Web or kiosk check-in not working on standby
777LR
Post by 777LR »
Hi guys,
First of all, thank you for the reciprocal jumpseat!
Every time I try to check-in online or at the kiosk I get this message: ''We’re sorry we could not finish your transaction at this time. Please see a WestJet agent at Guest assistance on arrival at the airport to complete check-in.''
Is this normal?
Thanks!
MCB
Re: Web or kiosk check-in not working on standby
Post by MCB »
All of the times I've jump seated with westjet, I've received this message. I'm pretty sure it's to verify company ID with an actual agent.
Not too big of a deal; thanks for the jumpseat!
777LR
Post by 777LR »
Most of the time I have no bags to check-in. If I was able to check-in online/kiosk I wouldn't have to bother the agents and the WestJet guests. I think it would be easier to just show your RAIC as you board...
Everyone wins. Thoughts?
Jack In The Box
Post by Jack In The Box »
WJ doesn't allow you to use kiosk when js'ing
Ace Cdn
Post by Ace Cdn »
it is not just jumpseating you cannot checkin online or on the kiosk on any kind of pass unless you are an actual
WestJet employee....seems kinda dumb as it would alleviate a lot of problems and less lines and work for the agents.
Bede
Post by Bede »
I believe it is a coding issue when you book by phone. I had this happen a couple times (I'm an employee) and I asked a CSA about it. It the person puts the wrong code on the reservation it makes you talk to a person at the desk.
Return to “WestJet”
