Get the gist of it thanx TC guy.TC Guy wrote: When you get at PPL (or CPL/ATPL) it allows you to fly any of the following types of airplanes:
"ALL SINGLE PILOT NON-HIGH PERFORMANCE, SINGLE AND MULTI-ENGINE LAND AEROPLANES
GROUP 1 INSTRUMENT RATING VALID TO 2007/05/01"
etc.
That means that I can do the following:
a) fly any single or multi engine land aeroplane that fits the above discription VFR
b) fly any single or multi engine land aeroplane that fits the above discription IFR (because the instrument rating is Group 1)
Therefore:
You Group 1 Instrument Rating is valid also for groups 2 and 3 (group 2 is also valid for group 3 but not group 1).
Does this answer your questions?
-Guy
Just to be a bit specific here, if I'm doing the flight test for PPL/CPL on a C152, and I want to fly a C172 I don't need to have a type endorsement on the 172...is that what it means (dunno if the 172 comes under complex A/c...say the Skyhawk?)?
So, with a CPL, i can fly for hire & reward...ok...AND I can fly IFR on any multi engine airplane....?...that's within the 'envelope' of parameters..??PPL rules for IFR are identical to CPL rules, except: You can't fly for hire or reward AND you can only fly single pilot airplanes.
So, How do I find this out..? you at TC are my resource for this I guess?...or the flight school should be able to assist me here?For any aircraft that falls outside those parameters, I will need a type endorsement on my licence for each one.
eg. MIFR test flight done-BE76. CPL obtained-C152. Can I fly for H&R (CPL) on the Seminole or say the Seneca..?
Well if you don't need a type rating to fly an A/c other than on which you qualified, it's as good as an 'open rating', one that allows you to fly all A/c under...say an AUW criteria...1500kgs.
Now that is KOOl if it's true ...but Hell I am sure you would atleast need a check or two before you fly such an A/c...maybe by the CFI of the flight school or some other instructor/examiner...atleast unofficially (i mean without an endorsement on your license)
Do let me know ...but thanx again.
