If you drove a Tesla at 150 mph in the snow and hit a pole, should you be concerned about the safety of the car?? Black sheep didn't operate the otter properly. That same plane also hit a snow bank with the back end just prior to the accident flight. It wasn't just a "plane fell apart for no reason" crash....If it turns out that there were no contributing factors and the latest one just fell apart, then I would be concerned.Mick G wrote: ↑Tue Oct 29, 2019 5:56 amI beg to differ. With presumably 2 in a period of less than 10 years, it would be appear to be a cause for concern, especially considering the air-frames are continuing to age. I'd bet Viking is sweating blood at the moment.Maynard wrote: ↑Mon Oct 28, 2019 11:48 am This is (unofficially) the 5th (on record)
2 in 1956. First suspected wake turbulence, the other inadvertent rapid full flap retraction
1 in the 70's, unknown cause
1 in 2013, black sheep, determined excessive over speed on high percentage of flights
While the tail has had its issues, it doesn't seem like in flight break ups are a known issue or weak spot with the Otter
Blue Water Aviation plane down North of Winnipeg
Re: Blue Water Aviation plane down North of Winnipeg
FishermanIvan
BWA has Walter/GE engines on their Otters and they’re not operating with that 9000 pound upgross or whatever it is.
I worked there for two summers. Very sad to hear this and my heart goes out to everyone involved.
I fly both the PT6 and Garrett conversions. They are very similar in limitation. PT6 is max 134mph on floats and 144mph wheels, Garrett if I recall is limited at 136mph floats 146mph wheels. Regardless it's very tragic and hits home.
There is enough to go wrong in aviation , without having to worry about airframe failure.... this needs attention.
There but for the grace of God, go I.
Do we have an official body count yet? Is it for sure 3? Have they all been recovered?
FishermanIvan
One passenger has been recovered, the pilot and other passenger are still missing.
Where did you get this intel from?
A reliable witness and RCMP have retracted their original statement.
Told the same by RCMP on site. "Not sure why they printed that they hit a tree. We said It was possible. But the wing came a couple hundred feet up."
Does anyone know if the aircraft in question had one of the upgross kits? I don’t think it would have been overweight on this flight but I’m more curious about the effect of years of an upgross kit applied to a plane and it’s effects.
FishermanIvan
It did, but it was the 8367 pound one, and not the other (9000 pound?) upgross kit that I’m pretty sure exists.
ragbagflyer
I'd be more concerned about the Otters flying around at 9000 pounds+ without the upgross than the ones with the STC that are getting the correct maintenance.
Agreed and it appears this one wasn’t a 9000lb plane anywayragbagflyer wrote: ↑Tue Nov 05, 2019 11:26 amI'd be more concerned about the Otters flying around at 9000 pounds+ without the upgross than the ones with the STC that are getting the correct maintenance.
How many of the otters are operating at 8000 lbs. plus without the stc? Over the years I’ve seen many with the back of the floats under water?
You wouldn't be the first with that observation.
The backs of the floats being under water means almost nothing. Also there are a number of float sizes and fuel tank locations. It's easy to sink the backs of a straight 7170 Otter without a Walter header tank and be perfectly legal.
Both pilot and second passenger now recovered and brought to Winnipeg.
I really hope the TSB can find out what caused the structural failure with some haste. It would be horrible if this were to happen to another otter before the report comes out 3 years from now.
AD can be issued before the final report. It does seem like the TSB has started issuing some reports more quickly on the last year or so for smaller accidents.
Maybe we are having an effect.
Here is the obituary for Jonathan, the pilot.
There is a fund for Keira and Liam (his daughter and son) education.
https://www.soberingfuneralchapel.com/j ... g-friesen/
Rest in peace
Rest in peace
FishermanIvan
I’m pretty gutted I can’t make it to Bissett tomorrow, both Jonathan and Tanya made being away from home very easy for both my summers there. Made me feel right at home from day one. Nothing but the utmost generosity from both of them.
I do hope they find out what happened so it doesn’t ever happen to anyone else.
Rest In Peace. I’ll miss knowing you.
seasonaldriver
Evidently all Otters in Canada have been grounded pending the results of the accident investigation.
That's gonna hurt the west coast operators hard.
I hope they find the cause of the wing failure very soon. Before anything else catastrophic happens.
Where did you get that info?
That would really screw Harbour Air.
