More interesting press releases / Links
Satellite Company Inmarsat Says Its Data Could Help Find Malaysia Airliner
http://nation.foxnews.com/2014/03/21/sa ... a-airliner
Chris McLaughlin, Senior Vice President of the British satellite communications company, Inmarsat, joined Megyn Kelly on the Kelly File to discuss the mysterious disappearance of Malaysia Airlines Flight 370.
Inmarsat has estimated that the missing plane took a westerly path, rather than a northeast path at the time of its disappearance.
In the company's first American television interview, McLaughlin said that Inmarsat was "absolutely certain" that its technology was "seeing the readings from this aircraft", referring to the Boeing 777 in question.
"Signals had continued to be received for a number of hours after it had lost contact with the radar and with the ACARS management system," McLaughlin said.
Then
MH370 hunt widens as commercial jets join search
Read more:
http://www.smh.com.au/national/mh370-hu ... z2wfJ7EbX4
An analysis of satellite pings shows that Malaysian Airline System Bhd. Flight 370 may have cruised steadily across the ocean after diverting from its scheduled route to Beijing from Kuala Lumpur. That assessment gave the clearest idea yet on how investigators pinpointed a search zone.
(Note - says May have - Nice to see something conservative)
Engineers at Inmarsat Plc, whose satellite picked up the pings, plotted seven positions for the Boeing Co. 777-200ER on March 8, Chris McLaughlin, a company spokesman, said in an interview. The plane flew steadily away from the satellite over the equator while pinging, McLaughlin said. Malaysia needs to verify that information, Azharuddin Abdul Rahman, the chief of the nation's civil aviation, said in Kuala Lumpur.
The data helped investigators conclude that the most logical path was progressively either north or south. U.S. investigators have focused the search to the south, where Australia is leading the ocean-search efforts.
When officials estimated the plane was flying at or near its cruising speed of more than 800 kilometres per hour, it produced a probable path the engineers were "very confident" about, McLaughlin said.
Arc Estimate
The engineers don't know the plane's track for certain because the satellite pings can only be used to estimate an arc along the Earth's surface where it would have been, he said.
The engineers at Inmarsat were able to validate their estimates of the plane's location by matching its position at 1:07 a.m., when it sent a burst of data through its Aircraft Communications and Reporting System, McLaughlin said. That final transmission on Acars included a GPS position that was used to calibrate the other estimates, he said.
The Inmarsat analysis is consistent with details suggesting that, at least initially, the path was commanded from the cockpit, John Cox, president of Washington-based Safety Operating Systems, said in an interview. It still doesn't answer what may have happened to the plane and what led it to fly for so long, he said.
Interview with Chris McLaughlin
http://vimeo.com/32770047 ( re yacht racing)
Another Item
Hunt for Jet Switches to Visual Search as Radar Empty
http://www.bloomberg.com/news/2014-03-2 ... mates.html
The plane flew steadily away from the satellite over the equator while pinging, McLaughlin said. Malaysia needs to verify that information, Azharuddin Abdul Rahman, the chief of the nation’s civil aviation, said in Kuala Lumpur.
(Malaysia needs to verify???)
Malaysia Airlines Flight MH370 Would Have Been Found If Communications Box Had $10 Upgrade
http://www.ibtimes.co.uk/malaysia-airli ... de-1441174
The Inmarsat Classic Aero is installed in 90% of the world's commercial jets, and it is this little box which sent out the pings of information.
The box has been in use "for decades" and sends information to the Inmarsat-3 and Inmarsat-4 satellites stationed in the geosynchronous belt 22,300 miles above Earth.
An upgrade to Classic Aero is currently going through testing, called SwiftBroadband. The new product will give 512Kbps of broadband to flights, which would be enough to send text messages, make phone calls, and crucially, to stream information into the cloud.
Flight 370: Satellite firm picked south on day two
(0ne of the better articles)
http://www.nzherald.co.nz/nz/news/artic ... d=11224111
Vital "pings" that continued to be sent to a satellite were first accessed by technical experts the day after the Malaysia Airlines plane disappeared from civilian radar off the country's northeast coast on Saturday, March 8.
By Monday the team at the satellite's owners, Inmarsat, were "fairly certain" the Boeing 777 had most likely flown for around another seven hours.
The British firm sent its analysis to a Swiss aviation IT provider the next day, which is said to have then informed Malaysian officials the day after that - on Wednesday, March 12.
"Our engineers looked at the time between the handshakes, and they realised that the object wasn't stationary under a satellite but moving away from it," Inmarsat senior vice-president Chris McLaughlin told the Washington Post.
http://washpost.bloomberg.com/Story?doc ... T6EVUTMVBJ
(Note; - "May have")
According to the Wall Street Journal, the company became concerned the data was not being acted upon and approached UK security authorities for assistance. Malaysia Airlines was also said to have told the Swiss firm to use the UK's Air Accidents Investigations Branch as a "primary conduit".
It remains unclear why the Malaysian investigators took several days to act on the information, and change the focus of the search.
Critical Data Was Delayed in Search for Missing Malaysia Airlines Flight
Investigators Are Still Working to Recover From the Delay
http://online.wsj.com/news/articles/SB1 ... 0167673144
The information was relayed to Malaysian officials by Wednesday, March 12, the people said. Inmarsat also shared the same information with British security and air-safety officials on Wednesday, according to two of the people, who were briefed on the investigation
Malaysia's government, concerned about corroborating the data and dealing with internal disagreements about how much information to release, didn't publicly acknowledge Inmarsat's information until March 15,
The disclosures about how the information made its way into the investigation underline how international efforts to find the plane have been repeatedly marred by distrust among the countries involved, confusion in many of Malaysia's public statements, and criticism from many countries that has led some to suspend or change their search efforts in frustration.
The lost days and wasted resources have threatened to impede the investigation, according to some officials involved with the probe.
Another government official said Malaysia was cautious about revealing and acting on the data because "we don't want to upset anybody with round after round of confusing information."
China's government has complained about Malaysia's response, with Premier Li Keqiang on Monday urging Mr. Najib to provide "more detailed information in its possession, including third-party information, in a timely, accurate and comprehensive manner," according to China's official Xinhua news agency.
Mr. McLaughlin said the data was shared the following day with SITA, which in turn shared it with Malaysian officials.
One person said Malaysia chose not to disclose what it considered raw data, preferring to check it first with international partners.
It wasn't clear how U.S. officials obtained the initial Inmarsat data, which they analyzed and helped translate into maps. Regardless, people briefed on the probe agree it took longer than expected for the information to spread from engineers and technical experts who cranked out the first version of the data to policy makers and then back down to officials directing specific elements of the searches.
This article
http://online.wsj.com/news/articles/SB1 ... 0167673144 )
is about the best one I've seen.
If you take a look at "the Arc" the various scenarios of how the flight "turned around"
you see that "the arc" does not look like a straight line.
If you look at the map of the Australian search area, it appears to assume that
(a) The 777 flew on the same heading
(b) ran out of fuel
and that appears, to determine their search area
with adjustment for wind and current.
It looks impressive.
But still raises of why they have a curved line rather than a straight line
if it was on the same heading?
Anyone got any ideas?
Now here is a simulator checking out 45,000 Ft
Plane Crash MH370 Latest News Shwing A Test Flight The theory
https://www.youtube.com/watch?v=2UHzHNmNX3c
Excellent video...
Another one showing the RADAR on that night...
https://www.youtube.com/watch?v=9D9Nnxt0D_I MH370 is in red...
This shows that the flight was being HAND FLOWN over Malaysian
Take a look at 2:26 it appears to be a Military Jet....!
Can anyone verify this video? it makes a variety of claims that are worth looking at...
FAA warned Boeing 777s had problems (March 13, 2014)
https://www.youtube.com/watch?v=sxFisHZMef0
