Type Rating and Rank
Is your rank locked for the type you are flying (for an airline)?
If you get rated on a new type and you are, say, a 2nd year Capt, do you start as a 1st year FO on the new type? Do you have to start as an FO on every new type you get rated to fly?
Can someone please explain how it all works or point me towards the appropriate reading?
Thanks!
Thanks!
Re: Type Rating and Rank
Since this is in the general industry forum I'll answer it for legacy model airlines. If you want information about non seniority-is-everything airlines like Westjet you can look them up individually.
Seniority number is everything. When you get hired, you get a number at the bottom of the seniority list. Everyone hired before you is above you on the list. Everyone hired after you is below you on the list. That number controls your position (they don't use ranks in the airlines), your schedule, your vacations, your pay, your priority on standby flights, pretty much everything at work.
So for any position that becomes available, your current position and experience don't have any bearing. What matters is your seniority number. If you are the most senior person to want that position, you get it. Otherwise you don't. So if you are an Embraer F/O and a 777 Captain spot opens up and you are the most senior pilot who wants the position, it's yours.
Westjet isn't that different. We have seniority for equipment bids, just not for schedule or vacation bidding.
Maybe I didn't word my question properly or do not understand something. So I'm going to try giving you an example.
Suppose I start working for a major airline. Initially, I could only expect an F/O position and probably on one of the smaller types (they are also more common so odds are in that favor). Within a few years, maybe due to my seniority level and positions becoming available, I'm offered a Captain's position on the type I'm currently an F/O on and I take it. Now, suppose a while after, some crew retires and due to my seniority I'm offered a chance to get rated for a larger aircraft, maybe on long haul flights. I would finish all the training required and now I return to fly the type I'm now rated for. Would my position be that of a Captain (since I have already been a Captain prior to getting the new type rating) or would I have to start as an F/O again as this is a new type? And if I start as an F/O would this always happen or it varies with the situation?
I understand that seniority is what determines eligibility for the different positions and types, but there might be someone with more seniority that prefers to not move up to a larger type or have to do long haul flights. So maybe somewhere along the line when my seniority entitles me to it, I may choose to take on that new rating.
I think I understand what you don't understand. When a spot opens up on the larger aircraft in your example, the spot isn't for Aircraft B. The spot is either for Captain on Aircraft B or F/O on Aircraft B. Your current position as Captain on Aircraft S does not change your seniority number and therefore has no effect on your bidding for the position on Aircraft B.
So if you bid F/O on Aircraft B and have the seniority to get it, you will be F/O. If you bid Captain on Aircraft B and have the seniority to get it, you will be Captain. If you bid Captain on Aircraft B and do not have the seniority to get it, you stay Captain on Aircraft S. If you have the seniority to get Captain or F/O on Aircraft B and bid F/O on Aircraft B, you will be F/O, even if you have the seniority for Captain.
Ill put it in even simpler terms, using Jazz as an example. You could choose to spend 15 years in the right seat of the Dash 8, and then go straight to the left seat of the RJ if you had the seniority to hold that seat. You do not have to ever fly right seat on a new aircraft type, as long as you have the seniority to hold the left seat of the new type.
Same idea with AC. I know one pilot who got a 777RP position on initial ground school. He's just staying in that position until he can hold FO on the 777. Since RP is usually a lower seniority position, most if not all other RP's will be under him as time progresses and he can choose where and when he wants to go fly.
It's the same reason some 777/767 FO's might stay on the FO position for years after they can hold a Captain position. They will be able to bid what they want as an FO vs. a Cpt and if you're after lifestyle and ability to work when you want why go from a high seniority position as an FO to a lower seniority position as a Captain?
Huh ? Does your seniority reset/take a hit when you accept an upgradelazyeight wrote: It's the same reason some 777/767 FO's might stay on the FO position for years after they can hold a Captain position. They will be able to bid what they want as an FO vs. a Cpt and if you're after lifestyle and ability to work when you want why go from a high seniority position as an FO to a lower seniority position as a Captain?
Generally the Captain position is paid more and therefore tends to be more senior. So when you move from F/O list to Captain list, you will be among more senior pilots and therefore lower on the list.
What really matters for quality of life is not your global seniority in the company but how your seniority compares to those on the same aircraft in the same position at the same base.
A friend of mine took an upgrade to Captain last year and when all was said and done, he's away from home at least twice as much for a 25% pay raise. Eventually it may work out for him but for now he's effectively cut his hourly rate down significantly.
No. Think of it this way. Three pilots seniority 1, 2 and 3 all start at the same time. Pilot 1 goes 777RP and holds poor seniority as do 2 and 3 as an FO on the A320. 5 years pass and Pilot 1 is still an RP however he is at the top of the 777RP seniority for his position as everyone else has moved on to FO jobs on other aircraft or the 777. This allows him to choose and bid on whatever he wants. Pilots 2 and 3 both can now hold the 777 FO job and take it right away. Now they are new 777FO's and likely lower on the 777FO seniority list for that specific position. They take the flights they get until they start to move up the ladder. All while pilot 1 is still working as an RP, and still picking and choosing his days and rotations. He gets days off when he wants, flies to destinations he wants etc. 3 years pass and in this time both pilots 2 and 3 have moved up on the seniority list for the 777 FO position. They are starting to get more flights they want and days off when they want. Pilot 1 decides now is the time to make the switch to 777FO. Now he holds higher seniority right away than both pilots 2 and 3 in that position even though he just started as his overall number is higher.digits_ wrote:Huh ? Does your seniority reset/take a hit when you accept an upgradelazyeight wrote: It's the same reason some 777/767 FO's might stay on the FO position for years after they can hold a Captain position. They will be able to bid what they want as an FO vs. a Cpt and if you're after lifestyle and ability to work when you want why go from a high seniority position as an FO to a lower seniority position as a Captain?
The above scenario can be related to anything, FO to Cpt upgrades etc. Makes sense?
Exactly. Base matters too. Look at Jazz. Captain upgrades in Vancouver are over 10 years from what I've been told. Compare that to Toronto, 2 years. Vancouver is what you consider a "high seniority" base. Same reason you might get a Captain upgrade at AC faster if you are willing to move to Winnipeg vs. staying in Toronto or Vancouver and waiting until you can hold a Captain position at that base.ahramin wrote: What really matters for quality of life is not your global seniority in the company but how your seniority compares to those on the same aircraft in the same position at the same base.
Does all that seniority stuff mean, that as a low seniority pilot at an airline you could have to change base every month / year ? Or are there mechanics in place to prevent that stuff ?
If there is a fleet reduction you could loose your base or be given options for a new plane at your base (might be a lower seniority bid) or a move to another base.
Digits unless something happens to force the issue like getting rid of an aircraft type or layoffs you are protected in your position. If someone above you on the list decides they want a certain position, they have to wait until there is an opening on it (from expansion or retirements) and be the most senior (or 10 most senior if 10 positions open up) to get it. They cannot displace someone who already has that position despite a better seniority number.
Thanks !
The answer is no.mcapmare wrote:Is your rank locked for the type you are flying (for an airline)?
The last aircraft I flew as F/O was the 737-300.
I've flown 757/767/A320/A330/A340 as Captain. No F/O time on any of them.
This sometimes means your first day on the job as Captain on your new aircraft, you find yourself paired with an F/O who has many many hours on type, and you have zilch.
That's not correct - you still need to complete Line Training. First flight on Type will be with an Instructor in the right seat.ogopogo wrote:This sometimes means your first day on the job as Captain on your new aircraft, you find yourself paired with an F/O who has many many hours on type, and you have zilch.
Example A330 to A340 requires 4 Line Training sectors with an Instructor followed by a 2 sector Line Check.
A company will normally combine Line Training with route qualification. At my previous employer this was a checkout for European routes and at my present employer it was KJFK.
Figuratively speaking as I'm sure he was, he is correct. Your first day on the job as a Captain on a new aircraft is the first day you are qualified and signing out the airplane. That means after the bare minimum of training with the type rating on your license still wet you could be paired (if you're lucky)with a First Officer with many years and thousands of hours of experience on that type. A wise Captain will recognize that and properly utilize the First Officer to continue his education on the airplane.Eric Janson wrote:That's not correct - you still need to complete Line Training. First flight on Type will be with an Instructor in the right seat.
