Have you a link to that?lostaviator wrote: The live ATC recording is quite chilling. And also went on for much longer than I expected given the short duration of their flight.
thankslostaviator wrote:I don't sorry. Go to liveatc and search the yvr arrival/departure feed. Search by time on liveatc. It was 15z-15:30z time frame I believe.
I can understand if the families do not want their name broadcast all over the media. I probably wouldn't want my family to release my name either.phillyfan wrote:This kinda highlights one of the things that bug me. When people are looking for PM's about Crew ID.
Yearwood said all indications are the two pilots suddenly lost control of the aircraft, dropping from an altitude of 2,400 metres to about 900 metres — the height at which the wreckage was found — in less than a minute,
Carson Air SA226 plane
The crashed plane is a twin-engine SA-226 Metro II similar to this one. (Carson Air)
"The radar track showed a very steep descent," he said. "The crew did not call, declare an emergency or have any stress, which gives us an idea that whatever happened, happened suddenly. The radar track gives us information on how fast it was descending ... and that is consistent with uncontrolled flight."
There's at least couple others that I can come up with. Not likely but possible.iflyforpie wrote:5000 feet per minute. I think airframe failure is the only possibility.
It may bug you but when I have a friend that may have been on board it bugs me not knowing if he is ok or not. It's not like im looking for a name so that I can tell the world, it's for my own piece of mind. And yes I found out later on, my good friend was on board that plane and I am devastated.phillyfan wrote:The identities of the two pilots are not being released at the request of the families, police said
Sorry for your loss.arctic_slim wrote:It may bug you but when I have a friend that may have been on board it bugs me not knowing if he is ok or not. It's not like im looking for a name so that I can tell the world, it's for my own piece of mind. And yes I found out later on, my good friend was on board that plane and I am devastated.phillyfan wrote:The identities of the two pilots are not being released at the request of the families, police said
A few years back a FedEx Caravan basically fell out of the sky into a Winnipeg neighborhood due to icing.5000 feet per minute. I think airframe failure is the only possibility. Icing or mechanical failure wouldn't have been so abrupt.
Didn't Bearskin have a pitch actuator failure into Winnipeg several years ago? If I recall it got quite sporty, but they pitched nose up. It's certainly a plausible theory.Unit 969 wrote:Sounds like a pitch trim actuator failure to me.
I would think that such a failure would have resulted in a Mayday, no?Unit 969 wrote:Sounds like a pitch trim actuator failure to me.
