My mistake , sorryAuxBatOn wrote:There is no 602.96 section 2 para c...
sec 3 para c
I have been flying 30 yrs and cannot remember this not being the rule.AuxBatOn wrote:So, " make all turns to the left when operating within the aerodrome traffic circuit, except where right turns are specified by the Minister in the Canada Flight Supplement or where otherwise authorized by the appropriate air traffic control unit;"
How does that mean you cannot join straight-in? This would also mean all IFR traffic is in violation of 602.96(3)(c) since 602.96 (1) says: "This section applies to persons operating VFR or IFR aircraft at or in the vicinity of an uncontrolled or controlled aerodrome." when they complete a straight-in approach.
AuxBatOn wrote:How about an IFR airplane shooting an approach?
AuxBatOn wrote:Even if there is nobody in the circuit, this dude is saying you cannot conduct a straight-in final. This include IFR traffic (as 602.92(1) says), because of 602.96(3)(c). I call BS. It may be very poor airmanship to do so, but it is not against the law.
Good pointsAuxBatOn wrote:It is not explicitly written that you cannot conduct a straght-in approach therefore, at this point, is merely an interpretation of the law that, IMO, is a bit stretched. Until a Court is presented with a case and makes a ruling, it will remain interpretation. If that was the case, every IFR traffic conducting a straight-in approach at an ATF would go against the law. Tell that to the 703/704 companies that operate to ATFs....
FWIW, the CARs do not differentiate between ATF, MF or controlled aerodrome in 602.96.
Again, good points but again TC is saying no straight in allowed at ATF Aerodromes but you can do them at MF AerodromesCpnCrunch wrote:If you're doing an IFR circling procedure, you can circle the opposite way to the circuit pattern if circling is prohibited in the other direction. Whether or not you're actually in the "circuit" (as you'll probably be lower than the standard circuit) is another question. I certainly wouldn't recommend circling in the opposite direction to the circuit on a VFR day when there is VFR traffic in the circuit, although I've seen people do that.
What if you're landing a 737 at an uncontrolled airport? Are you going to do a circuit? Even if there is other traffic, it doesn't seem like the smartest idea. Or what about Hedley and his L-39? He says he does a 1500ft circuit to avoid blasting the spam cans out of the sky.
Fleet I have a letter somewhere around here from TC Enforcement - the people who would actually charge you with something - that says a straight in is permissible anywhere as it avoids the circuit. I'll see if I can dig it out.fleet16b wrote:Again, good points but again TC is saying no straight in allowed at ATF Aerodromes but you can do them at MF AerodromesCpnCrunch wrote:If you're doing an IFR circling procedure, you can circle the opposite way to the circuit pattern if circling is prohibited in the other direction. Whether or not you're actually in the "circuit" (as you'll probably be lower than the standard circuit) is another question. I certainly wouldn't recommend circling in the opposite direction to the circuit on a VFR day when there is VFR traffic in the circuit, although I've seen people do that.
FYI there are no official circuit heights at MF / ATF Aerodromes only recommended heights
You can fly 100ft VFR circuits till your hearts content not good practice but totally allowed
Be careful. Watch out for 602.114(d)(ii). Then we can discuss if the downwind part of a circuit is either "taking off" or "landing".fleet16b wrote: You can fly 100ft VFR circuits till your hearts content not good practice but totally allowed
To meet the requirements of 604.28(a) you may be required to fly a circuit.JohnnyHotRocks wrote:I have just spent the last hour researching this topic and cannot find guidance anywhere that requires an aircraft on an IFR approach (in vmc) to join the circuit. In fact the TC poster I found cautions VFR pilots that IFR aircraft may be landing from a straight in approach.
I did not take the opinion of one TC Inspector and sought out a second inspector to see if there was any conflicting interpretations.ahramin wrote:Fleet I have a letter somewhere around here from TC Enforcement - the people who would actually charge you with something - that says a straight in is permissible anywhere as it avoids the circuit. I'll see if I can dig it out.fleet16b wrote:Again, good points but again TC is saying no straight in allowed at ATF Aerodromes but you can do them at MF AerodromesCpnCrunch wrote:If you're doing an IFR circling procedure, you can circle the opposite way to the circuit pattern if circling is prohibited in the other direction. Whether or not you're actually in the "circuit" (as you'll probably be lower than the standard circuit) is another question. I certainly wouldn't recommend circling in the opposite direction to the circuit on a VFR day when there is VFR traffic in the circuit, although I've seen people do that.
You can't take the opinion of one inspector and then say "TC is saying". You have to look up the rules, present your interpretation of them to multiple enforcement people at TC and compare the different answers. To me it's very obvious that many TC inspectors say you can't do a straight in at ATF Aerodromes, and just as obvious that if you do a straight in and don't cut anyone off, you are avoiding the circuit and not breaking any CARs.
You are correct , its the AIM poster that states this .....sort ofAuxBatOn wrote:It does NOT say such things in CARs, therefore it is not law (and not enforceable). If someone issues an infraction on the basis you are suggesting and he takes TC to court over it, I strongly suspect the individual would win his case...
