Air Canada's Embraer ERJ-175
Gurundu the Rat
Post by Gurundu the Rat »
Not gonna work. Makes too much sense.
gelbisch
Post by gelbisch »
So what's THIS thing now??
I can see that 3000 hours on the 99 is going help me out a lot on this thing...
Gurundu the Rat
That is a touch pad to move the mouse kinda like on a laptop. Have fun.
gelbisch
Post by gelbisch »
My GOD it's a computer with wings!!
abc xyz
Post by abc xyz »
hey gelbisch better start exercising that typing finger of yours. only 9 more sleeps for ya till the big day. :D
split s
Post by split s »
That is also how my daughter measures time as well! Three more sleeps until halloween!
Hey bubbles,get me some of those dressed all over chips!
Gurundu the Rat
You didn't actually think you would be flying it did you? You're a programmer now, congrats!
abc xyz
Post by abc xyz »
split s wrote:That is also how my daughter measures time as well! Three more sleeps until halloween!
smart girl - probably knows how many sleeps to christmas and more importantly how man sleeps until daddy buys her a car after her 16th birthday.
Jaques Strappe
Post by Jaques Strappe »
Gelbisch
It is called a CCD. The three little buttons let you select either your PFD, MFD or EICAS displays. Once you have selected the desired display, you can select what information you want.
If you have an electrical problem, for instance. You can bring up a schematic of the electrical system in its current status.
You can select your wx radar, TCAS, and various other information sources. You can use it as an alternative method of tuning your radios as well.
J.S
Standby for new atis message
gelbisch
Post by gelbisch »
Thanks, Jaques. What does CCD stand for?
Trevor Corey
Post by Trevor Corey »
Yes.... that was quite the complex FMS in the 99. :wink:
2 smokes, let's go!
Jaques Strappe
Gelbisch
CCD stands for "Cursor Control Device"
Check your PM's
J.S
tonysoprano
Post by tonysoprano »
Study hard and stay away from the champaign room you guys. Many AC new hires have dumped alot of $$ there.
rightsideup
Post by rightsideup »
tonysoprano wrote:Study hard and stay away from the champaign room you guys. Many AC new hires have dumped alot of $$ there.
So where is the champaign room ... just to make sure we stay away.
8)
tonysoprano
Conveniently located next to one of the airport's finest eateries, Arizona's.
EI-EIO
Post by EI-EIO »
Re: the 175s. A few pages back a rumour was asked about - that the rampers disliked the 175 due height of the cargo door compared to the 705. Nobody answered this - any word?
Jaques Strappe
This is true
The ramp guys don't like it because they have to bend over or stand on their knees when in the hold. It is very low in there to accomodate 6'7" headroom in the cabin.
Not to insult the rampies but I don't think their needs ranked very high on the list of design features.
Gurundu the Rat
WARNING This may or may not be true but I love a good rumor anyways.
Someone mentioned to me the E175s are burning a lot more fuel than advertised (23%more). This is 2nd hand info, can anyone confirm this? Also heard air quality is bad and that the air filters need to be changed every 50 hours. This person also told me the crews are feeling more fatigued after flying it all day due to the air problems. Can someone that actually flys it confirm or deny this? They also said E190s will be delayed, not sure but something to do with operating costs being high. I'm thinking it probably has more to do with training issues. (If true)
So can anyone bust these rumors?
Jaques Strappe
Gurundu
I haven't heard or experienced any of those issues. If the vnav is not used properly, I can see a fuel burn increase happening but that is just bad airmanship.
I am showing 190's on my December schedule. YOW-FLL and YOW-MCO
Air quality is fine and all the passengers are very complimentary about the airplane as they disembark.
The only real issue that pisses me off about this aircraft is that you cannot leave it powered up and walk away. You want to go into the terminal to grab a bite, you have to do a termination. Subsequently, it is always being " re booted ".
The APU does not have automatic fire protection on the ground and if the GPU is being used, then the Batts must be on which exposes them to the risk of discharge should the GPU go offline. For the life of me, I can't understand why they designed it this way. If you put the airplane on ground services, the flight deck still goes dark, you can't even keep essentials powered up.
Gurundu the Rat
Well, good to know most of what I heard was BS. I don't know who comes up with this stuff sometimes. Thanks for setting the record straight.
GTR
Return to “Air Canada”
