Just curious if anyone can shed some light on this.
Thanks!
Same as the 100s...loopa wrote:I was just wondering, what's the reason for the spoilers being deployed just before take off on the Q400? The first time I noticed it I wanted to jump on the radio and let the flight crew know their spoilers were left up![]()
Thanks!
For the 100 it's just the design. Once the power levers are advanced the spoilers drop and they work with the ailerons for roll control. If the switch is not selected to flight and the power levers are advanced the spoilers will arm and deploy themselves then drop.loopa wrote:Oh ok thanks whiteguy!
Would you by chance happen to know the actual reason why armed means they deploy before takeoff?
I imagine there are way too many warning messages that go off should the Ground Spoilers not stow for takeoff, I just can't logically make out why they would be deployed before such an important phase of flight.
No, the reason is that BA did not have in place an AOM procedure. The real issue is the lack of an energized #1 Hydraulic system, ergo no brakes. The trials have been completed with FlyBe and in 300 days of tests (75,000 cycles) there has been insignificant tire and landing gear wear. The no.2 engine is started and the STBY HYD pump is energized, thereby providing hydraulic brake pressure.Beach 200 wrote:You can taxi a Q400 with one in feather but no operator will do it. Simple reason is cost. Typical fuel savings with one in feather on the Dash 8 100 and 300 are good. Even better on the Q400, but due to the added torque and strain on the nose gear, the cost of repair and maintenance out weighs the fuel savings substantially on the Q. So hence why it won't be done!
aileron wrote:No, the reason is that BA did not have in place an AOM procedure. The real issue is the lack of an energized #1 Hydraulic system, ergo no brakes. The trials have been completed with FlyBe and in 300 days of tests (75,000 cycles) there has been insignificant tire and landing gear wear. The no.2 engine is started and the STBY HYD pump is energized, thereby providing hydraulic brake pressure.Beach 200 wrote:You can taxi a Q400 with one in feather but no operator will do it. Simple reason is cost. Typical fuel savings with one in feather on the Dash 8 100 and 300 are good. Even better on the Q400, but due to the added torque and strain on the nose gear, the cost of repair and maintenance out weighs the fuel savings substantially on the Q. So hence why it won't be done!
The issues that have cropped up is: Not selecting Autofeather after the no.1 engine is started, prior to T/O, and Not selecting or deselecting the STBY HYD pump at the gate (leaving or arriving respectively).
Overall they have saved 40lbs of fuel per sector. Huge savings for a fleet...
Around 40.2KBig Pistons Forever wrote:what is a typical OEW ?
