Ed Force One Badly Damaged on ground in Chile
Taxivasion
Re: Ed Force One Badly Damaged on ground in Chile
Two people were injured when the plane broke loose from the tow truck,
Don't let your wife talk you out of buying an airplane,
True North
Wow! That is a helluva lot of damage from bumping into a tug on tow.
I think there might be more to this story.
That should buff out, no problem.
I wonder what they will use as a replacement in the interim?
Yeah, a quarter inch of paint and no one will notice.photofly wrote:That should buff out, no problem.
- Rank Moderator
Wow! Looks like the tug really had the number of that jumbo. I wonder if the ace who was driving it is running for the Andes, before the killers are released from the hold, and some murders are committed!
Happiness is V1 at Thompson!
- Shady McSly
Man how awesome is that guy's life...he's a member of Iron Maiden AND flies a 747
- currysonic
Chileans just didn't want them to leave!
Heavy Metal band Iron Maiden’s new-to-them B-747-400 “Ed Force One” currently fresh on their “Book of Souls World Tour” was badly damaged on the ground at Santiago Airport Chile today while being towed. Two engines and possibly an undercarriage were impacted. Initial details indicate that the B-747’s steering by-pass pin fell out on the tow turn, NLG locked up and during the tug’s continuing turn, towbar shear-pin sheared and loss of towbar/tug connection to the aircraft occurred. This was followed by the tug operator slowing up and the aircraft over-running it. Tugs cab was sheared off. Two ground employees injured. See photos below for damage.
As you may know Iron Maiden’s front-man Bruce Dickinson is a commercial pilot (over 20 years / 7,000 hours). He flew their B-757, and prior this current world tour he got his B-747 ticket on a simulator at Cardiff Aviation, his aircraft maintenance facility in Wales (Bruce is chairman and co-founder of Cardiff Aviation). He finished his last 2-3 weeks of training in Florida, right before flying to Sharjah in the UAE to pick up the B-747 aircraft, where it was being prepared for the tour. The aircraft carries 20 tons of show equipment plus the band and support staff.
- efo1.jpg (41.97 KiB) Viewed 4644 times
- efo4.jpg (37.01 KiB) Viewed 4644 times
- efo5.jpg (40.27 KiB) Viewed 4644 times
more......
- efo3.jpg (71.35 KiB) Viewed 4644 times
- efo2.jpg (62.87 KiB) Viewed 4644 times
Lots of things went wrong with that tow!
Was someone not riding the brakes on the flight deck?
Was the nose wheel steering hydraulics not turned off?
Nose wheel steering bypass pin "fell out"!?
I have never had a bypass pin fall out nor have ever heard of it.
If the tug turns the nose wheel with the steering hydraulics pressurized, the "weak link" in the tow bar goes off with a big bang! Very hard to miss.
His audiogram must be ... interestingShady McSly wrote:Man how awesome is that guy's life...he's a member of Iron Maiden AND flies a 747
- Siddley Hawker
I wonder if Dickinson was flying it himself? He used to fly the 737 for Astraeus, been into Deer Lake a few times on that charter they used to run out of Luton? Stanstead? someplace.
My guess is that all that awesome is the result of a hell of a lot of very hard work. Kudos!Man how awesome is that guy's life...he's a member of Iron Maiden AND flies a 747
ChrisEvans
Yes he is flying it thru the entire tour - aircraft scheduledI wonder if Dickinson was flying it himself?
to be back in service Wednesday.
Its back in action. Saw it twice in one week a couple of weeks ago. Seattle and LA.
It was in YVR a few weeks ago as well.
It was not out of service very long. Only 10 days........2 new engines, inlet cowls, reverser and fan cowls, and some x-rays.
Seattle April 13th.
Semper Fidelis
Semper Fidelis
If those guys were true rock stars there'd be footage of them inverted in a 4 G negative dive.
That's a different kind of rock star.
