The last major accident in Canada was First Air 6560 in Resolute, and the TSB put out an interim report about six months after it happened. If they haven't said anything about this specific accident, maybe it's because they're still running tests to try to figure out what happened. Would you be satisfied if they announced that they were having a press conference, and at the press conference an investigator came out, cleared his throat, and said "We still don't know what caused the accident"? Do you want a quick answer, or a correct one?jpilot77 wrote:+1
Time after time the US investigative body gives out preliminary reports, for the most part you don't hear a peep out of Canada's for years. If Asiana had happened in Vancouver as opposed to SF we still wouldn't have any idea what happened.
Bearskin Metro 3 CYRL accident - Speculation thread
Re: Bearskin Metro 3 CYRL accident - Speculation thread
Translation is not a time consuming process. From what I understand the time consuming process is the time for comment given to involved parties. In this case it would be the operator, aircraft manufacturer, engine manufacturer, NavCanada, insurance company. If anyone disputes what's in the draft report it has to go back for editing or potentially further investigation.
Preliminary reports are put out in the event that there is an immediate safety concern that affects others. If the probability of recurrence is high you can be certain action would be taken. Granted quick release of information helps provide closure for the victim's families, it largely serves the purposes of media interests and rubber neckers. I'm a rubber necker like everyone else, but I understand it's important to get the correct and full information instead of quickly released, incomplete and potentially unverified information. A full report will be released in due time, have patience!
I have been reading many posts on this subject and since it is a speculation thread, it appears most of the the discussion centers on either a botched missed approach or the props hanging on the start locks, which for an engine in operation is highly unlikely. One area no one has mentioned is the possibility of a malfunction of the underspeed governor. I had a Garrett/Honeywell OIL (Operational Information Letter) describing what happens when the drive for the underspeed governor fails. Basicaly, this is what I understand. In normal forward flight, the power levers are forward of flight idle therefore the main fuel control unit supplies more fuel than the underspeed governor and therefore is the more dominant control. The underspeed governor is not shut off, it simply does not supply enough fuel to be of any significance until engine RPM drops below the speed set by the speed levers, usually with the power levers aft of flight idle. But if the governor looses it drive shaft, the underspeed governor will now attempt to "regain speed" but with the failed drive, it cannot so it will continue to increase fuel flow, totally uncontrolled until either the engine stop and feather control is pulled or the engine spits it's pieces out the tail pipe. I read an accident report where a Junkstream crashed in North Carolina when the underspeed governor increased engine power to beyond maximum and the one man show captain reacted to "dead foot, dead engine" and feathered the normally operating engine, lost control in coud and spiraled out, killing everyone on board. This is the reason the PF always holds the engine stop and feather control during engine start and why some Company (as opposed to the AFM) checklists/SOP's have a blurb about uncommanded torque increase not responding to power lever movement. At a Metro operators conference a few years ago, Honeywell discussed this problem and has come up with a fix but I do not know if it is a manditory fix.
Although a totally different failure, the same sort of thing could possibly happen to a PT 6. Uncommanded torque increase not responding to power lever movement. In most training scenerios, everyone is trained to handle an engne failing to zero power but a turboprop engine could fail the opposite way, an uncommanded and uncontrolled increase in power for a very short time. Just my opinion.
The really annoying thing about Canadian accident reports is, even if they know the cause with absolute certainty within 48 hours, it'll still take 18 months for them to produce a report.
Illya
Illya
Oxi wrote:Accident report is usually out after a year no?
Has TC given any statements about the investigation yet? It has been over a year and seems like they should have a little more info by now. Is there somewhere specific that I could view info like that on their website?Oxi wrote:Accident report is usually out after a year no?
http://www.tsb.gc.ca/eng/enquetes-inves ... 3c0150.aspCollidingwiththesky wrote:Is there somewhere specific that I could view info like that on their website?
The link above goes to the investigation website for this specific accident. However you won't find any significant information posted since around the time of the accident. If you want details try asking someone from Bearskin.
Good idea. Much appreciated!
Why is the TSB still dragging their collective asses on this one?
Illya
Illya
How do you know it's the TSB and not one of the parties involved who are allowed to comment?Illya Kuryakin wrote:Why is the TSB still dragging their collective asses on this one?
Illya
KK7 wrote:How do you know it's the TSB and not one of the parties involved who are allowed to comment?Illya Kuryakin wrote:Why is the TSB still dragging their collective asses on this one?
Illya
I'll bite. How long does it take to "comment"?
Sanitizing it, or covering up?
Illya
I read the CBC report of the TSB report. It leaves me with more questions than answers.
They were on final?
You can arrive 1000' short of the runway, and it might still only be a "hard landing"....
They were on final?
At an aircraft level, the nature of the malfunction would be loss of power on one side, so fly the plane first, and feather the prop if you have time?"The crew was unable to identify the nature of the engine malfunction, preventing them from taking timely action to control the aircraft," the report says.
Hate to sound flippant, but we waited how long for such wisdom? No Shiite Sherlock!! I've had the odd engine go south. On final? Power, control, land. I find TSB a reports way to full of irrelevant history, and for the most part devoid of the "what happened" and "why it happened" in favour of telling us about the pilot's time, medical etc., history. No contributing factors here.
I still have no idea why this crew, on this night, were unsuccessful in bringing this flight to a safe ending.
Illya
Illya
Well...some people can understand what they read and some can't. And if you can't figure out why the TSB does it like this then you are beyond help. Note that the TSB, the airline and the engine manufacturer have been providing information as required to people who require it in a timely manner. Not just a bunch of knee-jerk recommendations.I still have no idea why this crew, on this night, were unsuccessful in bringing this flight to a safe ending.
Illya
I think the TSB did an excellent job here and I appreciate the work they do.
Maybe you should read the actual report, not a media report, of a report.PilotDAR wrote:I read the CBC report of the TSB report. It leaves me with more questions than answers.
I'm assuming your not familiar with the TPE331 and its systems...
500' AGL, something goes wrong, how do you feather something instantly that has more signs saying its fine than not....
And Doc, when you have 4 out of 5 gauges telling you the engine is AOK, how do you conclude in seconds (since it was less than a minute from failure to trees, and less than that from things going south), that you need to shut that engine down?
It's always easy to be an expert when your sitting in a comfy chair with all the information, not so easy when its at night and your fighting for your life...
A TPE331 engine failure with NTS (Negative Torque Sensing) is very easy to deal with. However if it is still running and at 0% torque you are now dealing with a lot of drag, so much that you will lose control in short order unless the "Stop and Feather" is pulled.
The NTS will increase blade angle if it senses negative torque (-4% torque) in the case where the engine fails and spools down. In this case the engine was still running and driving the prop to fine pitch trying to increase N1 RPM to the commanded level so no NTS. You must follow the drill and "Stop and Feather" the engine. Flying the airplane will not be enough with massive drag on one side.
No disrespect to these guys as I am sure they were competent Metro pilots. They may not have understood the necessity of shutting down a running engine that was not producing torque. As noted above it would been very hard to to analyze what was going on that night.
It has been a lot of years since I did any training in the Metro but I seem to remember that we never got close to 0% torque during simulated engine failures. If the trainee was slow getting the "Stop and Feather" drill done the airplane would soon be departing controlled flight thus the instructor never let it get too far.
These guys had their hands full and most likely would have landed fine had they pulled the "Stop and Feather" knob.
I too think the TSB did a very thorough investigation into this crash.
Hopefully the message to others is to know your machine as not all procedures work for all aircraft.
+1Maynard wrote:Maybe you should read the actual report, not a media report, of a report.PilotDAR wrote:I read the CBC report of the TSB report. It leaves me with more questions than answers.
It would have been helpful to see a transcript of the CVR and the data curves from the FDR, to figure out whether they were aware of the airspeed loss, and to explain the power reductions tens of seconds before the crash.
The report doesn't show the airspeed graph, which is too bad. That table that they gave is not enough. I wonder what the speed was at the first power reduction and what was the actual reason for the power reduction. The airplane rolled because the airspeed was low. Was the reduction in power a contributing factor to the airspeed loss or was the propeller drag the factor that caused it? I remember from flight training that once you reduce the power on the good engine with the dead engine windmilling the airspeed drops very quickly.
This was probably the worst engine failure situation one could have. Propeller was at the lowest pitch and the spinning energy was delivered by the engine, the propeller was not windmilling, it was being spun at 96% at low pitch.
What happened to the Mayday 10 minutes out that TSB initially reported?
Um, yaw? Dead foot, dead engine a new concept for some of you I guess? A sudden yaw sends me to a shut down if there are no other indications. But, what would I know? You should ask Doc. He'd know.
Illya
PS. I flew Metros for two years. Flight Safety trained. You?
This is the part that has me concerned. Why all the crap? re-configuring so many times? Even TSB said in the report the crew may have been confused in the steps required as the raised and then lowered the gear.....like they were trying to do everything at once.The Bearskin Airlines SOPs for a non-precision engine-out approach requires the crew to change (re-configure) the aircraft flap and gear positions 3 times during the final stages of the approach (Appendix B). Frequent configuration changes over a short distance or period of time can lead to confusion as to the configuration state of the aircraft.Footnote 16
The point of all the re-configuration is to reduce the drag. Gear is a source of very significant drag on the Metro, so the point is to clean the aircraft up. I was taught to retract the gear in case of levelling off at the MDA for sigle engine circling in the Metro. I do not know if I would have retracted the gear in this case. Anytime there is an issue with the engine, the spinning propeller should be the first concern, it has the potential to create many times more drag than any gear.boeingboy wrote:This is the part that has me concerned. Why all the crap? re-configuring so many times? Even TSB said in the report the crew may have been confused in the steps required as the raised and then lowered the gear.....like they were trying to do everything at once.The Bearskin Airlines SOPs for a non-precision engine-out approach requires the crew to change (re-configure) the aircraft flap and gear positions 3 times during the final stages of the approach (Appendix B). Frequent configuration changes over a short distance or period of time can lead to confusion as to the configuration state of the aircraft.Footnote 16
Good point ... the TSB report doesn't even mention pilot error in the findings as such; doesn't that seem unusual? _Should_ they have been able to identify the nature ... etc.?Illya Kuryakin wrote:Um, yaw? Dead foot, dead engine a new concept for some of you I guess?
3.1.3. The crew were unable to identify the nature of the engine malfunction, which prevented them from taking timely and appropriate action to control the aircraft.
WHAT?? It's max power, drag check, identify, verify, feather!! Reconfigure the flap and gear three times????? On an approach????? WHY?? On approach, if it suddenly yaws, apply dashboard power. If it yaws even more, feather the engine. You're on approach. If the gear is down, and the aircraft is flyable, leave the gear down. If it's not, retract and continue until it's safe to extend it. Blind adherence to this SOP will kill you. It well may have.boeingboy wrote:This is the part that has me concerned. Why all the crap? re-configuring so many times? Even TSB said in the report the crew may have been confused in the steps required as the raised and then lowered the gear.....like they were trying to do everything at once.The Bearskin Airlines SOPs for a non-precision engine-out approach requires the crew to change (re-configure) the aircraft flap and gear positions 3 times during the final stages of the approach (Appendix B). Frequent configuration changes over a short distance or period of time can lead to confusion as to the configuration state of the aircraft.Footnote 16
Illya
