Hmm.. well, as far as im concerned, the job of the examiner is to see if the candidate meets the standard of the exercise being demonstrated. Ive posted below from the flight tets guide on ex 12.modi13 wrote:No, I'm quite certain that he meant your stall recovery technique. How did any of your students get that past the examiner? Unless the examiner was also the Class I who trained you on that technique...The largest concern for all of us here isn't that you've said you'll stop teaching it that way; it's that you taught it that way at all. How many licenced pilots are there out there who are certain that the way to recover from a stall is to add power first? For that matter, who taught you, and how many other instructors were taught the same thing, only to pass it on to their students? On the other hand, this seems like the kind of thing that you came up with yourself after a moment's thought on the use of power to arrest descent, without any in-depth consideration for the actual aerodynamics involved, or a complete lack of understanding thereof.
http://www.tc.gc.ca/civilaviation/gener ... 3/menu.htm
Aim
To determine that the candidate can recognize indications of the approach to arrival stalls, the full stall and can accomplish a positive and smooth recovery with a minimum loss of altitude.
Description
At an operationally safe altitude that allows recovery at or above 2,000 feet AGL, or the minimum height recommended by the manufacturer, whichever is higher, the stall manoeuvre will be entered from a power off situation. The examiner will specify the aeroplane configuration for the stall demonstration.
Performance Criteria
Assessment will be based on the candidate's ability to:
a.complete appropriate safety precautions before entering a stall;
b.establish the specified configuration;
c.transition smoothly to a pitch attitude that will induce a stall;
d.recognize the onset of the stall by identifying the first aerodynamic buffeting or decay of control effectiveness;
e.stall the aeroplane;
f.maintain directional control;
g.promptly and smoothly recover using control applications in the proper sequence;
h.avoid a secondary stall and excessive airspeed or altitude loss
So as you can see, they dont specify the exact sequence of recovery. All they say is that the candidate should recover with minimum loss of altitude. Maintain directional control (with rudder of course, and ailerons neutral). Instead of saying proper sequence, they should say nose down first, and so on. It might be that the examiner might have a different opinion of what the "proper" sequence is than the instructor. I would hope TC lists the standard sequence on the FTG, in our case, nose down first.
