YYT Cancellations
YYT Cancellations
Anyone want to explain how Provincial Airlines were operating in and out all day yesterday yet AC canceled all flights in the afternoon and last night?
Re: YYT Cancellations
Last edited by Slappy the Squirrel on Wed Sep 30, 2015 6:05 pm, edited 1 time in total.
Exactly right. For PAL St. John's is home, but for Air Canada it is the far end of a very large North American route network. Any disruption there has follow on consequences that no one but SOC (System Operations Center) are fully aware of. Cancelling flights is not a decision taken lightly and is only done because the certain disruption to the schedule, inconvenience to the customer and cost is less than it would be with airplanes, passengers and crews diverted someplace they're not supposed to be. Rest assured as soon as a flight is cancelled plans are underway to reallocate whatever resources are necessary to get things back to normal.Slappy the Squirrel wrote:Just a guess?
My hat is also off to the good people of Newfoundland who generally greet such disruptions with a good natured shrug. Nobody knows bad weather like they do.
The Cat 3 on runway 11 should be operational by the end of the year, although the E190 cannot do Cat 3 and it currently flies into YYT a lot so unless they take it off the YYT run, the problem will persist.
Yes and no. The CAT II/III will be to both 29 and 11 (according to the PPT I just saw) which will greatly improve the reliability over the current time when winds are out of limits for low visibility approaches on 29. While it's true the 190 is not CAT III capable (no autoland) they are due to leave the fleet completely in a little over four years to be replace by the 737 which is.hithere wrote:The Cat 3 on runway 11 should be operational by the end of the year, although the E190 cannot do Cat 3 and it currently flies into YYT a lot so unless they take it off the YYT run, the problem will persist.
If I may. Isn't the airline responsible for the pax once in the aircraft and enroute, for example if they miss YYT and head to their technical alternate which, lets say is Gander. AC is then responsible for meal vouchers and accommodation should their aircraft not be able to get back to YYT for whatever reason(duty limitations, continued bad WX) Also AC would have to charter a bus to get thoes people to their final destination YYT is that a a preferred method.
If the flight is cancelled at departure point(YYZ,YHZ or where ever) then AC is not responsible for that(bad wx), they will book you on next available flight subject to availability.
Outside of the very items Rockie stated, if my commentary a fair statement.
PS. I got nailed a couple of times in and out of YYT due shit wx but Maritimers take it in good stride..............
Thanks for the responses, makes sense. I was checking the RVRs and winds last night and the last 4 or 5 flights into YYT which were canceled hours before departure time had 1200 or better on the catII runway at or just past their scheduled arrival times.
Rockie wrote:Yes and no. The CAT II/III will be to both 29 and 11 (according to the PPT I just saw) which will greatly improve the reliability over the current time when winds are out of limits for low visibility approaches on 29. While it's true the 190 is not CAT III capable (no autoland) they are due to leave the fleet completely in a little over four years to be replace by the 737 which is.hithere wrote:The Cat 3 on runway 11 should be operational by the end of the year, although the E190 cannot do Cat 3 and it currently flies into YYT a lot so unless they take it off the YYT run, the problem will persist.
Only 20 of the 45 E190 will be leaving the fleet(as per the deal with Boeing to take 20 E190 off AC's hands in exchange for a good price on the inbound 737). That still leaves 25 E190(kind of an orphan fleet, wouldn't you agree?) until the end of the current contract in 2025
Major avionics upgrades would be required on all the airplanes to comply with the US ADS-B requirements by the mandatory date of January 1st, 2020. Air Canada is not going to invest that kind of money in airplanes that will be leaving anyway, and for the same reason the 320's have to be gone by then as well. If for some strange reason AC keeps those planes they either get upgraded or they may not fly in US airspace after that date.hithere wrote:Only 20 of the 45 E190 will be leaving the fleet(as per the deal with Boeing to take 20 E190 off AC's hands in exchange for a good price on the inbound 737). That still leaves 25 E190(kind of an orphan fleet, wouldn't you agree?) until the end of the current contract in 2025
Obviously catIII approaches are long overdue at YYT. As someone said after the YHZ accident, airports need to spend less money on fountains and art and more on approach aids and lighting.
+1av8ts wrote:Obviously catIII approaches are long overdue at YYT. As someone said after the YHZ accident, airports need to spend less money on fountains and art and more on approach aids and lighting.
+2Radiocaster wrote:+1av8ts wrote:Obviously catIII approaches are long overdue at YYT. As someone said after the YHZ accident, airports need to spend less money on fountains and art and more on approach aids and lighting.
No they put a "subject to weather" notice out prior to boarding, but yes if they miss they will charter a bus, however since they are so painfully slow paying the companies lots won't do the job. Hence why charlottetown is preferred to MonctonOld fella wrote:If I may. Isn't the airline responsible for the pax once in the aircraft and enroute, for example if they miss YYT and head to their technical alternate which, lets say is Gander. AC is then responsible for meal vouchers and accommodation should their aircraft not be able to get back to YYT for whatever reason(duty limitations, continued bad WX) Also AC would have to charter a bus to get those people to their final destination YYT is that a a preferred method.
Starting in June 11//29 will be closed for 5 months. It's going to get a lot uglier before it gets better
A lot of autopilots have significantly reduced crosswind limitations for autoland below CAT I minima. So despite the improvement, for some operators there could still be some difficulties with the new lower minimums.
AC FOM says 15 KT max x-wind for low vis approaches which is more restrictive than the Boeing AOM (25 kt)... Not sure about limits on the emb/bus...
The AC FOM complies with the TC Low Visibility Procedures manual which is where the crosswind and tailwind limits for CAT 2/3 approaches come from. Autopilot / autoland crosswind and tailwind limits are type specific but are pretty much identical between Boeing and Airbus at 25 and 10 knots.altiplano wrote:AC FOM says 15 KT max x-wind for low vis approaches which is more restrictive than the Boeing AOM (25 kt)... Not sure about limits on the emb/bus...
While autoland is required for CAT 3 and used if available when performing a CAT 2, it is a separate issue from low visibility approaches and has its own technical limitations.
