Plane crash in Temagami - Labor Day Weekend 2012
Hi there, this past weekend I was involved in a serious plane crash in Temagami, Ontario. My wife, the pilot/owner and I escaped unharmed. I believe the plane was 182 Cessna although I can't verify that. The engine shutoff mid flight and we descended into the forest while trying to make a nearby lake. It was a terrifying ordeal, not something anyone should go through. I just wanted to find out what the procedure is after a plane crash? No one has contacted us regarding the crash, maybe it is still a bit early? Thanks, I've attached some photos I took shortly after we exited the wreckage.
- IMG_0056.JPG (79.46 KiB) Viewed 6916 times
- IMG_0053.JPG (72.81 KiB) Viewed 6916 times
Re: Plane crash in Temagami - Labor Day Weekend 2012
Wow! You are such a lucky guys!
But WHY do you think your pilot hasn't reported it yet? You said, nobody was hurt. That means, the pilot/owner was capable to report this accident immediately. If he doesn't know how to do that, his proficiency and currency turns into an issue to discuss with Transport Canada.
If you still want to help him, follow this link: http://wwwapps.tc.gc.ca/saf-sec-sur/2/I ... x?lang=eng
There's nothing in the CADORS yet. It's a 185, not a 182, but that's not terribly important. Report it as Gogona suggested, you can get more info on the aircraft and it's owners here if you need it. Just type in the registration (c-fwds) in the "mark" field:
http://wwwapps2.tc.gc.ca/Saf-Sec-Sur/2/ ... search.asp
This seems much more serious than the last accident that aircraft was involved in (under a different owner):
Flight #:
Aircraft Category: Aeroplane
Country of Registration: CANADA
Make: CESSNA
Model: A185F
Year Built: 1973
Amateur Built: No
Engine Make:
Engine Model:
Engine Type: Reciprocating
Gear Type:
Phase of Flight: Unknown
Damage: Unknown
Owner: ORILLIA AVIATION LTD.
Operator:
Operator Type: Private
Event Information
Engine malfunction - other
Loss of control - on ground
Detail Information
User Name:
Date: 1998-02-19
Further Action Required: No
O.P.I.:
Narrative: C185 SKYWAGON SUDBURY AVIATION C-FWDS - AFTER LANDING AND DROPPING OFF 2 PAX, THE PILOT HAD DIFFICULTY RESTARTING THE ENGINE BY HAND-SWINGING THE PROP. WHEN THE ENGINE STARTED, THE A/C GOT AWAY FROM THE PILOT AND TAXIED INTO TREES ALONG THE LAKE SHORE. SUBSTANTIAL DAMAGE. OPS IMPACT - UNKNOWN. TIME = 1345Z. ACTION = PAX, PAH, PAP, TSB.
Are you sure the pilot didn't report it? How did you get out of the bush after the crash? Was this a commercial or private flight? (I could look up don't have the time, and surely BizJets will be all over the info)
Needless to say you are lucky you guys escaped unharmed...
Thank you for the comments, I will check with the owner. I'm sure he did if that was protocol, but he did not tell us. We were just going for a scenic trip, it was our first ever flight in a small plane.
After we crashed, we were picked up by the owner of a charter company in Temagami, who flies a Beaver aircraft (cant recall the name). We were picked up on Kokoko lake, just north of Temagami.
Shannon
Shannon
floatpilot46
Such a shame, glad no one was hurt.
Found it.
Cadors Number: 2012O2626
Reporting Region: Ontario
Occurrence Information
Occurrence Type: Accident
Occurrence Date: 2012-09-02
Occurrence Time: 2143 Z
Day Or Night: day-time
Fatalities: 0
Injuries: 0
Canadian Aerodrome ID:
Aerodrome Name:
Occurrence Location: Kokoko Lake
Province: Ontario
Country: CANADA
World Area: North America
Reported By: NAV CANADA
AOR Number: 151793-V1
TSB Class Of Investigation:
TSB Occurrence No:
Aircraft Information
Flight #:
Make: CESSNA
Model: A185F
Year Built: 1973
Amateur Built: No
Engine Make: TELEDYNE CONTINENTAL
Engine Model: IO-520-D
Gear Type: Land & Sea
Phase of Flight: Cruise
Damage: Substantial
Owner: Private
Operator:
Event Information
Collision with terrain
Engine failure
Detail Information
User Name: Donaldson, John
Date: 2012-09-04
Further Action Required: Yes
O.P.I.: System Safety
Narrative: The privately-registered, float-equipped Cessna A-185F aircraft was on a VFR flight from [origin and destination not reported]. NAV CANADA staff at Toronto ACC were advised by J.R.C.C. Trenton staff that the aircraft had crashed short of Kokoko Lake (47º05'38"N 080º01'93"W) due to an engine failure. There were three (3) S.O.B. with no reported injuries. T.S.B. and CACO staff advised.
- Beefitarian
flyinthebug
The pilot did something right! Too bad about the plane, but great news that all walked away. Id say well done to the pilot (at least until we find out why his engine failed)?. Either way though, good job keeping everyone alive in an obviously ugly option for a landing area.
Fly safe.
Fly safe.
Thanks for the comments again. We feel bad the plane is a writeoff. But then we also feel so lucky to have got through this. The pilot definitely made the right decisions once we were in trouble. I think it was a great bit of quick thinking under extreme circumstances, combined with some luck when we dropped into the forest.
...and it was mainly hard wood, very lucky go get a 649.
shoinen, I'm curious, did you pay for this scenic trip? You mentioned the pilot/owner, but not your buddy or old friend which leads me to think that this was a chisel charter. I would suspect if this is the case he is probably trying to keep you as far away from the investigation as possible.
Big trouble for the pilot if you paid for this scenic tour.The privately-registered, float-equipped Cessna A-185F
callander pilot
Same plane, same pilot collided with boat on a rainy, foggy day last year. DOT advised of paid for scenic flights. Might as well have told to my dog. When he flies (not my dog) I watch, seems to be a good pilot but takes chances. With two accidents, might not fly again due to increased insurance rates.
Hi there... thank you for the post but I just want to state that the practise you are suggesting was definitely not the case. Earlier that weekend, we'd checked rates with commercial charter services in the area and, on that day, we'd decided we were comfortable with the risks we were assuming on a private flight over the area. I dont know the industry very well, but I can guess that for a registered charter service there are insurances covered that are built into the fee. For this reason we would vindicate that people understand these risks. Lastly, I must thank with ours lives the local pilots in the area, two of which came to our calls for help (Lakeland Charters - Darryl). To me, this was more important that surviving the whole ordeal, the fact that people dropped everything to assist in this very desparate situation is very inspiring.
Shannon
Shannon
I must also add that the pilot saved our lives by the decisions he took in those critical moments... This cannot be doubted, we are alive today because of this.
- Beefitarian
"Same plane, same pilot collided with boat on a rainy, foggy day last year. DOT advised of paid for scenic flights. Might as well have told to my dog. When he flies (not my dog) I watch, seems to be a good pilot but takes chances. With two accidents, might not fly again due to increased insurance rates."
Actually the boat hit him, an old guy whom had been drinking, hiding behind the windshield of his boat to avoid the weather, said he didn't see the plane, was in a hurry to pick up grandkids at the dock.
I have flown with this pilot many times, probably the most cautious I have flown with, I have never seen him take any "chances". I don't understand where that misinformation came from.
