Question from a N registered pilot.
Can canadian operators get authorization to land below published mins?
just curious
- Rank Moderator
just curious
- Rank Moderator
Re: Question from a N registered pilot.
Yes. Pilots flying for the Canuck equivalent of a part 135, 121, or part 91 company generally work for companies will note in their company operations manual a specification in their Govt Authorization a deviation from the published limits. It specifies the aircraft, airport, and approach considerations, the SOPs to be adopted.
The main catch (and there is a bunch of them!) is that you might legally land, but then not be able to taxi.
Takeoff is a different matter. If the standard takeoff via is say a half mile, you can't take off unless you have completed sim training and a ride in addition to the authorization.
Whether you have the approach authorization or not, if you land a CADOR (occurrence report) is generated. Transport Canada looks to see if your company had the authorization or not. If not, then sadness, paperwork, re-training, and fines are generally in one's future.
whistlerboy02
Yep we can land,
but not always able to taxi legally from the runway to the terminal
Thanks for the replies guys. At yyt the published mins is 2600 rvr, what would your typical corporate operator be able to land with? Also, for the record I throughly enjoy George street
just curious
- Rank Moderator
Wrong part of the country for me. But as I dimly recall it has centreline lighting so 1/4 mile
- Chaxterium
Please correct me if I'm wrong but I believe it depends. Without specific approval from Transport Canada, a commercial operator may not conduct an approach unless the reported visibility is greater than or equal to 3/4 of the published visibility. In the case of a published RVR of 2600 that would be RVR 1600 (or 3/8 mile). If you have a copy of our CAPGEN check out page 16 and you'll see what I'm referring to.
If your company has the specific approval from Transport Canada (we call it an Ops Spec up here incase you aren't familiar with the term) then you can fly the approach if the reported visibility is greater than or equal to half of the published visibility. In your case as just curious mentioned you'd be good to go with 1/4 mile. This is shown on page 18 of the CAPGEN.
Again, if anyone here disagrees please let me know.
Chax
I'm assuming that you're company does not have the Ops Spec so you would be limited to 3/8 mile.Supsup wrote:Thanks for the replies guys. At yyt the published mins is 2600 rvr, what would your typical corporate operator be able to land with
Chax
Then there's the low vis take off...
There are a lot of US corporate Part 91 operators getting pee pee slapped (so I am told).
I used to work corporate (604 POC). We had one CDN a/c and a sister fleet in the US part 91. We all did the same Trg, but because we had a POC, we could put the applicable ops specs on it. If they were part 135, they could have gotten a foreign operator certificate from TC and been good to go. However, there is presently no mechanism to do that with a 91, despite the fact that our whole dept was IS-BAO certified!
Tried to go to TC to get a waiver, they wanted written notice from FAA saying that they were authorized for lower, but FAA wouldn't play ball. Thy stated that they didn't authorize less, they just dont prohibit less (part 91 can depart 0/0 in th US). Ain't bureaucracy great.
End of story, we would have two a/c sitting on ramp in YYT. Canadian departs US waits
Yes Cap'n P8, there has been some mild pee pee slapping. Your story sounds very familiar??? Thanks again everyone for your replies.Cap'n P8 wrote:Then there's the low vis take off...
Are you perhaps one of my former co-workers?
