United Express (opr by Trans States) runway overrun in YOW
Go Guns
Re: United Express (opr by Trans States) runway overrun in Y
Post by Go Guns »
spend millions on putting shops and bars into an airport terminal and not spend a cent on improving operational facilities
While I agree to your line of thought, it's not relevant to this incident.
Liquid Charlie
Post by Liquid Charlie »
-- I did mention grooved runway :smt040
ACTPA :kriz:
swordfish
Post by swordfish »
Liquid Charlie wrote:
Ottawa is not busy enough nor is the weather often poor enough to require a CAT II.
that has to be one of the silliest replies i have ever read and I must say typical canadian aviation thinking -- spend millions on putting shops and bars into an airport terminal and not spend a cent on improving operational facilities -- like a grooved runway and a cat 2 landing -- seems that places like Europe figure it's good policy and airports far less busy that Ottawa have it -- I'm sure wpg has no more "bad"wx than ottawa -- go figure -- only in canader -- silly
+1
In Europe almost every village, town, and city has an ILS and most of the larger cities are set up with Cat IIIb facilities. After the ILS is installed, the associated ground infrastructure is the least expensive part of it. Tho it will take NavCanada 2 years to publish the plate...
linecrew
Post by linecrew »
The airport has never had grooved runways since they were built back in the 50's and you'd be hard pressed to find incidents of aircraft sliding off (outside of winter ops) except in the last handful of years.
Are some modern aircraft like the early model ERJs not able to handle this type of runway surface? Is it the calibre of crews flying in there? I just don't get how this has 'suddenly' become a problem.
CpnCrunch
Post by CpnCrunch »
It seems odd to select maximum thrust for 7 seconds at 5 feet AGL. Shouldn't they have either just let the aircraft settle onto the runway, or else fully committed to a go-around?
flyinhigh
Post by flyinhigh »
Lack of experience is the reason here. 2 reasons that stand out are;
1. In a storm with high winds they selected full flap coming through 1000'. Now your changing configuration in deteriorating weather conditions. Can anyone say unstable approach already.
2. Max reverse selected while aircraft is in the air. (Selected max reverse at 5' agl for 7 seconds), sry you hit reverse while in the air....If you wanna do this do a go around, obviously your already worried.
av8ts
Post by av8ts »
flyinhigh wrote:Lack of experience is the reason here. 2 reasons that stand out are;
I think that was max thrust not max reverse thrust
CpnCrunch
Post by CpnCrunch »
Yes, and the report says the aircraft wasn't equipped with reverse thrust (and that was a factor in the overrun).
Donald
Post by Donald »
07/25 is in fact grooved, it was done after it was re-paved recently.
And it has made a tremendous difference on rainy days.
linecrew
Post by linecrew »
Yeah...they grooved it because the *same company* ran an exact same type of aircraft off the end of Runway 07 in 2010: http://www.tsb.gc.ca/eng/medias-media/c ... 130613.asp
I still question how this is now suddenly considered a huge safety enhancement when, up until just recently, aircraft operated safely on these runways without the aid of grooving for several decades.
