Small STOL jet ?
Small STOL jet ?
Hi
Question for the expert jet guys around which small jet can get in and out of 3000ft rwy or less ??
Thx
Thx
Re: Small STOL jet ?
I've done it in CJ3 and CJ4's (CJ4 being better than the CJ3), but you you want to run your numbers carefully for the conditions, 100% bare and dry. Also has to be operated privately to legally do 3000ft.
The PC-24 has just been announced and is suppose to have STOL performance but I've seen no numbers on it.
Just ran the numbers through Ultra-Nav on our Citation 560 Ultra, and it'll do 3,000' at 25c and 500' field elevation, but your max t/o weight is 15,081 (about 1,200 lbs shy of max gross t/o weight), which means you'll lose about an hour's worth of fuel. That will still get you 2 1/2 - 3 hours of range depending on passenger load, but it's a consideration.
Landing distance under the same conditions at max gross landing weight (15,300 lbs) is 2,956'. Any moisture on the runway and it goes up to 4,337'. If there's 0.5" of water on the runway it goes up to 5,219'.
As the previous poster mentioned, the runway has to be bare and dry and the aircraft can only be operated under POC rules.
How about 2200' x 40'
At 20 seconds you'll see the landing.
here's the departure;
http://skyvector.com/airport/2NC0/Mountain-Air-Airport
http://www.youtube.com/watch?v=jLDhGdjL2gI
http://www.youtube.com/watch?v=Aqa14cA8AkU
OK, so it has a bit of a grade to it...
Wow, that was cool - the departure awesome.
Just checked it out on google maps; Click Here nice place to play golf!!
Bizjet,
You might wanna buy a small mansion on the hillside too.
What a piece of heaven.
http://www.mountainaircc.com/experience ... /index.php
goingmach_1
I fly a Global Express XRS and I can land or depart on 25C day and fly 3500 nm with 6 passengers. Thats assuming I loose an engine at V1.Egres wrote:Hi
Thx
Cough Syrup
