Boeing Systemic Problems Continue
Curiousflyer
Re: Boeing Systemic Problems Continue
Post by Curiousflyer »
ahramin wrote: Thu Jan 02, 2020 8:50 am
Curiousflyer wrote: Thu Jan 02, 2020 4:37 am How exactly does this work then? MCAS is required flight control system for certification of the aircraft to fly. But it’s going to disable itself if both AoA sensors don’t agree? How then is the aircraft still certified to fly?
It works the same way as every other system on the airplane. Once the takeoff roll is commenced, there is no requirement for the aircraft to remain certified. Even on a plane without MCAS, an aircraft with a u/s AOA probe is no longer certified to fly. That doesn't mean you stop the plane on the side of the airway and call for a tug.
No. Aircraft must be designed with redundancy.
https://www.ecfr.gov/cgi-bin/text-idx?n ... p14.1.25.d
FAR 25.601
Raymond Hall
Post by Raymond Hall »
An interesting take on the genesis of the Corporate demise—from an on-line publication, Quart:
The 1997 merger that paved the way for the Boeing 737 Max crisis
Late in the summer of 1997, two of the most critical players in global aviation became a single tremendous titan. Boeing, one of the US’s largest and most important companies, acquired its longtime plane manufacturer rival, McDonnell Douglas, in what was then the country’s tenth-largest merger. The resulting giant took Boeing’s name. More unexpectedly, it took its culture and strategy from McDonnell Douglas—even its commercial aviation department was struggling to retain customers. ...
In a clash of corporate cultures, where Boeing’s engineers and McDonnell Douglas’s bean-counters went head-to-head, the smaller company won out. The result was a move away from expensive, ground-breaking engineering and toward what some called a more cut-throat culture, devoted to keeping costs down and favoring upgrading older models at the expense of wholesale innovation. Only now, with the 737 indefinitely grounded, are we beginning to see the scale of its effects.
“The fatal fault line was the McDonnell Douglas takeover,” says Clive Irving, author of Jumbo: The Making of the Boeing 747. “Although Boeing was supposed to take over McDonnell Douglas, it ended up the other way around.” ...
Inside the company, there were rumblings of dissatisfaction. A formerly cosy atmosphere, in which engineers ran the show and executives aged out of the company gracefully, was suddenly cut-throat. In 1998, the year after the merger, Stonecipher warned employees they needed to “quit behaving like a family and become more like a team. If you don’t perform, you don’t stay on the team.” ...
Two decades on, perhaps the most lasting consequence of the change in culture has been in Boeing’s approach to aircraft building. Cutting costs and diversifying revenue ought to have served as an ideal way to subsidize the expensive process of plane development. Instead, with engineers now disempowered and management far away in Chicago, the actual building of new planes in Seattle all but stalled. Boeing would not actually announce even the plans for a new plane until 2003, with the 787 Dreamliner. Throughout this time, Boeing was led by its first chairman without a traditional aviation background: James McNerney had instead spent almost two decades in management at General Electric—now, he was following a tried-and-tested route of cutting, downsizing, and shifting.
[Article continues ...]
https://qz.com/1776080/how-the-mcdonnel ... ax-crisis/
Ifly
Post by Ifly »
Long ago my wife said the airplane will not fly again, and I disagreed, I'm starting to think my wife may have been correct and I'll explain why...
If the return to service is going to require additional training, the common type certificate is likely in jeopardy. If the Max is no longer considered a common type with the original 737 then it is a new type that will be required to meet modern FAR design criteria, which is impossible without a complete redesign.
My suspicion is that there is a great deal of discussion going on in the background between Boeing, the FAA and various other political bodies about how to unpaint the corner they've all found themselves in. At this point the silence is deafening.
2R
Post by 2R »
Any new return to service dates yet ?
pilotbzh
Post by pilotbzh »
https://www.cp24.com/news/air-canada-we ... -1.4752495
Off schedule until March 31 for now, probably later, I have doubts it will fly this summer....
Raymond Hall
And the beat goes on—a new problem: wiring; from today's New York Times:
It’s Not Just Software. New Safety Risks Under Scrutiny on Boeing’s 737 Max.
The company and regulators are looking into everything from the wiring on the plane to its engines.
Even as Boeing inches closer to getting the 737 Max back in the air, new problems with the plane are emerging that go beyond the software that played a role in two deadly crashes.
As part of the work to return the Max to service, the company and regulators have scrutinized every aspect of the jet, uncovering new potential design flaws.
At the request of the Federal Aviation Administration, Boeing conducted an internal audit in December to determine whether it had accurately assessed the dangers of key systems given new assumptions about how long it might take pilots to respond to emergencies, according to a senior engineer at Boeing and three people familiar with the matter.
Among the most pressing issues discovered were previously unreported concerns with the wiring that helps control the tail of the Max.
The company is looking at whether two bundles of critical wiring are too close together and could cause a short circuit. A short in that area could lead to a crash if pilots did not respond correctly, the people said. Boeing is still trying to determine whether that scenario could actually occur on a flight and, if so, whether it would need to separate the wire bundles in the roughly 800 Max jets that have already been built. The company says that the fix, if needed, is relatively simple.
The company informed the F.A.A. about the potential vulnerability last month, and Boeing’s new chief executive discussed possible changes to the wiring on an internal conference call last week, according to one of the people and the Boeing engineer, who spoke on the condition of anonymity to discuss internal deliberations. [Continued]
https://www.nytimes.com/2020/01/05/busi ... 7-max.html
2R
Post by 2R »
How big would the Tail Strakes required be ?
To prevent a deep stall on a Max ?
An aerodynamic solution to an aerodynamic problem.
Tail strakes work on many different aircraft , the guys with the slide rules stuck them on Lear jets for a similar issue of power induced pitching at high alpha creating a deep stall . The tail strakes prevent further pitching ,
The counterintuitive part of deep stall recovery is reducing the power to get out of the trap.
Might be a work around for the Max, works on other high performance aircraft ?
Raymond Hall
From today's Wall Street Journal:
Boeing Considers Raising Debt as MAX Crisis Takes Toll
Compensation and maintenance costs rise as grounding stretches toward one-year mark
Boeing Co. BA -0.34% is considering plans to raise more debt to bolster finances strained by the grounding of its 737 MAX, according to people familiar with the matter.
The aerospace giant isn’t running out of cash. Boeing had about $20 billion in available funds at the end of the September quarter, according to the company’s financial statements. But costs associated with the MAX crisis are rising.
Boeing faces compensation claims from airlines and families of the 346 victims of two MAX crashes over the past 15 months. This month, Boeing halted production of the plane, lowering some costs but pushing back the likely date at which payments for finished planes would resume.
Analysts expect Boeing to raise as much as $5 billion in additional debt to help cover expenditures that could top $15 billion in the first half of this year. In addition to spending on maintenance for the MAX’s stalled production facilities and finished planes, the company plans to close its $4 billion acquisition of an 80% stake in the Brazilian plane maker Embraer SA ’s commercial airliner business. Boeing also has to repay some existing debt and fund shareholder dividends.
Chief Financial Officer Greg Smith said in October, when Boeing last provided guidance related to the MAX return to service, that the company didn’t expect to have to resort to certain unspecified “levers” to improve its finances. Mr. Smith is also serving as interim chief executive until David Calhoun takes over on Jan. 13.
Now, alongside raising more debt, Boeing is also thinking of deferring some capital expenditures, freezing acquisitions and cutting spending on research and development to preserve cash, people familiar with those possibilities said.
https://www.wsj.com/articles/boeing-con ... lead_pos5
boeingboy
Post by boeingboy »
The real problem is the vortex flow off the new, larger nacelle body which produces lift at high AoA. As the nacelle is ahead of the C of G, this lift causes a slight pitch-up effect, that – in turn - keeps the nose up instead of falling naturally. This abnormal nose-up pitching is not allowable under 14CFR §25.203(a) "Stall characteristics".
The 14CFR §25.203(a) regulation (a) is [2]:
>It must be possible to produce and to correct roll and yaw by unreversed use of the aileron and rudder controls, up to the time the airplane is stalled. No abnormal nose-up pitching may occur. The longitudinal control force must be positive up to and throughout the stall. In addition, it must be possible to promptly prevent stalling and to recover from a stall by normal use of the controls.
Remember - this is an expanded portionof MCAS and not it's sole function. It is not an anti stall software.
Raymond Hall
Another headache:
Ukrainian Airlines plane crashes in Tehran shortly after takeoff
A Boeing 737 plane carrying 180 passengers and crew crashed shortly after takeoff from Imam Khomeini Airport in Tehran early Wednesday local time, Iran's semi-official news agency ISNA reported.
Most passengers on board the Ukraine International Airlines flight died, said Pirhossein Koulivand, head of Iran's Emegency Medical Services.
Emergency crews have been dispatched to the crash site but cannot assist because the area is currently ablaze, Koulivand said on IRINN, a state-run media outlet.
Flight-tracking service FlightRadar 24 said in a tweet that the jet had been in service for about three and half years.
ISNA reported the crash was due to to technical difficulties.
https://www.cnn.com/2020/01/07/middleea ... index.html
Raymond Hall
Raymond Hall wrote: Tue Jan 07, 2020 9:43 pm Another Boeing 737 disaster. From the video released on CNN, it would appear that the aircraft was engulfed in flames, big time, immediately after take-off...
Raymond Hall
Boeing's 180 — from today's New York Times:
In Reversal, Boeing Recommends 737 Max Simulator Training for Pilots
The company had long maintained that the training wasn’t needed to fly the plane, which was grounded after two deadly crashes.
From its inception, Boeing’s 737 Max was designed to save airlines the expense of training their pilots on flight simulators. During the initial approval of the plane and after two crashes killed 346 people last year, Boeing argued in conversations with the Federal Aviation Administration that simulator training was not necessary.
Now, after a worldwide grounding has cost the company billions of dollars over nearly 10 months and caused it to temporarily halt the production of the Max, Boeing has reversed course. On Tuesday, the company said it would recommend that pilots train in flight simulators before flying the Max.
The decision stems from Boeing’s analysis of recent flight simulator tests that were part of the work necessary to return the Max to service, which showed that pilots were not using the right procedures to handle emergencies. Those tests are the latest hurdle for Boeing, which has encountered setback after setback as it tries to fix problems with the Max and persuade regulators that the plane is ready to fly.
The training requirement may further complicate efforts to return the plane to service. The final decision on whether to mandate simulator training will be made by the F.A.A., which is likely to follow the company’s advice. The agency still has to complete testing of the plane.
The F.A.A. said it would consider Boeing’s recommendation, adding in a statement that it was “following a thorough process, not a set timeline, to ensure that any design modifications to the 737 Max are integrated with appropriate training and procedures.”
https://www.nytimes.com/2020/01/07/busi ... ining.html
Raymond Hall
From Bloomberg News:
Boeing faces US$5-billion tab on 737 Max simulator training
Boeing Co.’s costs would rise an estimated US$5 billion if pilots need to get simulator training before flying the 737 Max, according to Bloomberg Intelligence.
That would nearly double the US$5.6 billion that Boeing had committed to cover costs from last year’s grounding of the jetliner. The manufacturer will be expected to reimburse airline expenses for simulator training because it sold the plane on the basis that pilots certified for the previous 737 variant would need minimal additional training, analyst George Ferguson said in a note Thursday.
The manufacturer on Tuesday said it had advised regulators that pilots need more than brief tablet-based training before flying the Max, reversing its previous stance in part because of revisions to the plane after two crashes killed 346 people. Simulator training would delay the return of the aircraft, Ferguson said. The decision on simulators is up to regulators, who have yet to approve the plane’s return.
“Our estimates show the cost of airline lost profits will probably exceed Boeing’s US$5.6-billion reserve just for 2019,” he said. “As the production pause stretches on, suppliers will run into more financial difficulty, perhaps even needing support from Boeing.”
Boeing’s compensation to Southwest Airlines Co., the largest operator of the Max when it was grounded in March, likely will exceed US$1.2-billion if the plane remains parked through this quarter, Ferguson estimated. That would be 22 per cent of the US$5.6 billion that the manufacturer has set aside. Southwest hasn’t disclosed terms of its agreement with Boeing but said the grounding reduced operating income by US$830 million last year.
https://www.bnnbloomberg.ca/boeing-face ... 1.1371460
Raymond Hall
Has the bad news finally hit bottom? From today's New York Times:
Boeing Employees Mocked F.A.A. and ‘Clowns’ Who Designed 737 Max
The company expressed regret at the embarrassing communications it sent to investigators on Thursday, which included a comment that “this airplane is designed by clowns, who are in turn supervised by monkeys.”
Boeing employees mocked federal rules, talked about deceiving regulators and joked about potential flaws in the 737 Max as it was being developed, according to over a hundred pages of internal messages delivered Thursday to congressional investigators.
“I still haven’t been forgiven by God for the covering up I did last year,” one of the employees said in messages from 2018, apparently in reference to interactions with the Federal Aviation Administration.
The most damaging messages included conversations among Boeing pilots and other employees about software issues and other problems with flight simulators for the Max, a plane later involved in two accidents, in late 2018 and early 2019, that killed 346 people and threw the company into chaos.
The employees appear to discuss instances in which the company concealed such problems from the F.A.A. during the regulator’s certification of the simulators, which were used in the development of the Max, as well as in training for pilots who had not previously flown a 737.
“Would you put your family on a Max simulator trained aircraft? I wouldn’t,” one employee said to a colleague in another exchange from 2018, before the first crash. “No,” the colleague responded.
https://www.nytimes.com/2020/01/09/busi ... ages.html
2R
Post by 2R »
I would have thought clowns would make excellent consultants for aviation. I have been to the circus and was impressed by how many clowns they can pack in those small cars .I am sure they could get 300 pax in a 120 seat aircraft and still have room for their balloon animals .
As for the monkey comment I have been to the zoo and know that monkies have no problems getting rid of shit, in fact they will throw it at you and threaten you with more shit if you do not move .
Might be an improvement putting clowns and monkies in charge , so long as they have an MBA from a reputable on line school and have paid at least 73.59 plus tax for it :)
Raymond Hall
More, from the Boeing e-mails recently provided to Congress:
Boeing Mocked Lion Air Calls for More 737 Max Training Before Crash
Indonesia’s Lion Air considered putting its pilots through simulator training before flying the Boeing Co. 737 Max but abandoned the idea after the planemaker convinced them in 2017 it was unnecessary, according to people familiar with the matter and internal company communications.
Boeing employees had expressed alarm among themselves over the possibility that one of the company’s largest customers might require its pilots to undergo costly simulator training before flying the new 737 model, according to internal messages that have been released to the media. Those messages, included in the more than 100 pages of internal Boeing communications that the company provided to lawmakers and the U.S. Federal Aviation Administration and released widely on Thursday, had Lion Air’s name redacted.
“Now friggin Lion Air might need a sim to fly the MAX, and maybe because of their own stupidity. I’m scrambling trying to figure out how to unscrew this now! idiots,” one Boeing employee wrote in June 2017 text messages obtained by the company and released by the House Transportation and Infrastructure Committee.
In response, a Boeing colleague replied: “WHAT THE F%$&!!!! But their sister airline is already flying it!” That was an apparent reference to Malindo Air, the Malaysian-based carrier that was the first to fly the Max commercially.
Doing simulator training would have undercut a critical selling point of the jet: that airlines would be able to allow crews trained on an older 737 version to fly the Max after just a brief computer course.
In a report on the Oct. 29, 2018 accident, Indonesia’s National Transportation Safety Committee cited a failure by Boeing to tell pilots about the new flight-control feature on the jet, called MCAS, and the need to provide training on it so that pilots would be able to better respond to malfunctions.
The report also cited shortfalls in the crew’s ability to perform emergency check lists, fly the plane manually and communicate about the emergency. The copilot, who took nearly four minutes to look up an emergency procedure he was supposed to have memorized, was singled out for repeated failures during training.
https://www.bloomberg.com/news/articles ... hwarted-it
Tealcowboy
Post by Tealcowboy »
The new Memory Actions are so simple really:
https://www.youtube.com/watch?v=7t4kDcVFnXU
Raymond Hall
The oft-quoted statement of George Santayana comes to mind: "Those who cannot remember the past are condemned to repeat it."
From today's New York Times—offer safety as an "option," for a price, then if the option is not purchased, blame the pilots for the outcome...
How Boeing’s Responsibility in a Deadly Crash ‘Got Buried’
After a Boeing 737 crashed near Amsterdam more than a decade ago, the Dutch investigators focused blame on the pilots for failing to react properly when an automated system malfunctioned and caused the plane to plummet into a field, killing nine people.
The fault was hardly the crew’s alone, however. Decisions by Boeing, including risky design choices and faulty safety assessments, also contributed to the accident on the Turkish Airlines flight. But the Dutch Safety Board either excluded or played down criticisms of the manufacturer in its final report after pushback from a team of Americans that included Boeing and federal safety officials, documents and interviews show.
A review by The New York Times of evidence from the 2009 accident, some of it previously confidential, reveals striking parallels with the recent crashes — and resistance by the team of Americans to a full airing of findings that later proved relevant to the Max.
In the 2009 and Max accidents, for example, the failure of a single sensor caused systems to misfire, with catastrophic results, and Boeing had not provided pilots with information that could have helped them react to the malfunction. The earlier accident “represents such a sentinel event that was never taken seriously,” said Sidney Dekker, an aviation safety expert who was commissioned by the Dutch Safety Board to analyze the crash.
Dr. Dekker’s study accused Boeing of trying to deflect attention from its own “design shortcomings” and other mistakes with “hardly credible” statements that admonished pilots to be more vigilant, according to a copy reviewed by The Times.
The muted criticism of Boeing after the 2009 accident fits within a broader pattern, brought to light since the Max tragedies, of the company benefiting from a light-touch approach by safety officials
Some of the parallels between that accident and the more recent ones are particularly noteworthy. Boeing’s design decisions on both the Max and the plane involved in the 2009 crash — the 737 NG, or Next Generation — allowed a powerful computer command to be triggered by a single faulty sensor, even though each plane was equipped with two sensors, as Bloomberg reported last year. In the two Max accidents, a sensor measuring the plane’s angle to the wind prompted a flight control computer to push its nose down after takeoff; on the Turkish Airlines flight, an altitude sensor caused a different computer to cut the plane’s speed just before landing.
Boeing had determined before 2009 that if the sensor malfunctioned, the crew would quickly recognize the problem and prevent the plane from stalling — much the same assumption about pilot behavior made with the Max.
And as with the more recent crashes, Boeing had not included information in the NG operations manual that could have helped the pilots respond when the sensor failed.
Critically, in the case of the NG, Boeing had already developed the software fix well before the Turkish Airlines crash, including it on new planes starting in 2006 and offering it as an optional update on hundreds of other aircraft. But for some older jets, including the one that crashed near Amsterdam, the update wouldn’t work, and Boeing did not develop a compatible version until after the accident.
The problem with the single sensor, he said, should have dissuaded Boeing from using a similar design in the Max. Instead, “the issue got buried.”
https://www.nytimes.com/2020/01/20/busi ... ents.html
L39Guy
Post by L39Guy »
Boeing has been found to follow the proper certification process.
There’s the NY Times and there are the facts:
https://www.avweb.com/flight-safety/faa ... ification/
L39Guy wrote: Mon Jan 20, 2020 9:03 am Boeing has been found to follow the proper certification process.
For a plane that is properly certified, it sure takes a long time to get it... uh .. recertified?
Good to know the government says the government was properly following all certification procedures :rolleyes:
L39Guy
Post by L39Guy »
The technical recertification of this airplane was a long time ago; the issue has been political and optics for months now.
tailgunner
Post by tailgunner »
L39,
Proof?
'97 Tercel
Post by '97 Tercel »
The proof is that it's stated on Avcanada - that always makes it true.
L39Guy wrote: Mon Jan 20, 2020 10:44 am The technical recertification of this airplane was a long time ago; the issue has been political and optics for months now.
Say what?
How about a source for this?
Raymond Hall
From CNBC today:
Boeing is in talks to borrow $10 billion or more as 737 Max crisis wears on
Boeing is in talks with banks to secure a loan of $10 billion or more, according to people familiar with the matter, as the company faces rising costs stemming from two fatal 737 Max crashes.
The company has secured at least $6 billion from banks so far, the people said, and is talking to other lenders for more contributions. The total amount could rise if there is additional demand from banks, one person familiar with the matter said.
The loan Boeing is negotiating will be a two-year, delayed-draw loan, meaning Boeing can tap into it later, a move that may not immediately affect its credit rating as another type of loan or a bond would, according to one of the people familiar with the matter.
Boeing’s pause of the planes, which had been its best-selling aircraft, is hurting its supply chain. Spirit AeroSystems, which makes fuselages and other parts for the 737 Max, said earlier this month it would lay off 2,800 workers.
Moody’s downgraded Spirit to junk territory last week, saying it “reflects our expectation that Spirit’s liquidity profile will quickly and materially erode in the absence of mitigating developments that remain largely out of the company’s control.”
https://www.cnbc.com/2020/01/20/737-max ... -more.html
