the stall speed of the wings at 80 degrees of bank is very low indeed
Simplify it and put the ball in the center. With
80 degrees of bank and ZERO G on the meter,
I am not asking the wings to do any work. In
fact, I could fly at zero airspeed and not stall
the wings, because the AOA is zero.
I do this frequently over the top of large inside
or outside loops, when I am ballistic, and I am
not asking the wings to do any work. The
airspeed is zero. The G is zero. The AOA is
zero.
If I'm not careful, I could get stuck up there
all day!
This is not very complicated. The airplanes,
parked in the hangar, are experiencing something
similar (albeit with +1G on the meter). The
airspeed is zero, but the AOA is zero, because
the wings are not holding the airplane up -
the landing gear are. Prove this to yourself -
walk into the hangar - no wind - and turn the
master on. Does the stall warning sound, even
though the airspeed is zero? Of course it doesn't
because you aren't working the wing. You have
no AOA on.
most of the force holding the airplane up in the air is coming from drag and lift off the fuselage
Not with the ball in the center. In fact, there
is no force holding the airplane up in the air
because I am allowing it to fall ballistically.
I had one particularly bad FTU instructor who said a slip is more dangerous on approach because it'll snap over in a spin
That's funny, and sad at the same time. But
it just goes to show you, that this guy had
neither "chalk" nor "stick".
This shows why aerobatics can be so educational,
both from a practical and a theoretical standpoint.
You start to understand how the wing really works.
But I guess a lot of people don't really want to know,
or don't care.
I had just landed a Pitts S-2C at Key West in January
and was getting out when a Southwest "four bars"
walked by an sneered at me about my "vomit machine".
Gee, thanks.
