DA-20 Cold ops.
rob-air
DA-20 Cold ops.
Post by rob-air »
The Katana does not like the cold. Any tricks to keep it warm when flyng ie. best power setting. Are you able to keep it in the green when in cruise at minus 10 and under? Thanks
4Stroke
Re: DA-20 Cold ops.
Post by 4Stroke »
Do you have the winter kit on it? Intake baffles and cover for the rear cowling opening make a huge difference.
akoch
Re: DA-20 Cold ops.
Post by akoch »
I fly the C1 version. At -10 the intake and outflow baffles are required (below -1 I recall). With both installed the oil and CHT stay reliably in the green zone. I take them off once spring comes.
Colibri
Re: DA-20 Cold ops.
Post by Colibri »
Baffles are the way to go. I've got loads of winter hours in them and have never had a problem, even around -20.
burninggoats
Re: DA-20 Cold ops.
Post by burninggoats »
The winter kits work really well even at -20, but be careful because if the temp warms up, or there is warm air aloft, you may have trouble with overheating. Also, if you are doing circuits i'd recommend some power on approach to help keep those temps up.
rob-air
Re: DA-20 Cold ops.
Post by rob-air »
Thank you for your inputs. The winter kit is installed but the engine is hard to keep warm when not in the climb.
akoch
Re: DA-20 Cold ops.
Post by akoch »
Call Diamond support. They answer the phone, and are actually useful and responsive in my experience.
CpnCrunch
Re: DA-20 Cold ops.
Post by CpnCrunch »
It could just be that your oil gauge isn't reading accurately. If you have a meat thermometer with a steel cable you can just insert it into the oil filler tube after a flight to check the temperature.
Re: DA-20 Cold ops.
Post by 2550 »
Thats a great idea, provided you know where the temp for the oil gauge is taken from....is right before the oil cooler pretty standard?
dash8310
Re: DA-20 Cold ops.
Post by dash8310 »
I flew the A1s for more than a year. These have a 80hp engine compared to the C1s at 125hp. With the winter baffle it keeps the the engine within the green arc. Its so effective that if you inadvertently leave it there in spring at or above the temp in the POH (7' if I remember) boy the engine will overheat in a second.
Are you using the correct oil grade ?
Colonel Sanders
Re: DA-20 Cold ops.
Post by Colonel Sanders »
if you inadvertently leave it there in spring ... boy the engine will overheat in a second
Effective winter kits can be a problem when it warms up.
I remember a few years back, on a warm spring day, a
low-time pilot declared an emergency in his 172 - redline
oil temp - and landed at our airport. You guessed it, the
winter kit was still in :wink:
PS IMHO it's not enough to just pull the winter kit when
that happens. When the oil gets fried, I like to change it,
regardless of how many hours are on it, but I guess I'm
"old school".
rob-air
Re: DA-20 Cold ops.
Post by rob-air »
It could be that the temp gage undereads a bit. i will submit the meat idea to my superior.
While not being a real probleme if it undereads in winter it could be a real bummer come springtime if we dont pull the winter kit soon enough. The gage could be 3/4 green but actualy up in the red.
Colonel, I like the way you think. I apply this theory for every machine's engine, transmission and diffs.oil is cheap, replacing or fixing those things is often not. So dont cheap out on the lube.
Thanks again for your inputs
kamikaze
Re: DA-20 Cold ops.
Post by kamikaze »
"So dont cheap out on the lube."
That's what she said!
(Sorry just couldn't let this one by ...)
Colonel Sanders
Re: DA-20 Cold ops.
You're not doing it right :lol:
Expat
Re: DA-20 Cold ops.
Post by Expat »
"old school".
At our airport up north, you could tell the brave pilots who flew in the winter cold. The planes were covered with left over duck tape around the cowl, and the fresh air vents on the wings. Mine was... :smt040
