverse correlation.
Even big runways have markers, marking on the runway, lights etc., so one can fly over and at least get an idea of what 1200 feet (as an example) looks like..Unfortunately many short strips are also narrow so that will skew the perception, but it should give them an idea...Canada is also blessed with the CFS which gives runway length and details..I sometimes think Canadian pilots dont appreciate what a great little book that is, but I dont expect there is to many of us left that remember looking at the side or back of a map to find that little airport diagram.
The problem I have with using numbers in small planes goes something like this.....I have used a "safe" factor of 2x the POH figure...(based on what I am not sure)..I then look at the CFS and the runway length exceeds that requirement, so off I go...And when I arrive over the airport, I notice that there is a big old hole about 1/3 of the way down...in 21st century piloting I would do the "safe" thing and simply divert. And then I would go back to the company and be mad because the CP got mad and said old guy did it...I would then hate the old guy as he was doing something unsafe....and would never realize that the problem was me just using numbers, and that the CP and old guy actually were able to fly over the airport, make a perfectly acceptable decision, that resulted in a safe landing and departure...I would have learned nothing.. And the chances are the next time I would feel "pressured" and attempt something that truely was not safe because I had never learned properly.. and that is not directed at you BPF....just my observations over the recent years.
As to what I use when working short field.. If the strip is long enough to have a plan B ( as opposed to once you have brake release it is fly or crash) I use whatever is available to have a fixed point I simply can determine easily rather than some indefinite point such as 1/3 of the runway. If the ASI is not alive, or is not at 40kts, for example, power off and get on the brakes..Picking the point is a bit of an art, as the faster you go, the more space needed to stop, or at least slow down some before you go off into the pasture. If the runway ends at an 800 cliff, the point is much more conservative then if you are simply going to run into a cow pasture. But we are speaking here of really unnecessary places for a PPL to be getting themselves into, and maybe the factoring of the POH is a good starting point to get experience. As long as the foundation for learning is there, so the picking of a point and determining things like how much runway does it typically take to get airborne after the ASI starts moving are good things to learn, and they can be learned on a big old paved runway without any scenarios.
Understanding when to use the technique is also a major issue, and that makes a bit of a problem is you start using POH+ figures as requiring a short field technique. That may be safe enough for training, but not so much in the future.
Use that length of runway for training, but short field is a short field...
One of the things I notice is that pilots,when being checked out on a real short field will horse the poor old plane into the air with 400 feet of runway remaining. It is rather a too common thing, that seems to result from the fact that no instructor ever told them that if there are no obstacle in front of them they can continue the takeoff roll to a higher speed...and yes yes...I know all about pulling off and flying in ground effect...but that technique has some different considerations.
Top
 Profile
PostPosted: Sun May 06, 2012 5:27 am
Online
Quote:
we both know that until we can do an inverted spin in a Pitts
Boy, you trot that out pretty well every other post now.
I'm fascinated that it bothers you so much that you can't
fly an airplane past 60 degrees of bank.
Remember this picture was taken from the ground, baby.
Something you will never, ever be able to do.
And do remember that if you want a piece of me, stop hiding
on the internet. Show up in person, and take a swing at me.
Top
 Profile
PostPosted: Sat May 12, 2012 2:44 am
Online
TK
I finally got around to picking up this thread again. Re-reading the posts I realize we were talking about different things as I was insufficiently clear in my original post. I was talking about teaching the short field exercise for the first time to ab initio students. You are talking about post CPL students showing up at their first job. There should be a big difference about how you teach short field techniques to someone with 20 hours vs 200 hours.
Students have to have a starting point to inform their thinking. One of my pet peeves is that many FTU's treat the POH as an entirely theoretical document useful only to answer trivia questions on written exams. POH's, especially GAMA format post 1975 ones, have a lot of useful information that taken with appropriate caveats; gives students a starting point to help them make decisions. My admittedly arbitrary 200 % factor is simply some starting guidance in when to use a short field technique vs a normal landing/takeoff technique.
By the time someone is at the CPL level the short/soft/obstacle techniques should IMO be taught almost entirely as an exercise in pilot decision making as the actual flying technique ought to be automatic. Unfortunately and rather sadly this is becoming a lot harder, at least on the West Coast. 10 years ago their was 2 grass field and 2 other larger airports with designated grass landing areas and a great little short gravel strip with obstacles at both ends; all within 5 to 30 mins flying time of each other.
Now all the grass/gravel fields have been paved/closed or are strongly discouraging training flights.
Anyway I reiterate my questions to those folks currently teaching the PPL/CPL. what if any criteria do you tell students to use to determine when a field is "short" ?
Top
 Profile
PostPosted: Sat May 12, 2012 2:56 am
Online
Colonel Sanders wrote:
I have to say I had never considered the "inverted spin method" short field landing technique but if anyone could do it it would be you. :wink:
Top
 Profile
PostPosted: Sat May 12, 2012 10:48 am
Online
Not sure about inverted spins, but I know an instructor that spun
a buck fifty all the way to the ground and somehow survived. Must
have landed on something soft.
Anyways, I doubt he used much runway during that landing.
I doubt anyone here will believe me, but ...
Many, many decades ago, the RCAF used the Tiger Moth biplane
for ab initio training. Then they got rid of it, and threw new students
directly onto the Harvard (shudder). Then, they got the Chipmunk,
which was a big improvement.
Anyways, you simply won't believe the cloud break procedure
in the Tiger Moth. If you got stuck up on stop of a layer, apparently
the safest way to descend through the cloud was in a fully establish
spin. If there was any vertical space below the cloud, you could
recover and scud-run on your merry way home, if you could figure
out where you were.
I doubt anyone here will believe me, but a spin actually puts less
stress on an aircraft than a spiral dive, which is certain to develop
in the cloud.
I know all the straight and level types hate spins with a passion,
but actually the non-accelerated modes (but upright and inverted)
are really quite enjoyable. They're about as exciting as a steep turn.
Top
 Profile
PostPosted: Sun May 13, 2012 1:57 am
Offline
I was instructed that it would be safer to spin a glider out of clouds rather than trying to execute a turn and fly back straight with no gyro instruments. I'd be inclined to agree.
Back to the original topic: I'd be inclined to call any runway where you can do a full stop-and-go at GW and the current DA a "normal" length runway. Even a grossed-out 172 can operate off of 1500 feet without needing any technique besides good piloting, add into 5000 feet of DA and things get a little more interesting.
Afterall weight and DA should be an integral aspect of dicussing take-off techniques. This little aircraft can happily operate off of 1500 feet of grass at sea level. Look what some DA does to it:
http://www.youtube.com/watch?v=daBU3aUq6n0
-Grant
Top
 Profile
PostPosted: Sun May 13, 2012 2:51 am
Online
-Grant
A gross weight sea level takeoff on a 10 C day, zero wind, with an obstacle requires 1570 feet according to the C 172P POH. The POH even with no obstacles landing on a 1500 foot strip, coming to a full stop and then taking off again with no obstacles would be an extremely marginal manoever as the landing ground roll is given as 530 feet and the no obstacle takeoff roll is 860 feet. Remember this is with a Cessna test pilot and a new airplane.
This idea that "I think" 1500 feet is plenty speaks exactly to my point that especially for ab initio training instead of folklore and urban myths maybe we should start with some POH performance data, and then understanding that this is the best possible performance we can expect, apply some pilot decision making to come up with a go/ no go decision. This pilot decision making would of course encompass more then just the book calculation but would also include the other factors that effect operations from short and especially short unpaved runway.
Top
 Profile
PostPosted: Sun May 13, 2012 6:11 am
Offline
Well the clapped-out 172H I learned in was perfectly capable of doing normal take-offs and landings from the 1800 foot airport it was based out of, and on 20C days very near GW.
I'm not seeing where the data in the POH supports thinking of a 2000 foot runway as needing any sort of special technique, I'm not even sure that would apply to a 1200ft runway unless it was hot and you were at GW.
-Grant
Top
 Profile
PostPosted: Sun May 13, 2012 5:15 pm
Offline
Well, I fly a 172M at gross weight all of the time (three adults, two hours of fuel minimum) and there are some days it is pretty close getting out of our 3000' strip because of obstacles at 4000'.
Even on cool days, I need about 1500 feet of ground run. When DA climbs north of 5000 feet I need even more. On a no wind day it gets even worse. If it's really bad, I'll use the 206 instead.
Flaps are a must, because despite what the POH says, ten flaps make a world of difference for clearing obstacles on the 172M. Mixture always leaned as well.
As far as teaching people what a short field is, well, it depends on factors like what I experience above. I don't consider my field a short one, but I would not take off from a shorter one under those conditions. I go in and out of shorter strips all of the time, but I am usually not at gross or having to deal with obstacles.
In my experience, takeoffs are more critical than landings when dealing with short fields--I could get into many places I could never get out of, but it is the landings that often get new pilots worried because they aren't as precise as they would like to be. Also, lots of times after getting a new license is when they like to load up the airplane with family or friends and go bombing around to different airfields. Some people have suggested (and some do) max gross checkouts because a plane fully loaded behaves quite differently than it does at typical training weights. But I suppose that is 'dumbing down' aviation even more....
Top
 Profile
PostPosted: Wed May 16, 2012 6:54 am
Offline
Any time there is any "pucker factor" It's short. If you have 20 hours this may be 2500' in the 172, if you have a couple thousand hours it might be 800'. I've found that it is easier to fly into actual short strips then to fly into simulated ones (pretending the last 8000 feet of pavement don't exist). I think this is largely due to the psychological effects of knowing that if you botch it, it's no big deal. When you are lined up on final on a <1000' strip with no overshoot, you know you have to perform and this feeling helps you perform better.
When I was doing my commercial in the Kootenays the "short" field was Crawford bay, if memory serves me correctly I think it's about 2600, it seemed short at the time because it was grass and had no desirable overshoot. I think it was my first non pavement landing as well. At any rate the point of all this is that obviously if it's beyond the POH it's too short, other then that it depends on the individual.
E
Top
 Profile
PostPosted: Mon May 21, 2012 3:57 am
Offline
Advocating a cloud break in a spin? Did I just read that in the flight training forum?
Seriously, to those of that brought that up you're really cool and I thought a lot of your piloting skills when I read that, but are you guys serial killers? Seriously ask a shrink and get back to me about what disorder a person would have to suffer from to suggest that in a flight training forum.
Top
 Profile
PostPosted: Mon May 21, 2012 4:09 am
Offline
Well, Square, despite the polite and clear way you brought this up, :roll: let me come to the defense of those who posted.
First of all, you are equating a cloud breaking procedure such as done in IFR. This is not how gliders fly. But when you are thermalling up to the base of a cloud you typically have five or six thousand feet between you and the ground.
If you enter cloud, and it happens ,you have two choices on entering the cloud as gliders tend to be VFR machines.. You can try and fly out in the bumpies with a limited panel, and take the chance on getting into a spiral and having the machine come apart, or you can put the stick in your lap and full rudder and let it spin out... It is not particularily dangerous despite what it seems. All the gliders I flew except one had nice spin characteristics.
And yes, when I learned to fly gliders in 1966 as a cadet, this was a procedure taught. Spirals were called graveyard spirals for a reason. A bit of a history lesson for you.
And again, I must empahsize it is not a cloud breaking procedure such as done in an IFR situation.
Nor do I particularily condone flying into a cloud when you are soaring, but no one deserves the kind of nastiness that was in your post .
Top
 Profile
PostPosted: Mon May 21, 2012 4:15 am
Offline
Would it really take so long to just descend in level flight in an unpowered aircraft? Isn't that like the whole reason they go flying? Anyway sorry if I was rude, just doesn't make sense to me going into an uncontrollable descent, just so you can see the ground really soon. It might be too soon no?
Top
 Profile
PostPosted: Mon May 21, 2012 4:39 am
Online
Square: typing this post in is probably a waste of time
because you clearly know it all, and thus have nothing
to learn, but ...
I was talking about a procedure that was recommended
long before you were born. Yes, airplanes were flown
before you started your flight training. Really.
And back then, it was recommended in a no-gyro aircraft
to spin through a cloud layer, rather than spiral through it.
You might think that a spiral dive puts less load on an
aircraft than a spin. Whatever, genius.
As I said, this was a procedure advocated a very long
time ago. Long before your time. But you already knew
that, because you know everything about aviation, right? :roll:
Quote:
sorry if I was rude
You weren't rude. You were in full frontal ignorant attack mode.
Top
 Profile
PostPosted: Mon May 21, 2012 4:46 am
Offline
Post it in a history forum then, these procedures are irrelevant and dangerous to modern-day training and commercial operations. Wake up. This isn't a military glider forum and what you say gets burned into minds of young impressionable pilots and enthusiasts around the country. Stop giving them bad ideas. Three people over the last five years I've trained have crashed by themselves in single-engine aircraft by using shitty ideas no one at the company ever trained them, in fact it was expressly against flight and ground training they received because they heard a COOL IDEA from someone else. I'm tired of fighting against showmanship and irresponsibility in commercial operations and it's this kind of fancy idea that gives them the notion. So be responsible would you, please?
Top
 Profile
PostPosted: Mon May 21, 2012 4:49 am
Online
Whatever. Maybe some day I will be know as much
about aviation as you, and I will be able to fly an airplane
as well as you can.
http://www.youtube.com/watch?v=Fcy4ZhGHHaE
Top
 Profile
PostPosted: Mon May 21, 2012 4:54 am
Offline
A PITTS S1 IS NOT RELEVANT. That is a dragracer hotracing a driving student. Who the hell cares who wins??
Top
 Profile
PostPosted: Mon May 21, 2012 4:57 am
Online
You win, because when you advocate a spiral
through a cloud layer instead of a spin, you
demonstrate superior aviation knowledge.
PS It's not an S1, genius :roll:
Hm.
Top
 Profile
PostPosted: Mon May 21, 2012 5:04 am
Offline
Did I advocate spiral dives? Yes three of them did crash, are you saying it was my fault? If you want the details of the incidents you can call me.
Top
 Profile
PostPosted: Mon May 21, 2012 5:11 am
Online
Sir: You are clearly a superior flight instructor to me.
I am only a class 1 instructor and class 1 aerobatic
instructor that has given thousands of hours of dual
flight instruction - including tailwheel, aerobatic, warbird
and jet type ratings - over the last 20 years, and to
the best of my knowledge, none of my students have
ever dinged an aircraft.
Objectively, as a flight instructor you have a far superior
track record. Your students are all far more skilled than
mine, and fly much more challenging aircraft.
Top
 Profile
PostPosted: Mon May 21, 2012 5:16 am
Offline
Well I'm not competing with you, I would totally suck ass at aerobatics and I've never held a flight instructor rating. I'm sure you're way better at doing those things you listed than I am. But we don't work in the same field. I'm a commercial pilot and I'm just trying to share insights I've learned in that scope of operations.
Top
 Profile
Who is online
Users browsing this forum: Alpha_Bravo_Charlie, alwayswannafly, Bravo Mike, PilotDAR, Pratt X 3, SunbeamTiger and 32 guests
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
webmaster@avcanada.ca
AvCanada Topsites List
While the administrators and moderators of this  forum will attempt to remove or edit any generally objectionable material as  quickly as possible, it is impossible to review every message. If you feel a  topic or post is inappropriate email us at support@avcanada.ca .  By reading these forums you acknowledge that  all posts made to these forums express the views and opinions of the author and  not the administrators, moderators or webmaster (except for posts by these  people) and hence will not be held liable. This website is not responsible or liable in any way for any false or misleading messages or job ads placed at our site.
  When you post a message, your IP is logged and may be provided to concerned parties where unethical or illegal  behavior is apparent. All rights reserved.
