GyvAir wrote:The summary in the original post doesn't state how the crossfeed came to be open, or if the crew checked the position of it.
I don't remember at all what the linkage between the control and the valve looks like on any of the PA31s. Given the age of all of these airframes though, it wouldn't surprise me at all if some kind of wear, stiffness or other deterioration of the system or markings contributed to the error.
Its a turn handle in a detent shroud. Has to be lifted up to be turned to crossfeed. I imagine it was made that way because its in a prime position to be swept by a foot as your getting in (bottom of the pedestal). I've never seen one move without deliberate action in other words.
It pretty common to have a cross feed check on a Navajo checklist. Where I used to fly, we would turn it on, activate one of the electric boost pumps, and verify that both sides of the fuel pressure gauge increased, turn crossfeed off and check that the pressure boost was now only on the side with the pump active. Perhaps SOP was the same and they forgot to turn it off. Only a guess.
The crappy thing about the Ho is if the the gauges are off, there is no good way to check fuel level due to the shape of the bladder tanks. Dipstick wouldn't show dick if you were below 3/4 full on the inboards, and about 5/8 full on the outs. Why I hated the super poor gauges on those things. Give me a C206 anyday... The gauges are still crap but at least you can check physically with a stick.
As for the imbalance, I would say it would be noticeable. Granted as another pointed out, the inboards not so much as the outs. Fly with that type of imbalance in the outboards and you would be at 1/4-1/2 of the aileron trim from center. BTDT when I ran the fuel dry at an airport and had to ferry 30nm to fill up properly. I always filled the inboards first due to POH limitations on turns and TO/Landing so I've never had that issue with the ins...
I used to run tons of scheds on the Ho. Six (normal) people and reasonable baggage would take you right to gross on a VG equipped example. I can't say without exact numbers in the case at hand, but it would have been really close either way. The only way we got seven on was if it was almost all females or a child was in the mix.
Glad this situation had a safe ending though! That is all that counts. Live to learn.
"...flying airplanes is really not all that difficult so it attracts some of the most mentally challenged people in society." - . .
"Baby, stick out your can... 'cause I'm the garbageman"
