Now I know you are supposed to compare distance time with your flight plan for accuracy.
And to improve the accuracy even further, perform a "DME Update".
To this you would have to select an in range VOR/DME. So lets just say you wait till the DME shows 100NM. You would insert the co-ordinates for that VOR/DME into the INS, enter the elevation of the VOR/DME. The distances should be similar between the two. Now the INS would continually update increasing the performance index.
So how was the performance index kept accurate on trans oceanic flights?
Or does an INS only lose accuracy turning way point to way point and would remain accurate on a straight line A-B lat/lon across a long distance?
