Vancouver ATC Help!
Yianni Macris
Vancouver ATC Help!
Hello,
I am in need of knowing the phraseology for Vancouver Ground (like the Taxi Code clearances etc.).
Kind Regards,
Yianni Macris
Kind Regards,
Yianni Macris
Diadem
Re: Vancouver ATC Help!
Edited: I should really stay quiet when I don't know the answer.
YVR coded taxi routes, see the attachment.
YVR-taxi-routes.pdf- (274.36 KiB) Downloaded 258 times
Yianni Macris
Yes. I know that the phraseology is common all over Canada. I am looking for the ground phraseology for the coded taxi rout clearances.
An example of a taxi clearance;
Aircraft-Ground ABC ready to taxi
ATC-ABC Runway 08R taxi code route ECHO
Aircraft-Code route ECHO to 08R ABC
No problem just have the code taxi route chart out. Very rarely used however.
Yianni Macris
Thanks!!!!J31 wrote:An example of a taxi clearance;
- Beefitarian
