Funny Email...
Pilot_adam
Funny Email...
I got this email today, i think it is funny so i thought maybe u guys will like it ...
After every flight, Quantas Airline pilots fill out a form, called
a "gripe sheet," which tells mechanics about problems with the
aircraft. The mechanics correct the problems; document their repairs
on the form, and then pilots review the gripe sheets before the next
flight. Never let it be said that ground crews lack a sense of humor.
>Here are some actual maintenance complaints submitted by
Quantas' pilots (marked with a P) and the solutions recorded
(marked with an S) by maintenance engineers.
>By the way, Quantas is the only major airline that has
never had an accident. Enjoy!
>P: Left inside main tire almost needs replacement.
>S: Almost replaced left inside main tire.
> P: Test flight OK, except auto-land very rough.
>S: Auto-land not installed on this aircraft.
>P: Something loose in cockpit.
>S: Something tightened in cockpit.
>P: Dead bugs on windshield.
>S: Live bugs on back-order.
>P: Autopilot in altitude-hold mode produces a 200 feet
per minute descent.
>S: Cannot reproduce problem on ground.
>P: Evidence of leak on right main landing gear.
>S: Evidence removed.
>P: DME volume unbelievably loud.
>S: DME volume set to more believable level.
>P: Friction locks cause throttle levers to stick.
> S: That's what they're for.
>P: IFF inoperative.
>S: IFF always inoperative in OFF mode.
>P: Suspected crack in windshield.
>S: Suspect you're right.
>P: Number 3 engine missing.
>S: Engine found on right wing after brief search.
>P: Aircraft handles funny. (I love this one!)
>S: Aircraft warned to straighten up, fly right, and be
serious.
>P: Target radar hums.
>S: Reprogrammed target radar with lyrics.
>P: Mouse in cockpit.
>S: Cat installed.
>And the best one for last...
>P. Noise coming from under instrument panel. Sounds
like a midget pounding on something with a hammer.
>S: Took hammer away from midget
per minute descent.
>P: IFF inoperative.
serious.
>S: Cat installed.
ADAM DO YOU FLY AT PENINSULAIR?
"FLY THE AIRPLANE"!
http://www.youtube.com/hazatude
Pilot_adam
Why haven't you PM'd me for access to the Peninsulair forums?
"FLY THE AIRPLANE"!
logicaldisaster
wha happen
