Dealing with engine roughness/loss of power
I recently contributed to a thread on pprune and thought it might be worth importing it here
One of my pet peeves is the fact that flight training treats the engine failure emergency as binary. Engine runs/engine doesn't run. Unfortunately the real world is a bit more complicated. Hence my post
But first a bit of context. What I am talking about is what I teach for the PPL student or low time PPL pilot. Since this group by definition does not have the benefit of a lot of experience a framework of procedures IMO is of significant practical value in helping them deal with abnormal situations.
So first we have to talk about the most likely scenario that a PPL will experience. It is not a sudden total engine failure with no warning, it will most likely be engine roughness and/or a reduction in engine power. The engine will still be running and producing enough power for the aircraft to maintain altitude, but the pilot feels that there is something definitely wrong.
The school I teach part time at flies C 172P's and for this scenario I expect them to go to the emergency checklist where I have added a checklist for engine roughness/Reduction in engine power. I want the student to methodically work through the checklist so that they don't forget anything.
It goes like this
Engine Roughness/Reduction in Engine Power
-Carb heat.........................................Full On for at least 30 sec
-Primer..............................................Full in and locked
-Engine gauges...................................Check
Note 1: if severe carb ice exists engine will initially run very rough until ice has cleared)
Note 2: If high oil temperature or low oil pressure is noted go to that checklist
If problem persists
-Carb heat........................................Cold
-Mixture ...........................................Full rich then lean to max RPM
If problem persists
- Mags............................................Select right and left mag individually
(Note if engine roughness is more pronounced on one mag select the other mag or both, whichever gives smoothest operation)
----------------Land at nearest suitable airport------------------------
If problem persists
- Fuel selector.................................Left for 2 mins
If problem persists............................Right for 2 mins
---------------Land at nearest suitable airport-------------------------
In addition to to this I have emphasized the importance monitoring the engine instruments in flight. Instructors now periodically and without warning cover the oil temp/press gauges and make sure the students know where the needle is actually pointing. (In the green is not a good enough answer ).
With respect to abnormal oil press/temp indications, these can indicate an developing mechanical internal engine failure potentially resulting in a total engine failure. This is the least likely cause of an engine failure but they do happen. The good news is there will almost always be some warning. Any internal misalignment or failure will almost always result in metal rubbing. This will cause a rapid rise in oil temperature with the oil temp gauge pegging at its maximum value. A dramatic drop in oil pressure will quickly follow. Any engine showing these signs should be presumed to be in danger of imminent total failure and appropriate actions to land ASAP should be taken. The only caveat is an open circuit in the oil temp wiring will cause the oil temp needle to peg at the highest temp. However in this case the oil pressure will be normal so it is likely just the gauge. However a landing at the nearest suitable airport would be prudent.
The next level of checks (Again for a C 172P) is a memory "cause check" intended to restore power when the engine fails or is producing so little power that the aircraft will not maintain altitude and with the aircraft more than 1000 feet AGL. If the aircraft is below 1000 feet then no cause check is done and the pilot concentrates on flying the aircraft to a survivable touch down point.
After establishing the gliding attitude and pointing the aircraft at the nearest survivable forced landing area.
Carb heat.......Full on
fuel ..............Both tanks
Mixture .........Full Rich
Mags.............Both/left/right/both
This check can be done in about 5 seconds if practiced. By that I mean every couple of flights you make a point of going through the sequence touching each control to build muscle memory.
If the reason the engine failed was caused by a mistake you made ( eg missing a build up of carb ice, running a tank dry, forgetting to enrichen the mixture and then adding a bunch of throttle) then these simple actions will restore power and instead of potentially wrecking a perfectly serviceable airplane after you smashed it into a field when the engine stopped, you will restore power, and fly away vowing never to do that again. :O
Don't forget that the accident statistic show that up to 80 % of the engine failures are caused by the actions or in actions of the pilot. The Cause check won't save you if you have run out of gas but it will save you from some other mistakes that are not all that hard to make.
Finally I also discuss the high altitude engine failure. This is one where you are cruising along more then 5000 feet above ground and you suffer a failure or gross loss of engine power. After doing the cause check and all the other appropriate actions preparing for the forced landing, assuming you are well placed for the field it may be possible to do some more advanced troubleshooting. A variety of carburetor/fuel injection failures can result in the engine only running at certain throttle or mixture settings. So consider going to mid range throttle setting and starting from full rich and then slowly leaning towards ICO. If that doesn't work go back to full rich and starting from full throttle slowly retard the throttle. Is that doesn't work try giving the engine a shot of prime. If the engine starts and then dies you can get some power back by setting a low throttle setting and continually pumping the primer. The little bit of power you can get may provide a useful stretch to the glide. However I must emphasize that these techniques must not get in the way of flying the aircraft and should be instantly abandoned if you start feeling pressured by trying to trouble shoot and manage the forced approach.
Finally I have presented the checks meant for a C 172P. They apply to most light GA aircraft except for C 172R or S models or other aircraft with fuel injected engines so for these aircraft where the check says carb heat insert "alternate air" and for low wing aircraft like Pipers and Grummans where the check says fuel to both, insert fuel.... change tank and boost pump on.
It goes like this
If problem persists
If problem persists
If problem persists
- Shiny Side Up
Re: Dealing with engine roughness/loss of power
You know, you could have saved yourself some typing and bumped your previous thread.
viewtopic.php?f=3&t=81602
I had totally forgotten I had posted this already...I guess memory is the second thing you loose when you get older
In the 172N an open circuit in the oil temp circuit will result in the gauge reading completely cold.
Thanks for this! And the link to the older thread as well
Kudos for posting this.
Both times I have had "engine troubles" - the issue was partial failure not total failure.
In the first instance I blew the exhaust value on a PA28-180 resulting in horrible backfiring noises and power drop till I got things leaned out and landed at my destination airport 10min ahead instead of the fields I was over.
In the second instance I blew the top off of a cylinder turbo'd continental 360 climbing through 1200ft AGL 3min from my home airport. Aside from losing 20% of my available power, I was unaware I was quietly puking oil overboard and landed with 1.5 quarts remaining.
In both instances, there was a 15%-20% loss of power, but not a total stop. Other than select carb heat on if carb icing is suspected none of the above was covered during my primary training 20yrs ago.
If the circuit is open (ie if powered but with an discontinuity) then the instrument will sense infinite resistance and the needle will peg. Only if the circuit is only going to ground which means the instrument is recieving no power, will the needle will go to zero.cgartly wrote:In the 172N an open circuit in the oil temp circuit will result in the gauge reading completely cold.
The more usual failure is poor wiring connections/ratty wiring. or a failing oil temp thermister which results in random jerky oil temp oil temp needle movements. The actual temp of the oil can't make sudden changes so if the oil temp gauge, say suddenly jumps 30 degrees, then it is the gauge not the engine.
And again oil temp and oil pressure are related. So you can't have very high oil temp without a reduction in oil pressure.
I would disagree with the above. If there is a problem with the oil cooling system then you could very well have high temp with normal pressure.Big Pistons Forever wrote:cgartly wrote:
Personally I can't think of any "problem" with the oil system that would result in a very high actual oil temperature but allow the engine to maintain a normal oil temperature. So what did you have in mind ?old_man wrote:I would disagree with the above. If there is a problem with the oil cooling system then you could very well have high temp with normal pressure.Big Pistons Forever wrote:cgartly wrote:
Personally I can't think of any "problem" with the oil system that would result in a very high actual oil temperature but allow the engine to maintain a normal oil pressure. So what did you have in mind ?old_man wrote:I would disagree with the above. If there is a problem with the oil cooling system then you could very well have high temp with normal pressure.Big Pistons Forever wrote:cgartly wrote:
- Beefitarian
I've had it happen to me once where I accidentally left the baffle plate (or whatever it is called) on the oil cooler when I shouldn't have. It resulted in a very warm temperature. (it's a little cover that goes over the oil cooler when it is really cold out to keep the engine warm. It was really cold out...I really don't know the proper name for it, you must.). This was on a very light piston single.Big Pistons Forever wrote: Personally I can't think of any "problem" with the oil system that would result in a very high actual oil temperature but allow the engine to maintain a normal oil pressure. So what did you have in mind ?
In one or two helicopters I flew if you sat on the ground running long enough the temps (trans, engine) would all start creeping up (even causing the little light to go off) just due to lack of air flow over the various coolers.
Although the above can cause high temp with normal press they are not technically part of the oil 'system' as they are more external factors.
I suppose you could also have a thermostat that fails to open but I think those things are designed to fail open. Some one could have accidentally pinched a line during maintenance to the oil cooler causing reduced flow. (Pretty remote, I admit)
What has happened to me in the past is on one machine I flew it had a fan to blow air over the oil cooler. It failed more than once. This would cause elevated temps with normal pressures.
That's the line I was thinking along when I made my earlier comment.
Just to make sure, are we talking about the same thing?
