I won't claim I've never heard it, only that I don't find that it is a consistent failing of instructors. I will say that you might find the problem more acute in your neck of the woods since I know that new class 4s are being made out that way by a couple of class 1s who are passing on this mentality. I will say the worst culprits I find making skidding turns are the ultralight guys - which sort of confirms my previous thesis - they spend a whopping seven hours before being "permitted" and most of that is starting off going around the circuit to figure out landings before anything else, then they go do just enough of the obligatory upper air practice to check off the boxes before the letter is submitted.Colonel Sanders wrote:Really? Well, you're doing a lot better out in AlbertaInstructors I've found are generally not consistent on transmitting this supposed fear of bank you're talking about
with flight instruction (as well as financially) as compared
to back east here in Ontario.
Every PPL I have ever flown with was crippled by his
ab initio instructor who sternly told him:
USE MAXIMUM X DEGREES OF BANK IN THE CIRCUIT OR YOU WILL DIE
I'll happily demonstrate this as well to students, but I also make clear that steep angles of bank aren't the solution for poor judgement (they're also good ways to make your wife never fly with you which might curtail your dreams faster too). You do a steep turn because you planned to do a steeper turn. Reading the wind is key to this, something a lot of people have trouble with, unsuprising since as I said, illusions is often the overlooked lesson. The "fix", if you really botched the turn onto final, isn't a suddenly increased angle of bank or a footful of bottom rudder to skid the turn, but rather an overshoot and go around and try it again. The other tactic I advise, is to begin with a gentle angle of bank and if it looks like its not working then to increase to a greater one, try to plan for the gentler one off the start though. If you're uncomfortable with how steep you must make the bank to make the turn, then see above. This is mostly for style sake, its easy to make a turn tighter by steepening the turn if it looks like you're going to overshoot the corner, than it is to make it look good if you start with a steeper bank and try to shallow it out part way through the turn, not that you can't, but even the layman in your passenger seat can tell when you make this error in judgement. Either way, that's less important than both the coordination of the turn and the judging of its resulting path of flight.They think I am insane when I tell them to use as
much bank as they want in the circuit, but I want
the ball in the center.
Students should also note that increasing the angle of bank is going to increase the rate of descent if the airspeed is maintained, so something to think about on the final turn. Cranking a steep turn on final without a thought to this has probably also filled a few drawers on new CPLs and contributed to their general fear of angles of bank. Its unfortunate that many pilots are afraid of the steeper bank angles, and slips more so than they are of skids.
