Not available for Merlot. Merlot doesn't connect to anything. I don't know if Canadian North or SkyRegional have had any better luck with the reporting.Beachparty wrote:Go check mccpilotlog (Google it) !
For around 70$, the software let you connect directly to your airline online portal and will download all available data as far as you are able to see when you log on yourself.
So if you have been with the same airline for a while, this is a simple and extremely quick fix.
Plus, you don't have to log anymore....ever ! Just hit the "sync" button once in a while and that's it
I get it though. If you've stopped looking for a job and consider yourself parked at an airline, then it's pretty easy to get behind. Our reports at Encore don't show crew members either for that matter so unless you're manually copying down info at the end of each flight then you don't have all the info required for a Canadian logbook. Throw in a few tail swaps per day and it gets to be a lot to manage yourself compared to flying one machine for weeks on end with the same crew members.
If you're looking to go overseas though, it is very important to stay on top of your logbook. They are more concerned that everything matches up properly. Only a small percentage of Canadian pilots will fly overseas in their careers.
