rudder wrote:I know that ACPA has already been reminded that AC has the right to park the 190's without replacement (if no layoffs), so it is clear that an attempt is being made at examining the possibility of placing the 190's at an Express carrier in exchange for other enhancements at AC (such as converting options on the 737 in to firm deliveries).
Rudder,
If the 190 remains in the fleet fewer 737's will be ordered. Your rational doesn't add up.
http://aircanada.mediaroom.com/index.php?item=727
Air Canada continues to evaluate the potential replacement of its Embraer E190 fleet with more cost efficient, larger narrowbody aircraft that are better suited to its current and future network strategy. Consistent with this strategy, the agreement with Boeing provides for Boeing to purchase up to 20 of the 45 Embraer E190 aircraft currently in Air Canada's fleet. The E190 aircraft exiting the fleet will be initially replaced with larger narrowbody leased aircraft until the airline takes delivery of the Boeing 737 MAX aircraft. The company will be reviewing various options over the next six months for the remaining 25 Embraer E190 aircraft including continuing to operate them or replacing them with a yet to be determined number of aircraft in the 100 to 150 seat range.
If the 190's can't be dumped. They will be operated. If they are operated they won't be replaced with larger narrow bodies either. But this is AC least favourable option. The preferred option is to dump all the 190's and revert to just 737's.
If the 190 continues to operate outside mainline as you suggest, there will be job losses.
And you think ACPA would agree to this? Give away a 100 seat aircraft?
You see I think despite all the growth talk everyone is starting to realize it is ASM growth. Not jobs. And most recently we are learning we are overstaffed.
Being in the bottom 300 you can probably understand my concern.
Even if by some miracle Air Canada did convince ACPA to relinquish the 190 your fooling yourself if you think AC will let you do it on your current terms. If it happens it will be used as bait. Carrot and the stick. Just like the Eagle situation. Personally I don't think that is good for anyone and embarrassing if ACPA participated once again in driving down tier 2 pay and working conditions.
I have asked on this forum before on this subject. How low are you willing to go to get the 190? Because ultimately that is what this will end up being about. If not now when your CPA comes up for renewal. Anything that ACPA relinquishes will eventually go to the lowest bidder. We would be crazy to willingly participate.
WJ will just respond in kind with Encore. This needs to stop. Not accelerate.
