Nanchang CJ-6A gear-up landing at Oliver Airport BC [video]
FlySigi
Post by FlySigi »
Nanchang CJ-6A (C-FTQW) landed with the gear-up during the Western Warbirds Association (WWA) meeting at the Oliver Airport (CAU3) in BC Canada [September 07, 2013].
Doc
Re: Nanchang CJ-6A gear-up landing at Oliver Airport BC [vid
Post by Doc »
Just how far up your ass does your head have to be, to pull something like that off? Seriously, WTF? How can you have the kind of commitment, time and money to own something like that, and not give a rat's ass about your flying. Okay, shovel the usual, politically correct crap about contributing factors, human factors and all that warm and fuzzy BS in my direction. I can take it. That guy is the consummate MORON!!
Post by sky's the limit »
Sweet landing.... minus the "wheels" bit. Details. :wink:
cncpc
Post by cncpc »
There is a possibility that the gear wouldn't come down, in which case good job. Not sure if the engine was caught or stopped dead on first blade strike.
If it was intentional, probably could have done without sandpapering those flap trailing edges.
Likely a high Biggles Factor around there.
Colonel Sanders
Post by Colonel Sanders »
I guess that's one technique to get stopped on a 10,000 foot runway?
:wink:
Good job.
If it was my plane and it was a gear problem, I would have headed to Penticton only a few minutes to the north rather than bellying in at Oliver.
The only advantage of going in there is that's where the warbird shop is (or was) and perhaps not getting a CADORS...
Do you see him hitting the rudder at the end? WTF? Better to go straight off into the toolies than sideways into the sod!
xsbank
Post by xsbank »
He shut the engine off before it touched - it must have been intentional.
Beefitarian
Post by Beefitarian »
It was very considerate of him to clear the runway for everyone else.
xsbank wrote:He shut the engine off before it touched - it must have been intentional.
I don't think the prop would stop that quickly if it were intentionally shut down. it would windmill. And if he intentionally shut it down it was at about 1 millimeter above the runway.
Nwtflier
Post by Nwtflier »
Not saying that this didn't happen, but does anyone else think it looks awfully animated as it starts to scrape and come even with the camera guy?
Seriously?
No, but somebody had to say it and I figured it might as well be me. :D
AirFrame
Post by AirFrame »
iflyforpie wrote:Do you see him hitting the rudder at the end? WTF? Better to go straight off into the toolies than sideways into the sod!
Maybe he thought he wouldn't make it to the end and didn't want to leave the runway blocked... It was a busy weekend with a formation clinic going on.
Doc wrote:Just how far up your ass does your head have to be, to pull something like that off?
Never forgotten anything on *your* checklist, eh? Got lucky that you weren't in a retract at the time?
What surprises me is the apparent number of people standing near the runway watching/filming, and yet nobody has a handheld to shout "gear!" on it.
Post by North Shore »
I wonder if it was intentional - why, otherwise, did the engine stop before touchdown?
Beefitarian
I watched it'a couple more times. It looks like one of the blades hit the runway, stopped the engine then turned the prop back slightly, to the position it is in in the still picture at the end.
First time it definitely looked like it was shut down in that position to keep the blades clear.
slowstream
Post by slowstream »
Once again, many people quick to jump to judgement without looking
My perspective from the video was that he shut the engine down just before touchdown which from a very limited point of assessment leads one to believe that it was indeed intentional.
If indeed that was the situation, it was well done and executed
Beefitarian
I just watched it yet again, it does shut down just before the prop strikes. It's only 15 seconds between the start of the video where the plane is short final and the point where the prop blade drags.
Unless he had that adrenaline slow motion it probably seemed even faster at the controls.
beaverbob
Post by beaverbob »
Watch in large screen on u-tube and use your pause. The engine was completely stopped before the prop touched the ground. Then one blade touched off vertical and then the blades rotated around as the weight settled onto it. This engine has not likely been damaged. Notice that the nose gear is out of its well. Shouldn't the wheel be out of sight with closed doors if selected up?
Bob
Beefitarian
Nanchang? Sounds Chinese. You're not suggesting something built in China could have a gear failure are you Bob?
Nearly everything is built there now, I thought that was because of the known high quality.
The prop hit the ground running. Two reasons... either it was shut down and windmilling, or it hit with power. You can hear the blades hitting the pavement, which has a bit of lag because of the speed of sound... and you can see the bent tips on all three blades. Watch it in 1080p and it is pretty clear.
Nanchang gear is partially exposed when retracted.
