lostaviator wrote: If I have filed an IFR flight plan, I am IFR. Respectfully, if you have filed an IFR flight plan, you intend to do an IFR flight. You are not IFR until you receive a clearance. You could, in fact, file a VFR/IFR composite flight plan, in which case you intend to be VFR initially, and will become IFR at a later time/place. In order to speed up the process, departing VFR with the intention of picking up the IFR clearance airborne, you are VFR. The same applies to an airport with an opperating FSS AAS or RAAS. You can request a VFR departure, especially when there is going to be a big delay due to other IFR traffic. In this case, if the VFR departure is approved, you are VFR and must maintain VFR until you do receive a clearance. My advice to anyone is to not request/accept a VFR departure, unless you are willing to remain VFR for the entire portion of the flight within controlled airspace. In other words, you may be legal to depart VFR with 500' OVC and 3sm vis, but do you really want to fly for 200 miles in that?
lostaviator wrote: Ill air on the side of caution until such time it is address otherwise in the CARS or AIM. Besides which, most airports that are class E control zones, have FSS ARR/DEP frequencies, etc.
Ok, I won't even touch on the atrocious English... There are plenty of airports that are not class E control zones, yet are within (or closely underlying) class E airspace. Heck, if I take off from my neighbour's farm, I will be in class E at 700' AGL -- no FSS available there, though.
Feel free to err on the side of caution; it's a safer way to ensure that you do get a clearance...
As for the OP: if your student takes 15 minutes after engine start to prepare for departure (especially if it isn't the first flight of the day), there is another problem to deal with.... |
