Twin down at Courtenay Airpark
AJV
Post by AJV »
Light twin off the end of the runway into the bushes, no one hurt.
AJV
Re: Twin down at Courtenay Airpark
Post by AJV »
how do you post pics on here?
Shiny Side Up
Post by Shiny Side Up »
AJV
Post by AJV »
I think I got it
AJV
Post by AJV »
one more
Shiny Side Up
Airplane's home is in CYRP, registered to "Touch n' Go Aviation" according to the registry database.
CpnCrunch
Post by CpnCrunch »
Seems a bit short of a runway to be landing a 310 on...I guess they were stopping there to save 10c on avgas. Anyway, glad nobody was hurt - could have been worse.
Post by ahramin »
Wet runway.
AirFrame
Post by AirFrame »
Can't see the second prop, but if it's as intact as the first prop, then neither engine was running when it stopped... Either that or it stopped against something and the props never touched ground. TWO overhauls would be expensive.
GUMPS
Post by GUMPS »
Shiny Side Up wrote:Airplane's home is in CYRP, registered to "Touch n' Go Aviation" according to the registry database.
The joke's already there....
170 to xray
Post by 170 to xray »
Post by ahramin »
Maybe it sold and that's the new owner off the end.
AirFrame
Post by AirFrame »
Change the ad to say "Bush pilots look here!"
crazy_aviator
Post by crazy_aviator »
Touch and No Go aviation ? :wink:
Redneck_pilot86
Post by Redneck_pilot86 »
AirFrame wrote:Can't see the second prop, but if it's as intact as the first prop, then neither engine was running when it stopped... Either that or it stopped against something and the props never touched ground. TWO overhauls would be expensive.
Judging by all the leaves and crud on the aircraft in the pic of the left engine, it was running when it went into the brush...
Rookie50
Post by Rookie50 »
Ouch. Both props and engines pretty low time. Double Ouch actually.
J31
Post by J31 »
CpnCrunch wrote:Seems a bit short of a runway to be landing a 310 on...I guess they were stopping there to save 10c on avgas. Anyway, glad nobody was hurt - could have been worse.
1800 feet of wet asphalt in a C310R? Hmmm...a bit of a challenge.
HighT5
Post by HighT5 »
Is that one of Seneca's old 310s from the 80s?
CFR
Post by CFR »
HighT5 wrote:Is that one of Seneca's old 310s from the 80s?
The registry shows it as being imported in 2009.
godsrcrazy
Post by godsrcrazy »
Manufactured in 1979 according to the registry.
Dash-Ate
Post by Dash-Ate »
170 to xray wrote:http://www.controller.com/listingsdetai ... 265349.htm
May have to adjust the price. :oops:
But that'll buff right out. :rolleyes:
HighT5
Post by HighT5 »
All their planes had KW_ registrations I believe because Ken Wilson sold them the planes.
Not a big deal, just curious.
Colonel Sanders
Post by Colonel Sanders »
With
1) VG's (essential, at least for me) and
2) no obstacles on approach and
3) light weight
I'd try it :wink:
AirFrame
Post by AirFrame »
Colonel Sanders wrote:2) no obstacles on approach and
Biggest possible obstacle on approach at Courtenay is a tall person on the walking path that runs across the end of the runway. Or maybe the waist-high fence beside him, that starts about a foot below runway grade. You can make a rather flat approach.
The owner and I looked at taking the company Cessna 340 into this airport. We decided against it as getting in was doable but the departure was too tight.
