Superior Airways / Severn Enterprise operation from late 1960's to 1974.
Sioux Lookout carried out a lot of the company float repairs. Aircraft that
were based in Pickle Lake, Round Lake, and Big Trout Lake came into Sioux
for most float repairs. The odd aircraft from Armstrong also flew into Sioux,
but that did not happed very often. With so many aircraft operating on floats
during the summer months, the repair ramp was kept busy.
There was no hangar in Sioux Lookout. All the repairs were done on the shore
of the lake on a wooden ramp that we pulled the aircraft up on. The maintenance
shop was approx. 50 feet in front of the ramp so repairs were no problem at all.
The shop was equipped to handle any repair that came up.
Usually if one of the aircraft was in from Pickle, Round, or Big Trout Lake, a 50 or
a 100 hour inspection would be carried out at the same time.
Attached is a photo taken in late August or early September 1970 in Sioux Lookout.
Beaver CF-MXR flew in from Pickle Lake for a float repair. The belly panel below
the forward door has been removed. I suspect the oil cooler is being replaced or
repaired. The belly area behind the cooler looks a bit dirty from an oil leak.
There are some other aircraft in the photo as well.
The bright red Cessna 185 is CF-YNS and was operated by a mining company.
The aircraft at the next dock over all belong to the original Slate Falls Airways.
The aircraft are Beech 18 CF-CSN. Cessna 180 CF-JDB. Norseman CF-HQD.
