Buffalo C-46 at Deline.
rigpiggy
Re: OWIE at Deline
Post by rigpiggy »
boeingboy wrote:
Explain to me why these are still legal then? Is it not time to retire the old girls, when everything else this size has to make accelerate stop distances and have guaranteed engine out climbs how are these allowed to operate?
Name me an airplane that will climb out on one engine with the inop engine not feathered? Not many if any.
Add to that possible icing, and.....say.....3/4 of gross weight....
Thats not a standard that is required to be met at all.
B1900
only did it in the sim, but numerous goarounds oei no feather with gear down, not pretty but doable
rigpiggy
Re: OWIE at Deline
Post by rigpiggy »
Heliian wrote:
fish4life wrote:If this was a turbo prop it would have had a much greater chance of not having a windmilling propeller due to power plants that have more fail safes with multiple ways to fx the engine. Also the other engine on most turbo props can handle well over 100% of the rated power rating in a situation like this so I would be willing to bet all ATR / Dash 8 types can handle this situation. These old warbirds have had their day and it has passed.
Pardon? That makes no sense, what kind of fixing are you doing to a blown engine? Even piston engines sometimes have a "military" power setting above the normal "100%". At least they all walked away from it, the ATR has a not so great safety record either.
FX means feather, fwiw it'll be a writeoff, joe will buy the wreck for scrap from the insurance company, and have spares for another 5yrs
fish4life
Re: OWIE at Deline
Post by fish4life »
Yes to clarify I meant feather by fx, typing on a touch screen leads to more shorthand. What I'm saying is most turbo props have multiple ways to insure the engine is feathered and even a windmilling free spool turbine shouldn't keep you from maintaining altitude. It looks like the crew did a good job but a one engine out scenario should never put a crew of an aircraft this size into a situation where they have to "put it down" somewhere it should be able to safely get them back to an airport even an hour away. This isn't a Navajo, what if this poor guys were doing some charter work in the high arctic would they they just have to hit the ground somewhere in between airports?
JasonE
Re: OWIE at Deline
Post by JasonE »
How many of these left that are actually air worthy in Joe's hands?
NunavutPA-12
Re: OWIE at Deline
Post by NunavutPA-12 »
There are four C-46's on the register. Apparently, Buffalo owns three, including TXW. It appears that AVO and TPO are flying.
Antique Pilot
Re: OWIE at Deline
Post by Antique Pilot »
ansonchappell wrote:The TSB investigator was interviewed by CBC North this afternoon. He said that the number 2 engine was shut down, and they diverted to Deline. The crew elected to land without gear extended and overran the end of the runway. Not enough time to extend, or too worried about airspeed to add all that drag?
Bringing GTXW home will likely have to wait until the Sahtu winter road system is in place, usually by Christmas.
Sean Parr, via Facebook
Maybe it is my old tired eyes but perhaps the bottom prop blade on the right engine is not in the feathered position. The other 2 blades are feathered. I consulted with a R2800 mechanic friend and he says that this has happened before. Just wondering.
AP
Longtimer
Re: OWIE at Deline
Post by Longtimer »
fish4life wrote:
gianthammer wrote:
fish4life wrote:Shouldn't a C-46 be able to maintain altitude on one engine?
This Post is speculation taking into consideration one persons knowledge and experience with this aircraft Type;
At or close to Max Gross Wt (Considering the Routing YZF-YVQ), Unfeathered Prop not producing full Power, possibility of being in icing conditions.
I would say no, you would be in a constant 100-300'/min decent
The crew did a great job salvaging this situation
The following may give you an idea as to why the C46 is still being used:
FLYING THE C-46
Flying the C-46 … First Impression (by Jeff Ethell)
(Note: Jeff Ethell came to Camarillo CA in Feb 1997 to fly the CAF So Calif Wing Curtiss C-46 “China Doll”. Immediately after the flight, he gave the following commentary.)
The C-46 was a big surprise to me. After you fly the DC-3, B-25, and other aircraft considered to be “heavy twins”, you appreciate that anyone who flew WWII airplanes probably had to be 18 years old and a weight lifter, because the airplanes are so heavy on the controls. It’s not unusual for the B-17 or B-25 to have 100 pounds of control pressure to deal with. Particularly if you lose an engine, you end up wrestling the airplane to the limits of your strength. There’s nothing to help you other than muscle power and maybe differential engine power.
It probably wasn’t so bad in WWII because those guys were young and fresh out of Cadets. But to those of us who fly them now, they’re heavy airplanes. Even though everyone told me that I’d enjoy how the C-46 felt, I was still surprised. From my perspective it was immediately pleasant. The controls never got heavy. The whole time we were flying, even in slow flight and with one engine out, the airplane was very nice to handle. I was surprised at how light an airplane its size was on the controls.
The C-46 was a pre-WWII design, intended to be a pressurized high altitude airliner. It never got there because WWII came along, and it never got its chance to do what it was designed for. But it was available for the massive transportation problem that came with WWII, when we had to move enormous amounts of material, and originally had no Transport Arm to speak of.
Airplanes were inducted into the military. The DC-3 was simply painted green, the seats taken out, and deemed ready to fly as the C-47. There were no self-sealing tanks, no armor plate, no help at all. WWII films taken over Arnheim, and D-Day, show that when a C-47 was hit it became a massive ball of flame. The plane went down immediately. There was no way out; everyone died. It’s a terrible thing to watch.
The DC-4 became the C-54 the same way. In fact, United Airlines bought ten of them, but when Pearl Harbor happened they were told “No Delivery”. Again, they were painted green and off they went into the Army Air Forces.
Fortunately the C-46 came along, and it had the power to out-perform even those airplanes with four engines. The C-54 out-performed the C-46 to some extent over the Hump, but Hump pilots told me the C-46 was THE airplane you could overload, climb to 20,000 ft (which was mandatory for the first time), go through terrible weather, get to the other side, off-load the equipment and come back. The C-47 couldn’t come anywhere close to that. Hump losses were high. We lost well over 700 airplanes, mostly due to weather, while ferrying 650,000 tons of critical war supplies to forces in China. During the peak month of July 1945, there was an average of 1.3 flights across the Hump every minute!
Having flown the C-46 now, I can see what they’re talking about. It’s a four-engine airplane with two engines! It doesn’t need the other two engines because it has two large R-2800s. Everything else had the smaller R-2000s, 1830s, or 1820s. The intention was to give the customer (it turned out to be the Army) a high performance airplane that didn’t over-tax the pilot, could be loaded to its limits and would fly … even on one engine.
That was a revolution in the air-transport world. Quite frankly, WWII was a revolution all the way through. It probably advanced airline flying by 10 years because the airline pilot who came out of WWII knew what carburetor icing was, understood the problems of having to go through very tough weather fronts, etc. The C-46 was probably the only airplane until 1944 that could deal with these problems to some degree.
The C-46 comes off the ground like a shot. Of course we were flying it light, but even so, it was off the ground quick and was immediately responsive. Differential engine power was wonderful. There’s lots of power in the throttles. You have large engines out there and a move on the throttles gives an immediate response. You don’t have that in airplanes of lower horsepower. I didn’t fly the C-46 in a cross-wind, so I didn’t experience some of the things that could get a pilot in trouble. But it was wonderful throughout the regime I flew.
This pre-WWII airplane was ahead of its day, and held its own throughout the war. Without it there probably wouldn’t have been the airlift operation we had; the “Hump” wouldn’t have existed. It’s certainly a great airplane, and a wonderful piece of history to keep flying. The CAF flies the only two C-46s that are displayed to the public (“China Doll” and “Tinker Belle”). Another 20 or so are still working in Alaska, Canada, and Central America.
More About Flying the C-46 (by John Deakin)
(Note: John Deakin flew C-46s for Air America in SE Asia)
The one thing the C-46 is really famous for is lousy directional control on the takeoff and landing roll. Its rudder is extremely ineffective at low speeds on the runway, even after the tail is up on takeoff. Even under ideal conditions with the wind right down the runway, or with no wind at all, the airplane might suddenly, for no reason whatsoever, head for the side of the runway rather briskly. If you slam in full rudder to stop it, that rudder is totally ineffective. The only solution is to yank back the opposite throttle to stop the nose. And when the nose starts back, you have to get the throttle back up again to get the beast under control. That particular quirk has bitten more potential C-46 pilots than anything else.
The C-47 doesn’t have the same problem. The rudder area on the C-46 is about 30 percent of the vertical surface area, leaving about 70 percent for the vertical stabilizer. The C-47 is reversed, giving it better directional control than the C-46 at low speeds.
Also, the C-46 is a very fat airplane, so when it’s moving down the runway the fat fuselage blocks a lot of airflow over the vertical surfaces. The small rudder doesn’t get much airflow, which limits its effectiveness. The C-47 has a much narrower fuselage, which allows more air to flow over the vertical surfaces, and it has a larger rudder to boot.
You can easily taxi a C-47 at moderate speed, 10 knots or so, and have rudder control with the free swiveling tail wheel. The C-46 rudder has absolutely no noticeable effect when taxiing.
The C-46 has monstrous ailerons, consequently the adverse yaw effect is much greater than on other airplanes. The result is that if you roll the wheel to the left for a left bank, the nose actually goes to the right if you don’t apply a fair amount of rudder to resist it. In most airplanes on a crosswind takeoff, you use the ailerons into the wind to help a little bit. With the C-46 it’s absolutely crucial to use the aileron very heavily to roll it into the wind.
It’s quite comical to watch when a jet pilot gets into this airplane and doesn’t instinctively use the rudder. They’re not used to not using the rudder at all, because most of the jet transports have dampers and other mechanisms that let you keep your feet on the floor when your’re hand-flying them.
The airplane does a job that no other airplane can do even today. A perfect example is the Everts operation out of Fairbanks AK. They haul 12000-15000 lbs of gasoline and other liquid fuels in 55 gal barrels into and out of 2500 ft gravel strips day after day … an astonishing feat. I’d love to try that for two weeks and really get sharp with the airplane again. Five C-46s fly for Everts, and they’re restoring one or two more.
The C-46 has big, fat, soft, low pressure tires, so it operates well off rough, soft, mud, or grass strips. Its footprint is fairly light for a huge airplane. At the time it was built it was the largest twin-engine airplane ever made. It’s bigger than the B-17 and B-24 in all dimensions except that the B-24 has a 2 foot longer wingspan:
AIRPLANE HEIGHT WING SPAN (FT) LENGTH (FT)
C-46 21.7 108.1 76.3
B-17 19.1 103.7 74.7
B-24 18.0 110.0 67.2
The rudder throw, i.e., the distance the rudder pedals move, is the greatest on any airplane I’ve ever seen. It’s quite difficult to set your seat so you can get full rudder on one pedal and get your other leg out of the way of the control yoke. There’s a real trick to it.
I hesitate to say it performs well on one engine, because these days we’re spoiled by jets and other high performance airplanes, where the loss of one engine is a no-brainer … it’s just a little unbalanced thrust. You have better performance on one engine with any of the modern twins than on both engines with the C-46. Nevertheless, for its era, the C-46 had remarkably good performance on two engines, and pretty good performance on one engine.
It has enough rudder control to handle an engine out, but you have to get it all in there. You have to be aggressive with it. It’s got sufficient power on the remaining engine to get around the pattern even with the max gross weight of 48000 lbs on a fairly warm day.
The airplane can do a good three-point landing on short fields. Most people who fly large airplanes are stunned when they see the airspeed indicator sitting at 60-65 kts and it hasn’t stalled yet. You make the landing approach at 65 kts, fairly steep, in fact scary steep, and at the bottom when you approach the runway, you yank the power off and haul the nose up and it squats down on three wheels, and you’re so slow with so much flap out it slows down very quickly. That’s how you get it onto short, rough fields. There aren’t many other airplanes that can do that.
In Vietnam we’d go into short, miserable strips surrounded by unfriendly people who enjoyed shooting at airplanes. We’d make a very tight descending spiral with a 45 deg bank turn at 65-70 kts, and make a real tight final turn. Just as the wings rolled level, we’d touch it down at a full stall and slam on the brakes and get it stopped before running off the far end. Only a C-46 will do that with a huge load. The C-47 is good at this also, but can haul only half the weight the C-46 does. A tail wheel airplane is definitely superior to a tricycle gear plane for getting into a short, unimproved strip, and the C-46 really excels at it.
In most airplanes, especially the larger ones, there’s a considerable delay between moving a control in the cockpit and having something happen out on the wing, particularly with the throttles or props. With the C-46 you just pop a little throttle on it and you get instant power response. You wouldn’t think the big prop would speed up that fast, or that the engine could respond so quickly. When the airplane suddenly veers into one of it’s wild excursions, you just pop a little power to it and you get instant response. The most effective directional control on the airplane is differential power. It’ll get you out of trouble quicker than any thing else.
I never flew the airplane under icing conditions, but its reputation is excellent for fighting ice. It was used heavily on the DEW Line, where it flew in miserable Arctic conditions, and of course across the Hump where its bad-weather exploits are legendary. I flew C-46s mostly in SE Asia, where the only ice was in our scotch.
It has a good range with regular tanks, which hold 1400 gals. That will take it 10 hrs easily, and if you really go into fuel conservation, you can get 12-13 hrs flight-time out of that much fuel. It will do 150 kts at low power settings and perhaps 125-135 gals/hr. It you really push it, it’ll go up to 180 kts at maybe 180 gal/hr. Figure roughly 1 kt per gal per hr, which makes fuel planning fairly simple. At 150 kts, the range is 1500 to 2000 miles … it depends on how slowly you fly and the load on board.
For a WWII era aircraft of its size and type, the C-46 is pretty fast. Even though it looks fat, it’s a streamlined airplane. It has a red-line speed of about 230 kts, whereas the “Gooney Bird” is well below 200 kts. At airshows it’s impressive to dive down the last 500 ft at full power and go roaring along the runway at red-line speed! Everybody’s impressed by how the big, fat, clumsy airplane can really move along.
The C-46 is a stiff wing airplane. Most airplanes are designed with lots of flex in the wing to absorb the turbulence. In theory the wing on this airplane is built like a bridge, and is actually designed not to flex. Don Downie (former Hump pilot and co-author with Jeff Ethell of “Flying the Hump”) said “Even in the most violent turbulence, it was impossible to see any flexing of this rigid wing structure. By comparison, the C-47 had a very flexible wing designed to bend under loads. Many times from the cockpit of the C-47, you could see the engine nacelle flex downward as the wing tip flexed upward, much to the consternation of those of us accustomed to the brick-house rigidity of the C-46.”
http://www.cafsocal.com/our-aircrafts/o ... -the-c-46/
boeingboy
Re: OWIE at Deline
Post by boeingboy »
You clearly have no idea what your talking about.
jspitfire
Re: OWIE at Deline
Post by jspitfire »
NunavutPA-12 wrote:There are four C-46's on the register. Apparently, Buffalo owns three, including TXW. It appears that AVO and TPO are flying.
I believe TPO has sat as a parts machine since it returned to Buffalo Airways from FNT a couple years ago. That being said, I'd put money on Joe stripping down TXW and getting TPO airworthy again pretty quick.
xsbank
Re: OWIE at Deline
Post by xsbank »
Boeing boy, I second that.
Troubleshot
Re: OWIE at Deline
Post by Troubleshot »
So you are saying a Dash 8 100 would have suffered the same fate as this aircraft? Or are you talking about the windmilling thing?
Re: OWIE at Deline
Was it an engine failure and the propeller refused to feather or a runaway propeller? With the latter, I doubt if you're going anywhere but down. A controlled descent mind you, but I doubt the airplane would maintain level flight.
xsbank
Re: OWIE at Deline
Post by xsbank »
I doubt if even a Dash8 would fly with an unfeathered prop, but who on here knows? The principle virtue of turboprops is their relative reliability and that most of them are about 25 years younger than any C46.
It looks like the nose gear is down? That must have been a very hairy ride, that prop is not happy and the weather was diabolical. I'll bet there was a fairly strong need to change clothes after that arrival.
Remember that old saw about "...any one you can walk away from is a good landing, any one you can use the plane again is a great landing?" This one might be one of the greats!
Well done to the crew; too bad the tv company wasn't along for that ride!
I remember a C46 doing a fuel haul in Manitoba years ago and while enroute it lost an engine. The copilot, famous from previous exploits, his reputation preceded him, proceeded to feather the wrong engine. If you think a C46 is a lump with only one running... They both came to, out in the woods, still strapped in and sitting in their chairs having been ejected out through the glass nose (it was a long time ago but I don't think their were any injuries?) about 200 feet in front of the junk. Despite being full of fuel and a bladder with something in it, no fire.
jpilot77
Re: OWIE at Deline
Post by jpilot77 »
xsbank wrote
it looks like the nose gear is down?
Well that would mean they really plopped her on considering that C-46s have conventional landing gear :lol:
xsbank
Re: OWIE at Deline
Post by xsbank »
Of course you're right! What a stupid mistake! To add insult to injury I have 800 hours in a Racer too!
That's it, I need more coffee!!!!!
Re: OWIE at Deline
Fritz (the Captain) wrenched his back on the Manitoba crash xs. He said he almost got the good one going again before they hit the trees, almost being the operative word here. :)
5x5
Re: OWIE at Deline
Post by 5x5 »
OK, I certainly didn't know what "the Hump" was so I looked it up, and to save others the time, here's an excerpt.....
http://flythehump.org/abouthistory.html wrote:The US was determined to keep China in the war, and the only way to supply Chiang's army and Chennault's China Air Task Force was by air, across the "Hump" of the towering Himalayas.
"The Hump" was a highaltitude military aerial supply route between the Assam Valley in northeastern India, across northern Burma, to Yunnan province in southwestern China, flown during World War II. This operation was the first sustained, long range, 24 hour around the clock, all weather, military aerial supply line in history. It was a start-from-scratch operation. There was no precedent for it.
Mark Twain
xsbank
Re: OWIE at Deline
Post by xsbank »
Thanks Siddeley. I was wondering if my memory was playing tricks. Amazing story, really.
How could you be a pilot and not know what "The Hump" was? Actually that's not an insult, necessarily, a school board official this week admitted she had never heard of Auschwitz! You can't help it if our education system can't be bothered to teach anything. It's just too bad that students have to be there, they could be out learning a trade or something useful rather than sitting there for years having "study periods."
Sorry, this is very off topic!
Curtis Commando Curtis Commando Curtis Commando Curtis Commando Curtis Commando
That better?
Donald
Re: OWIE at Deline
Post by Donald »
It's a little concerning that Buffalo operates 705 category aircraft, that have twice in the past two years been unable to sustain flight with an engine out.
Time to retire the old birds?
snoopy
Re: OWIE at Deline
Post by snoopy »
It's not what is being operated that should be in question, it is how it is being operated.... You can insist everyone operate shiny new jets if you want, but in the hands of the wrong people, it's just "whipped cream on dogshit" to coin the phrase of an old engineer I lost track of... (Dave if you're still on here you'll have a good chuckle).
snoopy
teacher
Re: OWIE at Deline
Post by teacher »
xsbank wrote:I doubt if even a Dash8 would fly with an unfeathered prop, but who on here knows? The principle virtue of turboprops is their relative reliability and that most of them are about 25 years younger than any C46.
Yes, a Dash 8-100 fully loaded will fly with a windmilling engine.
https://eresonatemedia.com/
https://bambaits.ca/
Donald
Re: OWIE at Deline
Post by Donald »
snoopy wrote:It's not what is being operated that should be in question, it is how it is being operated.... You can insist everyone operate shiny new jets if you want, but in the hands of the wrong people, it's just "whipped cream on dogshit" to coin the phrase of an old engineer I lost track of... (Dave if you're still on here you'll have a good chuckle).
snoopy
Are you suggesting that these crashes were the result of mis-handling by the pilots, or are you referring to the "company culture" of Buffalo Airways?
NunavutPA-12
Re: OWIE at Deline
My brother-in-law (an AME) once helped pull a damaged C-46 out of the bush near Pickle Lake. Must have been 30-years ago or thereabouts. Would anyone on here recall the registration letters of that bird? I think it went to Buffalo Airways.
snoopy
Re: OWIE at Deline
Post by snoopy »
@Donald the statement was generic in nature.
snoopy
Axial Flow
Re: OWIE at Deline
Post by Axial Flow »
Interesting that the TSB did not attend....I guess that is because there was no new information to further aviation safety because most of the problems associated were designed out of newer aircraft. Glad the boys made it ok, looks like a nice job putting down an airplane that didn't want to fly anymore.
