Behchoko Crash NWT??
Just heard on the local news regarding emergency services and a plane in the Behchoko area. Anyone have more info?
Re: Behchoko Crash NWT??
Just reported on local radio that it was a forced landing on Great Slave Lake. Pilot and all passengers are ok.
From CBC website: http://www.cbc.ca/news/canada/north/air ... -1.2841903
Yellowknife RCMP and Behchoko RCMP are currently responding to a report of a downed aircraft near the Boundary Creek area northwest of Yellowknife, a news release says.
Emergency resources are being deployed and additional resources are being prepared to assist with the response for any required needs.
A military spokesman told the Canadian Press that a small passenger plane with seven people on board made a forced landing in bad weather.
The spokesperson said the Air Tindi Cessna 208 Caravan declared an emergency when its engine quit after leaving Yellowknife.
However, Nahendeh MLA Kevin Menicoche says he spoke with RCMP and learned it was a scheduled flight that left Fort Simpson this morning at 8 a.m.
According to the military, the plane managed to land but officials didn't know if anyone was injured.
The military said a Royal Canadian Air Force C-130 Hercules aircraft with search-and-rescue technicians on board was en route to the area from Winnipeg.
Other aircraft were trying to take off from Yellowknife to join the search, but were being hampered by bad weather.
Weather conditions are not good in the capital this morning. It's -19 C with freezing rain.
Buffalo Airways says it's holding some flights because of bad weather conditions.
RatherBeFlying
Kudos to the pilot. Freezing rain is always bad news and especially hard on 'vans.
midwingcrisis
How do you go 205 kts TAS on 32 gal/hr without turbos!
Hmmmm. Maybe they shouldn't have been out there in the first place.RatherBeFlying wrote:Kudos to the pilot. Freezing rain is always bad news and especially hard on 'vans.
checkremarks
Severe Icing reported by Tower and a Cessna Caravan = uh ohmatrix wrote:Hmmmm. Maybe they shouldn't have been out there in the first place.RatherBeFlying wrote:Kudos to the pilot. Freezing rain is always bad news and especially hard on 'vans.
"There are no traffic jams along the extra mile"
"Why don't you knock it off with all them negative waves"
midwingcrisis
I did not hear any PIREPS of severe icing. Tower relayed "significant" ...moderate. Anyone know if this particular flight was on an IFR Flt Plan?
- Redneck_pilot86
What time does this sched leave Simpson? I just had a look at the actual weather for yzf, and 13-14z doesn't look too bad. (The TAF isn't very nice, but we've all seen TAFs that are way off in left field). How does Tindi dispatch these flights?
linecrew
"The spokesperson said the Air Tindi Cessna 208 Caravan declared an emergency when its engine quit after leaving Yellowknife."
I don't fly Caravans but would icing even have been a factor here?
esp803
Theoretically severe icing could cause an engine failure, I expect that the airplane would come out of the sky well before the engine stopped. If it was a genuine engine failure I'm curious as to the cause. It's been a few years since I was at Caravan sim, but I do remember going over every single instance of an engine failure in the Van, I think there were only one or two that were not preventable.linecrew wrote:I don't fly Caravans but would icing even have been a factor here?
E
- Redneck_pilot86
Opening the separator too late could do it, if ice had accumulated on the door and then is jarred loose and into the turbine. I imagine in severe icing the time between needing it open and being too late would be relatively short.
esp803
I've come to the conclusion I'd rather have the sep closed and the extra power when in ice, then open to save engine failure.... although at that point it's probably not going to end well either way.
E
E
midwingcrisis
NOTE: Source Not Verified
SPECI CYZF 201453Z 10011KT 2SM -FZDZ -SN BR FEW008 OVC013
M11/M12 A2963 RMK SF1ST7 SLP055=
SPECI CYZF 201424Z 09011KT 6SM -FZDZ -SN FEW008 OVC012 M10/M12
A2964 RMK SF1ST8 SF TR SLP058=
METAR CYZF 201400Z 10012KT 12SM -SN OVC012 M10/M12 A2965
RMK SC8 SLP060=
METAR CYZF 201300Z 10011KT 15SM -SN OVC012 M10/M12 A2967
RMK SC8 SLP068=
TAF AMD CYZF 201444Z 2014/2112 09012KT P6SM -SN OVC012
TEMPO 2014/2017 2SM -FZDZ -SN OVC008 FM201700 09012KT
5SM -SN OVC012
TEMPO 2017/2024 2SM -SN OVC006
PROB30 2017/2022 1SM -SHSN OVC004 FM210000 08012KT 6SM
-SN SCT008 BKN020 FM210600 06010KT P6SM BKN025 RMK NXT
FCST BY 201800Z=
TAF CYZF 201142Z 2012/2112 12015KT P6SM -SN OVC010
TEMPO 2012/2015 3SM -SN BKN008 FM201500 12012G22KT 3SM
-SN OVC008
PROB30 2015/2024 1SM -SN OVC004 FM210000 08012KT 6SM -SN
SCT008 BKN020 FM210600 06010KT P6SM BKN025 RMK NXT FCST
BY 201800Z=
RMK SC8 SLP060=
RMK SC8 SLP068=
5SM -SN OVC012
FCST BY 201800Z=
-SN OVC008
BY 201800Z=
midwingcrisis
Anyone else listen to the ATC tape? He declared a mayday stating he was having control issues. Never heard anything about an engine failure.
From what I could hear, he was on his way back into YZF, he had encountered severe icing at 8000 and was having trouble maintaining altitude. Nothing about engine issues that I heard.HuD 91gt wrote:Anyone else listen to the ATC tape? He declared a mayday stating he was having control issues. Never heard anything about an engine failure.
goldeneagle
Here is a source that logs historical data from the wire. the link should fetch the history in question.midwingcrisis wrote:NOTE: Source Not Verified
http://www.ogimet.com/display_metars2.p ... &send=send
History there agrees with your post on a first glance.
Looks to me like the TAF was amended to include the freezing drizzle, after this happened. The CADOR has a time of 1420, and the taf is amended at 1442. Prior to the incident, tafs and metars all mention snow, I see no mention of 'freezing anything'.
Illya Kuryakin
If see even HINT of freezing precipitation, and I'm flying a Caravan......im not flying that Caravan, that day. It's that time of year. Learn to say, no. Learn the one hundred eighty degree turn. Be safe.
Illya
Illya
Barrie, North Bay, Pelee Island, Winnipeg...
If I was about to blast off in a Caravan after being given the PIREP the tower controller issued, I'd be reciting those places in my mind, and then to my manager if given any flak for waiting it out...
He sounded rather calm and got all aboard down and intact. The outcome could have been a lot less pleasant, hindsight is a bugger so I say well done!
- Redneck_pilot86
Back when I lived in Fort Simpson, the Tindi sched came into YFS in the evening and overnighted there before returning to Yellowknife in the morning. Have the changed this, or was the flight already a half day late, possibly putting more percieved pressure on the pilot?
How far into the clip does the pertinent stuff start?
midwingcrisis wrote:Kudos? http://archive-server.liveatc.net/cyzf/ ... -1400Z.mp3
midwingcrisis
YZF tower was closed when DA223 departed. Audio @ 17:23 is start of transmission inbound back to YZF
