Rockie wrote:The access to information act predates SMS by a good number of years, and before SMS disclosure was much more open as the article indicates. Nothing bestows the "confidential" status on SMS reports or TC actions in relation to a company. There is nothing proprietary about SMS reports, they do not contain "trade secrets", and whatever technical information they contain has to do with safety rather than core business products.
What bestows confidential status on the contents of the report is that the data in them is provided to the government by a third party and treated in confidence by that third party. The law states plainly that that alone is sufficient.
20.1 contains an "or" clause. The records have meet any one of the criteria to be protected from release, not all of them. Since SMS reports are both technical information that is considered confidential by the third party
and could be reasonably expected to cause financial loss on disclosure, they're protected on two grounds. It doesn't make any difference if the information is proprietary or not, core business related or not, or trade secrets.
rockie wrote:
photofly wrote: the information in these particular cases doesn't pass that straightforward test.
You're wrong about the innocuousness of the information and that it is a straight forward test. It is completely
subjective test and this government has taken the default position of secrecy in everything they do when it should be the other way around. That's the way a free and open society works.
I'm not sure what the default position is, or even if there is one. What the government does in other cases is irrelevant to us; we must judge each issue on its own merits. Nor do I believe there's anything subjective about the test which I find quite easy to apply in this case.
The case that Porter might make to argue against disclosure is straightforward and logical:
1. The matters have already been corrected to the satisfaction of the regulator so no improvement to public safety could be obtained by disclosure
2. Disclosure of minor SMS findings would hinder future SMS reporting which is predicated on a level of confidentiality. Damaging the SMS system would be a detriment to public safety rather than assist it.
3. Disclosure is bound to cause significant commercial loss by needlessly alarming passengers and preventing them from booking for fear of safety issues that have already been corrected.
I doubt that we disagree on point 3. In fact I suspect that you're hoping to see that damage done because for some reason you have a hard-on for damaging Porter Airlines. But that's beside the point. What I'd like to read is a measured explanation of how public safety will be served by disclosure. I haven't seen it yet.
By the way, I believe there's a procedure under the Act where Porter would have been given notice of the intent to disclose and given the opportunity to make an argument against it. TC itself doesn't give a hoot if the information is disclosed, and it's not "government secrecy". It's Porter making a case to Government that disclosure of Porter's confidential information is not permitted in this case. And they're right.
