Fat chance...aircraft production is delayed.jpilot77 wrote: ↑Fri Jan 20, 2023 8:50 amThere are rumours that they still want to get to 6000 pilots by summer 24. They’re running classes every 2 weeks now.orangejuice wrote: ↑Fri Jan 20, 2023 8:01 amSo 3 PIT courses in February… 6,13,22? That seems like a lot
The Air Canada OTS thread
Re: The Air Canada OTS thread
It was 6300 in 2026. The amount of wrong information here is nuts.jpilot77 wrote: ↑Fri Jan 20, 2023 8:50 amThere are rumours that they still want to get to 6000 pilots by summer 24. They’re running classes every 2 weeks now.orangejuice wrote: ↑Fri Jan 20, 2023 8:01 amSo 3 PIT courses in February… 6,13,22? That seems like a lot
700 more this year with GS every 2 weeks is the aim.
1100 Oct 2023-Oct 2024 and
700 Oct2024-2025
Retirement Average is at 121 all the way upto 2037. AVERAGE. Some years its 60-70 some it'll be 120+.
Can you explain why there is such a frantic hiring push going on right now? Why not spread it out?Vanguard wrote: ↑Sun Jan 22, 2023 7:56 pmIt was 6300 in 2026. The amount of wrong information here is nuts.jpilot77 wrote: ↑Fri Jan 20, 2023 8:50 amThere are rumours that they still want to get to 6000 pilots by summer 24. They’re running classes every 2 weeks now.orangejuice wrote: ↑Fri Jan 20, 2023 8:01 am
700 Oct2024-2025
Just looking at the numbers here: ~120 retirements/yr doesn't seem to warrant so much hiring. 120/yr for the next 14yrs is only 1700. Why do they need 2500 new hires by 2026? There is little, if any, fleet growth happening. I can easily see any downturn causing a surplus situation ripe for layoffs.
Only what I’ve been told.. but Apparently they were short even before covid. And another 8-900 is for the new duty rules. Add in some retirements, plus jazz repatriation …but I can’t explain the full amount… seems like a lot to me as well.
The training pipeline cannot accommodate the numbers referenced above on an annual basis. How many type courses can the system handle? 600 PIT type courses plus another 800-1000 type courses from current pilots?
AC may well get to 6000 but it will likely be at a pace of 600/yr.
I'd start a new application from a different email host. They're hiring King Air medevac pilots now, they should be at least interviewing you. Sometimes things fall through the cracks. A lot of the initial application review is likely done by computers instead of people.indieadventurer wrote: ↑Thu Jan 19, 2023 6:32 pm 8000+ TT with 500+ PIC 737 and university degree.
Haven’t been able to get an interview since posting went up in the spring.
Anyone else with a similar background hearing nothing?
Air Canada does not have the pilots for their summer schedule right now. The hiring is a combination of future retirements, CARS duty regulations, Attrition (YES AC Has it too but not as high ~ approx 20/yr) and projected fleet growth. Keep in mind AC is not currently hiring all 20yr olds. Its a mix bag of experience from all over the world.thepoors wrote: ↑Mon Jan 23, 2023 4:40 amCan you explain why there is such a frantic hiring push going on right now? Why not spread it out?Vanguard wrote: ↑Sun Jan 22, 2023 7:56 pmIt was 6300 in 2026. The amount of wrong information here is nuts.
700 Oct2024-2025
I don't think layoffs are expected unless there is a major or extreme downturn in the economic climate or lockdown. The demand for air travel is strong and AC has a strong pull in the US/International Markets. The demand for travel has never been crazier and it will be hard for AC to cover all the flying possible. The hiring will need to continue to meet the demand for the foreseeable future.
I have to disagree with the post above, with the caveat that if there is a massive recession there won't be much movement for roughly 2-3 years, but I believe that would unfortunately be the same situation (or worse) regardless of which airline you worked for.
With reference to the two seniority projectors available one shows 280 mandatory (age 65) retirements between 2023-2026, while the other subscription service projects over 400 from 2022-2025, I've referenced those projections for about 10 years and found them to be accurate to within +/-5 annually. A pretty impressive mathematical projection when you account for unforeseen but sadly inevitable loses due to deaths, life long disabilities, resignations, and terminations.
Retirements ebb and flow, and the ebb we have today is a result of the early retirements in 2020/21. For the 6 years after 2026 projected retirements range from 110-150 annually. A pilot hired today at sen. 4500 could expect to see themselves move up to roughly sen 3300 in the next 10 years.
So what all that mean? That depends on the fleet. As of Dec 31/22 AC had 233 aircraft between ML/LCC with roughly 4500 pilots, on Dec 31/20 there were 255 and the last projection prior to the pandemic 261 aircraft were planned to be in the fleet at the end of 2021 to be flown by a planned 5000 pilots, with the junior Captains positions being awarded in the 3600-3800 range. I'm not sure where the 6000 pilot number came from but from what's been announced the 23 parked LCC 767's capacity is being replaced by a combination of the A21XLR and exercised 787 options. From what's been announced some A220 options and factory new 767/777 freighters have been ordered/exercised as well. That's easily 5000+ pilots by 2025 even with new aircraft phasing out some older airframes. 6000 seems like a massive number but so did 4000 when rumours of a massive hiring spree were being used to pitch a 10 year contract.
The latest financial statements available don't offer much insight past the end of this year, the full year 2022 results provided next month should provide a longer term picture. The pre-pandemic Air Canada seemed to believe there was a market for a fleet of 250-270 aircraft.
There are 60 76 seat jets operated by Express.TheStig wrote: ↑Wed Jan 25, 2023 10:45 am
The process of substituting mainline NB and Rouge aircraft on to Express operated routes began prior to COVID and is continuing now. The A220 converted options and extension of A319 fleet operations is a manifest result of this evolution.
Where that goes 2023-2025 remains TBD. But each time an additional A220 is ordered or A319’s remain in the AC fleet plan is another nail in the Express 76 seat jet coffin.
Notably, there has been ZERO public discussion by either AC, CHR, or Jazz about 76 seat jet fleet renewal. That is an ominous sign for the future of the Express 76 seat jet operation.
Mainline pilot staffing will increase if Express/Jazz pilot staffing decreases.
why would there be, its locked in for another 13 years?rudder wrote: ↑Wed Jan 25, 2023 12:18 pmTheStig wrote: ↑Wed Jan 25, 2023 10:45 am
Has nothing to do with the term of the CPA.flyingcanuck wrote: ↑Wed Jan 25, 2023 12:58 pm why would there be, its locked in for another 13 years?
40 of the 76 seat jets are vintage 2005/2006 date of manufacture. That is quite old in the world of regional jets.
All of the original AC E190’s are in the desert….. same vintage.
- Jean-Pierre
What about a Porter deal? How big are their jets going to be?
- Jean-Pierre
Not all of them, but we get the point. But it has more to do with that there is little market for a 97 seat aircraft that burns more fuel than a Max8.
The newest mainline A320 is 2002 and 5 are from 1991-1993. 2 of the 767 are 1989. Those RJs are practically new in AC terms.rudder wrote: ↑Wed Jan 25, 2023 2:34 pmHas nothing to do with the term of the CPA.flyingcanuck wrote: ↑Wed Jan 25, 2023 12:58 pm why would there be, its locked in for another 13 years?
True.Sharklasers wrote: ↑Wed Jan 25, 2023 8:59 pmThe newest mainline A320 is 2002 and 5 are from 1991-1993. 2 of the 767 are 1989. Those RJs are practically new in AC terms.rudder wrote: ↑Wed Jan 25, 2023 2:34 pmHas nothing to do with the term of the CPA.flyingcanuck wrote: ↑Wed Jan 25, 2023 12:58 pm why would there be, its locked in for another 13 years?
But the CRJ and possibly the ERJ were not built for the durability or lifespan of a Boeing or an Airbus. There is no such thing as an 80000 cycle regional jet. D check cost typically exceeds residual value with removable parts sold.
Hi everyone!
Recently did the interview and medical and wondering what's the average time to get a background check?
Also what's the current call back time post interview nowadays?
Pm is welcome.
Cheers!
Pm is welcome.
Cheers!
Background check roughly 10 business days after interview/medical.
Call back 2 months after the interview.
Did the interview early December, been crickets since then, anyone else not heard anything that long, be nice to know one way or the other!
Hopefully you'll hear back soon.
Now I wonder if no background check request within 2 weeks means probably PFO on the way.
Good luck to all of waiting.
AC is notoriously slow in their hiring process. It’s not uncommon to wait months from interview to job offer.
Meanwhile I’m hearing Flair and other airlines are fast tracking their hiring process because they want butts in seats as fast as possible.
Just sayin, there’s other options out there, do your due diligence before locking into a single employer and choose appropriately.
I did interview end of November. Still haven’t even got background check request. But no news is good news is what I’ve been told.cloudseeker wrote: ↑Sat Jan 28, 2023 6:27 amHopefully you'll hear back soon.
