Engine fire as seen from inside the passenger cabin
teacher
Post by teacher »
https://eresonatemedia.com/
https://bambaits.ca/
Meecka
Re: Engine fire as seen from inside the passenger cabin
Post by Meecka »
Ummm.... Did they not teach this crew what the fire handle in the cockpit was for.
Ypilot
Post by Ypilot »
Looks like tailpipe fire.
Meatservo
Post by Meatservo »
In other news: Dog bites man
Post by bizjets101 »
What kinda dog ????
AvHearld
By Simon Hradecky, created Thursday, Feb 5th 2015 20:00Z, last updated Thursday, Feb 5th 2015 20:00Z
A VivaColombia Airbus A320-200, registration HK-5051 performing flight 5Z-8023 from Bogota to Medellin (Colombia) with 160 people on board, was climbing out of Bogota's runway 13R when the right hand engine (CFM56) emitted a loud bang and streaks of flame prompting the crew to stop the climb at 13,000 feet, shut the engine down and return to Bogota for a safe landing on runway 13L about 20 minutes after departure.
An observer on the ground reported it looked like the engine ingested a bird when it emitted streaks of flame and a loud bang.
The airline confirmed a failure of the right hand engine. The flight was cancelled, the passengers were rebooked onto other flights.
Post by ahramin »
Meeka the first priority is to fly the plane :). The fire handle can wait.
PositiveRate27
Post by PositiveRate27 »
Not sure about jet engines, but if the fire monitoring system is anything like a turno prop It's likely the fire handle wouldnt light up if they injested a bird...
fanspeed
Post by fanspeed »
Bogota, at night...let it burn and make thrust until at a safe altitude!
Nark
Post by Nark »
Positiverate27
The A320 has a system exactly like the Ejet. There is an A and B loop that has inert gasses, which when heated sends a signal to the cockpit indicating a fire. There are 3 location, the Fan section, nacelle and core.
The turboprop and helicopters I've flown have the same photosensor light (system), which detects IR light, not heat.
In some cases, it's possible to trigger the fire handle because of reflected sun light and rain.
Semper Fidelis
teacher
Post by teacher »
fanspeed wrote:Bogota, at night...let it burn and make thrust until at a safe altitude!
AGREED!! At 8000'+ field elevation better burn for a little while longer and get altitude than hit the cumulus granite!
Oh..... I thought is was because of all of the Cartels.... :smt066 :smt068
